1977 ZH 540 Posted May 6, 2013 Im in need of a electric fuel pump for my xf 250 xflow webber carby the ute I got the motor out of had an external pump mounted in the bay so im looking into the same setup for mine basically what size will suit a standard motor? yes I have a mechanical pump but the motor has a efi cam so it wont drive the fuel pump lol cheers in advance. Share this post Link to post Share on other sites
revhead 1,392 Posted May 6, 2013 just a low pressure solid state ,fool pump id say no more then 8psi ,or your carby will start to wet its self,lol 1 1977 ZH reacted to this Share this post Link to post Share on other sites
1977 ZH 540 Posted May 6, 2013 will I need a fuel reg aswell? Share this post Link to post Share on other sites
slydog 7,873 Posted May 6, 2013 factory webber takes around 3-4 psi from memory 3 mcfly94, revhead and 1977 ZH reacted to this Share this post Link to post Share on other sites
revhead 1,392 Posted May 6, 2013 sly speaks the truth if you can find a new low pressure pump u wont need a reg 2 1977 ZH and KRUPTOR reacted to this Share this post Link to post Share on other sites
1977 ZH 540 Posted May 6, 2013 cheers guys, ill have to look around now. Share this post Link to post Share on other sites
KRUPTOR 929 Posted May 6, 2013 I just bought a goss solid state pump on the weekend 4-6psi rated.Works great. Share this post Link to post Share on other sites
1977 ZH 540 Posted May 6, 2013 I just bought a goss solid state pump on the weekend 4-6psi rated.Works great. if you don't mind me asking what did that set you back? Share this post Link to post Share on other sites
KRUPTOR 929 Posted May 6, 2013 Cost me $60.You could go a facett,if you wanted.I could have bought one off ebay cheaper but i needed it for the weekend. Share this post Link to post Share on other sites
1977 ZH 540 Posted May 6, 2013 Cost me $60.You could go a facett,if you wanted.I could have bought one off ebay cheaper but i needed it for the weekend. not to bad then may see what I can source tomorrow, I take it you didn't need a fuel reg? Share this post Link to post Share on other sites
1977 ZH 540 Posted May 6, 2013 No reg needed. cool, thanks for that mate. Share this post Link to post Share on other sites
steve mcqueen 1,796 Posted May 6, 2013 Here you go. http://www.ebay.com.au/itm/Electric-Fuel-Pump-12-volt-Solid-State-4-to-6psi-130-LPH-Petrol-Universal-New-/130721428894?pt=AU_Car_Parts_Accessories&hash=item1e6f9ab59e Share this post Link to post Share on other sites
1977 ZH 540 Posted May 7, 2013 Cheers Steve if I cant get one local today I recon that will be a go. Share this post Link to post Share on other sites
