imbeta 0 Posted February 26, 2020 I've almost finished putting a 302 Cleveland into my 89 XF Ute, but have run into some wiring issues. I have put an hei dizzy in but can't seem to get any spark. I've also removed the old tfi wiring and map sensor etc. I can't get the stater to turn using the ignition switch either. Share this post Link to post Share on other sites
deankxf 20,231 Posted February 27, 2020 the EST wiring probably would have have worked with the hei dissy even with the ecu removed from it XF ute didn't have TFI module, starter wont crank if the neutral switch wires are not connected(or looped for manual) not sure what you've removed, i've never removed the EST loom from one Share this post Link to post Share on other sites
