Recommended Posts
Hey Boys, so I have 1985 Ford xf powered by a 351c. I have lost brake lights. All other lights work and all electrics are sweet. I changed the bulbs still no brake lights. A mate mentioned it may be a fuse so i checkes the fuse box and cant locate a brake light fuse.
Any suggestions to what the problem may be and how I can go about getting them working again?
Share this post
Link to post
Share on other sites
Sweet as boys ill have a look under the pedal. By the look of it its just plug and play?
It will have an adjustment to make. You unscrew the old one and screw in the new till it stops, come out maybe half or full turn or so, plug it in and check adjustment. You have to unplug it if you need more than a couple of turns.
Sent from my CPH1903 using Tapatalk
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
