brady 0 Posted December 17, 2019 Hey guys my brother brought a EL the other day filled it up with gas started it up had it running for probably one hour to charge the battery drove it around a bit it was running fine not one problem so then we turned it off went in side for probably 1 hour and 30 mins about came out side started it up to jump start a nother car drove it back put it in to drive turned right and it just died will not fire anymore its getting gas tried it on fuel as well but nothing so we checked if it had spark and it didnt so were thinking it has something to do with the Smartlock or something like that. Share this post Link to post Share on other sites
CHESTNUTXE 7,260 Posted December 17, 2019 change interior light fuse,i went thru this many times,or dizzy n coil very common to just go , Share this post Link to post Share on other sites
brady 0 Posted December 18, 2019 The interior like works does anyone think it has somthing to do with the smart lock Share this post Link to post Share on other sites
bear351c 10,260 Posted December 18, 2019 Try holding the key all the way over (to start position), and hit the dash , in front of your left knee, with your other hand, I think the Smartlock is in behind there. Might be a dry solder joint. Share this post Link to post Share on other sites
CHESTNUTXE 7,260 Posted December 19, 2019 such a common problem with EL ,and frustrating cause it goes then it dont go,i went thru the same thing and fixed it by selling the car Share this post Link to post Share on other sites
brady 0 Posted December 19, 2019 Hahahahah what do u recommend doing Share this post Link to post Share on other sites
