Jay Baby 21 Posted January 4, 2020 Gday, Just brought myself an XG Falcon Ute and as I don’t use social media ( at all ) thought I’d join this page. This is my 18th car however my first ford... So my situation is iv brought this nice little XG but the odometer and trip counter don’t work on it. I have already called around and found a few places that can fix it for me however I will need to remove instrument cluster to take in, is this a big job? I’m not a slowly or anything and I have already installed a kill switch from the IGN and chucked in a battery isolator ect. I just haven’t tackled anything like this yet and was looking for a friendly bit of advice on where to start? Any information would be grand Share this post Link to post Share on other sites
deankxf 20,266 Posted January 4, 2020 welcome aboard, probably should buy a gregorys book for XF (don't think there's an XG one, so if you need the electronic stuff you'll need an EA EB book also) to remove the speedo cluster, its a bit of fun in the XG.. remove the light switches on the surround is what i did(but have seen them left mounted and unplugged later) take note of where they were and what wires they were plugged into. one screw holds them on. 2 screws on top for the surround, 2 under the light switch areas, and 2 hidden under the dash that most people don't put back in.. need to remove the fuse panel for this(pull the hand brake lever out a few clicks to manouver it out the cluster mounts with 4 screws, 2 on top, 2 on the bottom. can't remember, but you might need to remove the steering wheel on XG to get the cluster out. there's no speedo cable, but there are 2 wiring plugs on the back. if you were keen.. and had a spare to play with.. the odo gear is $5 ish on ebay.. on the XG you need to remove the speedo, and remove the needle and the face plate to get access to the gear.. that's after undoing lots of screws on the cluster housing etc.. i haven't got time to google pics for you but there'll probably be a tutorial on fordmods if it still exists and may be on here also if the photos still work 1 1 Jay Baby and gerg reacted to this Share this post Link to post Share on other sites
gerg 10,871 Posted January 4, 2020 Dean's pretty much nailed it, I did mine 6 years ago and hasn't missed a beat. The original odometer gear seems to be made from a different material to the others (like neoprene), just crumbles over time. The new one you get feels a lot tougher, more like the other nylon gears. Sent from my CPH1903 using Tapatalk 1 1 deankxf and Jay Baby reacted to this Share this post Link to post Share on other sites
deankxf 20,266 Posted January 5, 2020 2 hours ago, gerg said: the original odometer gear seems to be made from a different material to the others (like neoprene CHEESE), fixed 1 1 bear351c and gerg reacted to this Share this post Link to post Share on other sites
Jay Baby 21 Posted January 5, 2020 Cheers for the response lads this is exactly why I joined this page. Can’t beat real experience This will put me off to a great start. And yes after I have the cluster I may even look into swapping the plastic gear as at worst if I mess it up I’ll still be in the exact same position of dropping the cluster at the shop. cheers lads I’ll keep you posted on how I get on Share this post Link to post Share on other sites
Jay Baby 21 Posted January 5, 2020 16 hours ago, deankdx said: welcome aboard, probably should buy a gregorys book for XF (don't think there's an XG one, so if you need the electronic stuff you'll need an EA EB book also) to remove the speedo cluster, its a bit of fun in the XG.. remove the light switches on the surround is what i did(but have seen them left mounted and unplugged later) take note of where they were and what wires they were plugged into. one screw holds them on. 2 screws on top for the surround, 2 under the light switch areas, and 2 hidden under the dash that most people don't put back in.. need to remove the fuse panel for this(pull the hand brake lever out a few clicks to manouver it out the cluster mounts with 4 screws, 2 on top, 2 on the bottom. can't remember, but you might need to remove the steering wheel on XG to get the cluster out. there's no speedo cable, but there are 2 wiring plugs on the back. if you were keen.. and had a spare to play with.. the odo gear is $5 ish on ebay.. on the XG you need to remove the speedo, and remove the needle and the face plate to get access to the gear.. that's after undoing lots of screws on the cluster housing etc.. i haven't got time to google pics for you but there'll probably be a tutorial on fordmods if it still exists and may be on here also if the photos still work just out of interest if I was to replace the gears myself am I looking at the correct ones? And is there two in there so you replace both or just one? Share this post Link to post Share on other sites
deankxf 20,266 Posted January 5, 2020 27 minutes ago, Jay Baby said: just out of interest if I was to replace the gears myself am I looking at the correct ones? And is there two in there so you replace both or just one? it's 99.9% only the small (yellow in this photo) gear that goes.. i have once had to change the bigger gear. here's a link for a $10 one for eg on ebay with 2000 odd sold https://www.ebay.com.au/itm/Odometer-Speedo-Gear-Cog-Suit-VN-VP-VR-VS-Commodore-XF-EA-EB-ED-Falcon-/271733080319?_trksid=p2385738.m4383.l4275.c10 Share this post Link to post Share on other sites
Jay Baby 21 Posted January 5, 2020 Legendary cheers bud 1 deankxf reacted to this Share this post Link to post Share on other sites
Aussieyobbo16 7 Posted January 8, 2020 On 1/4/2020 at 11:34 PM, deankdx said: probably should buy a gregorys book for XF (don't think there's an XG one, so if you need the electronic stuff you'll need an EA EB book also) you might need to remove the steering wheel on XG to get the cluster out. ive got a haynes book for eb/ed that has a supplement for xg thats actually prety handy. you dont need to remove the steering but its considerablly eaier than tryna manouvre it around the wheel. 1 deankxf reacted to this Share this post Link to post Share on other sites
Jay Baby 21 Posted January 8, 2020 Yeah well it’s on a boss kit anyway with a wood grain wheel, so I’ll just pull the wheel as it’s easy as Share this post Link to post Share on other sites
Jay Baby 21 Posted January 11, 2020 Ok,so off to a good start with the cluster removal but I can’t find the last 2 screws iv found the tops and the sides as pictured. Iv removed bottom of dash to get access to hidden ones but can’t find them I have also left the light, haz switches ect in as I’ll just unplug them after. Also pulled wheel. Please give me a heads up where to find these 2 last screws Share this post Link to post Share on other sites
Jay Baby 21 Posted January 11, 2020 Ok,so off to a good start with the cluster removal but I can’t find the last 2 screws iv found the tops and the sides as pictured. Iv removed bottom of dash to get access to hidden ones but can’t find them I have also left the light, haz switches ect in as I’ll just unplug them after. Also pulled wheel. Please give me a heads up where to find these 2 last screws just found em.... after some acrobatics Share this post Link to post Share on other sites
deankxf 20,266 Posted January 11, 2020 ah, just read you found them.. will you refit them lol? doubt it Share this post Link to post Share on other sites
Jay Baby 21 Posted January 11, 2020 Bahaha I will put em back 100% can’t be one of “them people” 1 deankxf reacted to this Share this post Link to post Share on other sites
Jay Baby 21 Posted January 11, 2020 Not sure about pulling this cluster apart now looks very fiddley Share this post Link to post Share on other sites
deankxf 20,266 Posted January 11, 2020 1 minute ago, Jay Baby said: Not sure about pulling this cluster apart now looks very fiddley it's 4 times fiddlier than the cluster removal.. actually.. probably 7times Share this post Link to post Share on other sites
Jay Baby 21 Posted January 11, 2020 9 minutes ago, deankdx said: it's 4 times fiddlier than the cluster removal.. actually.. probably 7times Yeah I might just drop cluster in to speedline they only charge $130 to fix it and at least if something is wrong I can take it back to them. Appreciate your time bud your a champion 1 deankxf reacted to this Share this post Link to post Share on other sites
deankxf 20,266 Posted January 11, 2020 no problem, keep us updated on the repair.. these threads can help people in future as long as the site is still running 1 Jay Baby reacted to this Share this post Link to post Share on other sites
Jay Baby 21 Posted January 11, 2020 No problem I will keep it up to date until it’s finished and my kms are ticking over again 1 deankxf reacted to this Share this post Link to post Share on other sites
Jay Baby 21 Posted January 12, 2020 Just decided I’m going to do a dash cluster light conversion while the cluster is out Cheap as chips on eBay be mad not too Share this post Link to post Share on other sites
deankxf 20,266 Posted January 12, 2020 check they work before putting the dash back together. the LED needs the polarity correct(180 deg out on fitting = no lights) the old globes can go in either way. Share this post Link to post Share on other sites
Jay Baby 21 Posted January 20, 2020 yeah no worries I’ll make sure they all work before I reassemble everything Share this post Link to post Share on other sites
Jay Baby 21 Posted January 21, 2020 Just thought I’d wrap up the thread Got the cluster going and installed with the dash lights upgraded to white LEDs cheers for your help Lads now running a 1993 XG with only 137500kms 2 bear351c and deankxf reacted to this Share this post Link to post Share on other sites
deankxf 20,266 Posted January 22, 2020 good for another 20years 1 Jay Baby reacted to this Share this post Link to post Share on other sites
