Jafia 17 Posted August 22, 2019 So a stupid question :P How do you change a headlight globe in a BF Falcon. I'm use to the older models where is was simple to change the globes, and honestly from the looks of it looks like a pain in the bum :/ Share this post Link to post Share on other sites
2redrovers 21,389 Posted August 22, 2019 Is it the same as BA? If so, squeeze the sides of the wiring plug to release it from the terminals as you pull it back, take the rubber seal off the back of the housing, globe is held in by a spring clamp just look/feel for the light grey wire thing and gently push it in a little then sort of upwards to unhook it from the housing, globe should practically fall out. Reverse to install. I just changed my au one with one I harvested from the ba donor. Don't know if bf is different. Share this post Link to post Share on other sites
ESPSIX 143 Posted August 22, 2019 As above, and BA and BF are the same. 1 2redrovers reacted to this Share this post Link to post Share on other sites
Mr Polson 10,214 Posted August 22, 2019 Worst part is getting your hand in there, especially if it's an outer globe. May be easier to remove battery (driver side) or airbox (passenger side) depending on the size of your hands.Then as said, rubber boot off, squeeze connector with hands and it'll come off, could be stuck on if hasn't been out for a while.To remove the globe theres a metal spring clip that unclips.Remember when installing the new globe not to touch the glass with your fingers or it'll blow way quicker than you want. Share this post Link to post Share on other sites
deankxf 20,266 Posted August 22, 2019 with the Lexus LS400 i had, it was easier to remove the headlight.. which wasn't hard. not sure what the ford ones are like Share this post Link to post Share on other sites
ESPSIX 143 Posted August 22, 2019 The battery side one can be done without removing the battery, but air box out on the other. got to take front bar off to get headlights out. 1 deankxf reacted to this Share this post Link to post Share on other sites
