scottly 475 Posted October 12, 2019 Hey fellas, I’m currently deleting wires out of the factory loom on my xd. I have come across this green and white wire and I don’t know what it was for. I don’t recall ever using it, it goes from the engine bay through the fire wall to the red factory connector. I also can’t find it in the Gregory’s manual, any help would be fantastic. Sent from my iPhone using Tapatalk Share this post Link to post Share on other sites
FORD_MAN 1,026 Posted October 13, 2019 its for the optional driving/fog lights 1 scottly reacted to this Share this post Link to post Share on other sites
scottly 475 Posted October 13, 2019 Are you sure man? I pulled all my factory fog light wiring out of the car in one piece and can not remember it going to that wire. But I was more than likely drunk. I will check when I get home thanks for the reply I hope your right. It could be the trigger wire for the relay Share this post Link to post Share on other sites
deankxf 20,266 Posted October 13, 2019 2 hours ago, FORD_MAN said: its for the optional driving/fog lights 2 hours ago, scottly said: Are you sure man? I pulled all my factory fog light wiring out of the car in one piece and can not remember it going to that wire. But I was more than likely drunk. I will check when I get home thanks for the reply I hope your right. It could be the trigger wire for the relay if it was near the drivers headlight, then it would be the driving light/fog light wire i think also. can't remember any other wires that were round like that. other than the temp sender and maybe the choke wire on the XE(not applicable to XD) 1 scottly reacted to this Share this post Link to post Share on other sites
scottly 475 Posted October 13, 2019 From memory I think your right. Temp sender has a round plug And the wire is definitely not green and white. The choke is a single wire with a brown plastic plug that slots on to a male fitting. Yes it it looks like it was meant to be around the drivers side Share this post Link to post Share on other sites
scottly 475 Posted October 15, 2019 Both of you were correct it’s for the factory driving lights. I checked the factory spotlight wiring and their is a male round pin that goes to a green and white wire. It’s now time to cut the wire out of the car Share this post Link to post Share on other sites
deankxf 20,266 Posted October 15, 2019 1 hour ago, scottly said: Both of you were correct it’s for the factory driving lights. I checked the factory spotlight wiring and their is a male round pin that goes to a green and white wire. It’s now time to cut the wire out of the car would be handy to use as another purpose, alarm, thermo fan override, etc Share this post Link to post Share on other sites
scottly 475 Posted October 16, 2019 Yeah your right, I’ll probably regret it when I need it one day but it’s getting cut for now. 1 deankxf reacted to this Share this post Link to post Share on other sites
