SteveXE 0 Posted August 16, 2019 Hi guys. I have a XE FALCON. Original 250xflow now dropping in a Clevo. It's got a factory 4speed singlerail. I brought a kit from Rare Spares part number F2271. It doesn't seem to fit/ work. What am I doing wrong? Do i need any other extra bits? Thanks Share this post Link to post Share on other sites
SteveXE 0 Posted August 16, 2019 Sorry i forgot to mention im trying to convert it to a hydrolic clutch Share this post Link to post Share on other sites
gerg 10,871 Posted August 16, 2019 Let's see... I did this exact conversion and you need:Hydraulic pedal box (or swap pedal shafts)Hydraulic pedalMaster cylinderClutch lineSlave cylinderHydraulic forkWhat isn't working for you?Sent from my CPH1903 using Tapatalk 1 CHESTNUTXE reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,260 Posted August 16, 2019 pictures please Share this post Link to post Share on other sites
SteveXE 0 Posted August 16, 2019 Hey mate, As i mentioned i brought a kit in which i was told bolts on to the factory pedal box. The pedal is a hydrolic one. I have master slave and fork. Have a look at rare spares in search tyre in F2271. It will come up. Share this post Link to post Share on other sites
SteveXE 0 Posted August 16, 2019 14 minutes ago, CHESTNUTXE said: pictures please Share this post Link to post Share on other sites
CHESTNUTXE 7,260 Posted August 16, 2019 Hey mate, As i mentioned i brought a kit in which i was told bolts on to the factory pedal box. The pedal is a hydrolic one. I have master slave and fork. Have a look at rare spares in search tyre in F2271. It will come up.I have the same oneSent from my SM-G570Y using Tapatalk Share this post Link to post Share on other sites
SteveXE 0 Posted August 16, 2019 3 minutes ago, CHESTNUTXE said: I have the same one Sent from my SM-G570Y using Tapatalk So what would I be doing wrong? Have you done your one? Share this post Link to post Share on other sites
CHESTNUTXE 7,260 Posted August 16, 2019 I have the same oneSent from my SM-G570Y using TapatalkSo what dont work mateSent from my SM-G570Y using Tapatalk Share this post Link to post Share on other sites
SteveXE 0 Posted August 16, 2019 Just can't mount the pedal on. I'm not at the shop atm. But i have someone who has over 30 years experience doing it and he can't seem to get it to fit. I will see if i can ask him and get back to you. Share this post Link to post Share on other sites
CHESTNUTXE 7,260 Posted August 16, 2019 So what dont work mateSent from my SM-G570Y using TapatalkYou need to go to my thread on this exact conversion hyd pedal box conversionSent from my SM-G570Y using Tapatalk Share this post Link to post Share on other sites
SteveXE 0 Posted August 16, 2019 Do you know if i have the right kit from rare spares? Share this post Link to post Share on other sites
deankxf 20,231 Posted August 16, 2019 5 minutes ago, SteveXE said: So what would I be doing wrong? Have you done your one? if you start with an auto pedal box it would fit easier.. i have a feeling the shaft won't fit due to the others having a flat on the shaft and you'd need to file it (the hole in the pedal box) out to round. not sure if the cable manual pedal box has the pivot in the way? might need to cut it off?(if so, i'd find an auto one, and sell the manual cable one, as they are getting rarer now due to cracking) Share this post Link to post Share on other sites
CHESTNUTXE 7,260 Posted August 16, 2019 if you start with an auto pedal box it would fit easier.. i have a feeling the shaft won't fit due to the others having a flat on the shaft and you'd need to file it (the hole in the pedal box) out to round. not sure if the cable manual pedal box has the pivot in the way? might need to cut it off?(if so, i'd find an auto one, and sell the manual cable one, as they are getting rarer now due to cracking) Yes dean this was my manual xe one you must cut and grind to fit Sent from my SM-G570Y using Tapatalk 1 deankxf reacted to this Share this post Link to post Share on other sites
