Michael.Charalambous 1 Posted June 21, 2019 Hey Boys, so I have 1985 Ford xf powered by a 351c. I have lost brake lights. All other lights work and all electrics are sweet. I changed the bulbs still no brake lights. A mate mentioned it may be a fuse so i checkes the fuse box and cant locate a brake light fuse. Any suggestions to what the problem may be and how I can go about getting them working again? Share this post Link to post Share on other sites
gerg 10,871 Posted June 21, 2019 Sounds like brake light switch down on the pedal.Sent from my CPH1903 using Tapatalk Share this post Link to post Share on other sites
steve mcqueen 1,796 Posted June 21, 2019 As above. It looks like.... https://www.ebay.com.au/itm/Ford-Falcon-Fairmont-Xf-Brake-Light-Switch/151795865928?hash=item2357bd1948:g:TXoAAOSwgQ9V4QIP&frcectupt=true Share this post Link to post Share on other sites
Michael.Charalambous 1 Posted June 22, 2019 Sweet as boys ill have a look under the pedal. By the look of it its just plug and play? Share this post Link to post Share on other sites
gerg 10,871 Posted June 22, 2019 Sweet as boys ill have a look under the pedal. By the look of it its just plug and play? It will have an adjustment to make. You unscrew the old one and screw in the new till it stops, come out maybe half or full turn or so, plug it in and check adjustment. You have to unplug it if you need more than a couple of turns.Sent from my CPH1903 using Tapatalk Share this post Link to post Share on other sites
