Aussieyobbo16 7 Posted July 4, 2019 Alright all. The wipers on my xg have randomly decided to stop working. Not ideal when trying to get ready for roady. I’ve checked all the fuses and relays I can find but still nothin and all the wires look in good nick. Does this mean me motor is buggered. And if so is there chance I could get an au one to fit in there. Tia Share this post Link to post Share on other sites
deankxf 20,233 Posted July 4, 2019 first check the earth near the bonnet hinge, that's all that stopped mine working.. unscrew, clean the area and wire and refit Share this post Link to post Share on other sites
Aussieyobbo16 7 Posted July 4, 2019 Earths all good. Still nothin. Share this post Link to post Share on other sites
deankxf 20,233 Posted July 4, 2019 not sure what the AU motor looks like, but it may be same (you'd need to remove it from the wiper arm assembly at min. .not sure if the wiring plugs would be same either.) XF to XH would be a direct fit i would think. if you can find one.. that's assuming the motor is stuffed(doubt it, usually they are slow when old..) i'd unplug and replug in the wiring connector. old connections can get tarnish on them also and be bad connections no idea which wires do what in the wiper motor to hotwire it for checking, but someone might? Share this post Link to post Share on other sites
Aussieyobbo16 7 Posted July 4, 2019 Au motor had same plug and basic shape. But the shaft that connects to the linkages Is the wrong shape. I tried to swap em around but they’re setup too different. Stripper the original motor down and cleaned it and out it back together again. Havnt managed to get it reinstalled yet. Sent from my iPhone using Tapatalk 1 deankxf reacted to this Share this post Link to post Share on other sites
SPArKy_Dave 8,831 Posted July 4, 2019 The motor's have an over-temp cutout in them. If there's too much drag throughout the mechanism, from lack of grease etc, they get hot and cut out. Share this post Link to post Share on other sites
