Slow250XC 1,512 Posted October 12, 2019 Have found a 3.45 lsd from an xh xr8 to go into the xc.I have a xf ute driveshaft under the bench with the flat flange.Are the ute driveshafts longer than sedans? Sent from my SM-J330G using Tapatalk Share this post Link to post Share on other sites
bear351c 10,260 Posted October 13, 2019 Not sure on XH (later models) but on the early stuff, XA - XE etc..... the ute has longer leaf springs, and tailshaft. Pretty sure the Utes were set up on the Fairlane/wagon wheel base. Hence they too have longer cart springs, and tailshaft, Prob best to install diff and trans, then measure it. Don't forget, full weight on the tyres. (Dont have the diff hanging) 1 Slow250XC reacted to this Share this post Link to post Share on other sites
slydog 7,873 Posted October 13, 2019 E series sedan fit X series sedan E series wagons and utes fit x series wagons utes. I have a ED diff in the ute with a XH steel ute tail shaft. 4 BGDAV, CHESTNUTXE, Slow250XC and 1 other reacted to this Share this post Link to post Share on other sites
Slow250XC 1,512 Posted October 13, 2019 Thanks guys, as i thought. Next plan will be to fit flat flange to xc driveshaft. Sent from my SM-J330G using Tapatalk 1 CHESTNUTXE reacted to this Share this post Link to post Share on other sites
slydog 7,873 Posted October 13, 2019 Just get a e series shaft. 2 deankxf and Slow250XC reacted to this Share this post Link to post Share on other sites
deankxf 20,233 Posted October 13, 2019 1 hour ago, Slow250XC said: Thanks guys, as i thought. Next plan will be to fit flat flange to xc driveshaft. Sent from my SM-J330G using Tapatalk if you wanted to keep your current tailshaft you'll need a hybrid yoke as the E series(flat flange yoke) is 1310 and the X series is smaller(not sure what it is) otherwise, just get an EB ED ED EL SEDAN tailshaft and it will go straight in to XA to XF sedan 1 Slow250XC reacted to this Share this post Link to post Share on other sites
Slow250XC 1,512 Posted October 13, 2019 Yeah you guys are right. Common sense must prevail haha. Sent from my SM-J330G using Tapatalk Share this post Link to post Share on other sites
deankxf 20,233 Posted October 13, 2019 1 minute ago, Slow250XC said: Yeah you guys are right. Common sense must prevail haha. Sent from my SM-J330G using Tapatalk done it before 1 Slow250XC reacted to this Share this post Link to post Share on other sites
gerg 10,871 Posted October 13, 2019 Fairlane/LTD shafts are the same wheelbase as utes and wagons also (same floorpan) just in case you come across one of them for parts.Utes and wagons use the same leaf springs as well, but I'm unsure about Fairlanes being the same here.My XE wagon uses an alloy EF wagon shaft and flange. That was a straight bolt-on.Sent from my CPH1903 using Tapatalk 1 Slow250XC reacted to this Share this post Link to post Share on other sites
Slow250XC 1,512 Posted October 16, 2019 Easy as boys, bloke with the diff is throwing in an e series sedan shaft for free. Now to get a speedo drive to match.Sent from my SM-J330G using Tapatalk Share this post Link to post Share on other sites
deankxf 20,233 Posted October 17, 2019 8 hours ago, Slow250XC said: Easy as boys, bloke with the diff is throwing in an e series sedan shaft for free. Now to get a speedo drive to match. Sent from my SM-J330G using Tapatalk @CHESTNUTXE will have a 3.45 gear surplus soon (if its for a borgwarner gearbox?) 2 CHESTNUTXE and Slow250XC reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,261 Posted October 17, 2019 [mention=7196]CHESTNUTXE[/mention] will have a 3.45 gear surplus soon (if its for a borgwarner gearbox?) Didn't onlyxr6 have 3.45 v8 had 3.27Sent from my SM-G570Y using Tapatalk 1 Slow250XC reacted to this Share this post Link to post Share on other sites
Slow250XC 1,512 Posted October 17, 2019 [mention=7196]CHESTNUTXE[/mention] will have a 3.45 gear surplus soon (if its for a borgwarner gearbox?) Single rail box so yeah. But wrong side of the ditch lol. Sent from my SM-J330G using Tapatalk 1 CHESTNUTXE reacted to this Share this post Link to post Share on other sites
Slow250XC 1,512 Posted October 17, 2019 Didn't onlyxr6 have 3.45 v8 had 3.27Sent from my SM-G570Y using TapatalkMeant to type xr6 at the start. Not sure why i said xr8.Sent from my SM-J330G using Tapatalk 1 CHESTNUTXE reacted to this Share this post Link to post Share on other sites
deankxf 20,233 Posted October 17, 2019 1 minute ago, Slow250XC said: Single rail box so yeah. But wrong side of the ditch lol. Sent from my SM-J330G using Tapatalk it's postable.. they send pallets over the ditch even 2 Slow250XC and CHESTNUTXE reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,261 Posted October 17, 2019 Meant to type xr6 at the start. Not sure why i said xr8.Sent from my SM-J330G using TapatalkEL GT had 3.45Sent from my SM-G570Y using Tapatalk 1 Slow250XC reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,261 Posted October 17, 2019 it's postable.. they send pallets over the ditch evenYou can still buy the 22 grey from ford under au part number thats how i got mine about 50 buxSent from my SM-G570Y using Tapatalk 1 Slow250XC reacted to this Share this post Link to post Share on other sites
Slow250XC 1,512 Posted October 17, 2019 it's postable.. they send pallets over the ditch evenFreight is not the killer. It is the bank transfer.My better half normally does all that for me, however she is in hospital for at least another month and a half. But if Chestnut is right that ford have them available, i can order through work Sent from my SM-J330G using Tapatalk 1 deankxf reacted to this Share this post Link to post Share on other sites
Slow250XC 1,512 Posted October 18, 2019 Sweet ordered today, 1 left in NZ for 38 bucks.Sent from my SM-J330G using Tapatalk 3 CHESTNUTXE, gerg and deankxf reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,261 Posted October 18, 2019 Sweet ordered today, 1 left in NZ for 38 bucks.Sent from my SM-J330G using TapatalkYepSent from my SM-G570Y using Tapatalk Share this post Link to post Share on other sites
CHESTNUTXE 7,261 Posted October 18, 2019 YepSent from my SM-G570Y using TapatalkThe rare black 23 tooth is very hard to find could only be in 5 speed xrSent from my SM-G570Y using Tapatalk Share this post Link to post Share on other sites
Slow250XC 1,512 Posted October 19, 2019 The rare black 23 tooth is very hard to find could only be in 5 speed xrSent from my SM-G570Y using TapatalkWant me to get my suppliers to have a dig around for you? If you have a part # i can get them to put an email round the dealers.Sent from my SM-J330G using Tapatalk 1 CHESTNUTXE reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,261 Posted October 19, 2019 you could try but slupyers are out some years ago ? but the 22 grey works fine with 3.45 Share this post Link to post Share on other sites
