Chrisso 6 Posted December 26, 2019 I’m sure it’s been covered a thousand times before but I can’t seem to find it, does someone have a link to the thread on how to fix this door handle problem, just snapped my first one Sent from my iPhone using Tapatalk Share this post Link to post Share on other sites
gerg 10,871 Posted December 26, 2019 You can fix the one on it... Drill out the housing that the lever pivots on, and put in a fine thread self tapper to suit, with a washer behind it on the outside of the lever. The screw is the new pivot. Check the engagement of the lever to the arm, bend arm to make adjustments accordingly. Spray grease on all moving parts, install and test. Sent from my CPH1903 using Tapatalk Share this post Link to post Share on other sites
deankxf 20,286 Posted December 26, 2019 just tagged you in My gemini thread, but as gerg said above, pics of My gemini one below Share this post Link to post Share on other sites
bear351c 10,270 Posted December 30, 2019 ........fix the door. The hinges are probably buggered, forcing you to "lift" the door with the handle. 2 GRIFF and deankxf reacted to this Share this post Link to post Share on other sites
