xfish 20 Posted July 13, 2019 Hey guys, We are ready to mount my 140amp ( one wire alternator )on to my XF (250 crossflow), and have come into a conundrum. The instructions state that the alternator has to be earth, but have seen instances where it has not been earthed. Can some inform me of why it can work 'not being earthed' and 'being earthed'? Share this post Link to post Share on other sites
deankxf 20,286 Posted July 13, 2019 not sure, maybe @SPArKy_Dave knows BGDAV ran an earth to his, was needed for warranty.. can't see how it would differ being mounted to a metal engine that is also earthed(for the starter motor to work) Share this post Link to post Share on other sites
gerg 10,871 Posted July 13, 2019 I think the point of separate earthing is to avoid the reliance on a good electrical contact between the mount boss, the bolt, any spacers in between, and the block which all or at least some may be painted or rusty and not conduct whatever amps the alternator is capable of.Sent from my CPH1903 using Tapatalk 1 deankxf reacted to this Share this post Link to post Share on other sites
SPArKy_Dave 8,870 Posted July 13, 2019 As long as the engine block earth is ok, with appropriate gauge cable for 140A (battery to block, and engine block to body), then the alternator will be earthed just by being bolted to the engine. Share this post Link to post Share on other sites
xfish 20 Posted July 13, 2019 Yes, thats how my set-up is. And worse case scenario, is that if it isn't earthed right, the alternator wont charge? Share this post Link to post Share on other sites
deankxf 20,286 Posted July 14, 2019 10 hours ago, xfish said: Yes, thats how my set-up is. And worse case scenario, is that if it isn't earthed right, the alternator wont charge? i think you'd find if it's not earthed well, it could overcharge? and or not charge.. i've had overcharging when the earth wire came out of the battery clamp once.. well, i think that's what happened? was before i had a clue about most things. Share this post Link to post Share on other sites
AXD408 100 Posted July 26, 2019 So, quick question.. have any of you guys used one of the Bullet low mount altrrnator" brackets to suit an electric water pump?? Just tossing up to get an early (VN to VT) or late (aftermarket like MSD, Powerhouse, tuff) 140a alt to suit and wondering if one lines up better than the other with the crank pulley. Cheers Sent from my SM-G935F using Tapatalk Share this post Link to post Share on other sites
