Huntnfish 3 Posted December 5, 2019 Hi Guys first post please be gentle......... I have a 1972 XY Falcon Tribute, the Diff that is is there now is Drum Brake.It must be one of the last diff as it has the mounting brackets for the rear sway bar welded to the housing.I am fitting a S/Hand LSD Borg Warner diff with Disc Brakes into the car.Diff Tag Serial Number is.....P/N 78DA-4005-MA Serial #12332. Ratio 2.72.So my questions are1. What is this diff out of.2. What Brake bias problems ....(A) fit what model Master Cyl to fix this but still look the same...(B) fit a Mustang Brake bias Valve unit............Or What else.3. Hand brake cable difference.........length.I have measured and this just slips straight in.And thoughts on any other problems.......Regards Dave Share this post Link to post Share on other sites
deankxf 20,284 Posted December 6, 2019 you may find your answers in this thread , but i would say the biggest issue is the XA onwards diffs are slightly wider than an XR -XY diff making the wheel choice a bit harder to judge they fit 6" rims easy, but not sure how wide 78DA is XC onwards, so has the big center bore wheels.. (so XY wheels won't fit) i'd assume a sway bar was available in 1978, they made drum brake diffs that are almost same right up to 1993 Share this post Link to post Share on other sites
Huntnfish 3 Posted December 6, 2019 Hi Dean, Wow great reading, i will take pictures, and measurements, over the weekend. 1.........I have ordered new discs Part # DR109 and new Disc pads DB1046GCT from Australia..........DID I ORDER THE CORRECT PARTS. 2.........What Axle bearing sets should I order 3..........What Caliper overhaul kit sets should I order. Regards Dave Share this post Link to post Share on other sites
deankxf 20,284 Posted December 6, 2019 41 minutes ago, Huntnfish said: Hi Dean, Wow great reading, i will take pictures, and measurements, over the weekend. 1.........I have ordered new discs Part # DR109 and new Disc pads DB1046GCT from Australia..........DID I ORDER THE CORRECT PARTS. 2.........What Axle bearing sets should I order 3..........What Caliper overhaul kit sets should I order. Regards Dave 1. perhaps @Mr Polson would know or be able to look up.. 2 and 3.. same as above are the discs on part of the back of the axle or can they be removed with one screw off the axle from the outside. photos will help Share this post Link to post Share on other sites
bear351c 10,270 Posted December 7, 2019 DB1046 are for an XD rear caliper. Some late XC too. Look like these....... 1 deankxf reacted to this Share this post Link to post Share on other sites
Huntnfish 3 Posted December 7, 2019 1 hour ago, bear351c said: DB1046 are for an XD rear caliper. Some late XC too. Look like these....... 1 hour ago, bear351c said: DB1046 are for an XD rear caliper. Some late XC too. Look like these....... Yes that is it in a nutshell removable disc without disturbing the axle/......................so when i order parts what model and year do i quote to the wholesaler SCA or any rare spares ,,,auto supplier. ........................MAN YOUR GOOD. Share this post Link to post Share on other sites
deankxf 20,284 Posted December 7, 2019 57 minutes ago, Huntnfish said: Yes that is it in a nutshell removable disc without disturbing the axle/......................so when i order parts what model and year do i quote to the wholesaler SCA or any rare spares ,,,auto supplier. 1979 to 1981 XD Fairmont Ghia is probably the easiest for them to look up, all had that diff. same can be said for the ZJ fairlane of same year or the equiv LTD which is an FC LTD. XD ghia also had a sway bar standard, which explains a little also. Share this post Link to post Share on other sites
