thaenormountainstorm 3 Posted June 13, 2019 She just wont run. I wind her over runs for about a second (1 eleph...) then dies. The symptoms the night before after i drove little over 5 ks after getting 40 bucks fuel. Was an in consistant idle and a strong smell of fuel in the cab. And when i had started her at the servo (before coming back home) the whole engine sorta grabbed before starting. Sent from my SM-G930F using Tapatalk Share this post Link to post Share on other sites
bear351c 10,270 Posted June 13, 2019 Anymore info..? Really hard to diagnose over the 'Net. Still cranks, but never 'kicks' Runs, but on 5 cylinders Ignition leads, module, coil pack? Blocked fuel filter Collapsed air filter Immobiliser? 1 thaenormountainstorm reacted to this Share this post Link to post Share on other sites
thaenormountainstorm 3 Posted June 13, 2019 Still kicks then runs on all cylinders for a second tgen cuts out.Sent from my SM-G930F using Tapatalk 1 bear351c reacted to this Share this post Link to post Share on other sites
SPArKy_Dave 8,863 Posted June 13, 2019 Check fuel pump, fuel regulator and/or Map sensor. 1 thaenormountainstorm reacted to this Share this post Link to post Share on other sites
thaenormountainstorm 3 Posted June 13, 2019 2 questions fuel regulator wheres that. And map sensor, whats that?Sent from my SM-G930F using Tapatalk Share this post Link to post Share on other sites
SPArKy_Dave 8,863 Posted June 15, 2019 The fuel regulator is the canister looking thing, at the end of the fuel rail, up at the firewall. It has a vacuum line running into the top of it. The map sensor, is a rectangular plastic box thingy, with a plug and vacuum line. It lives just under the edge of the radiator coolant tank, also up near the firewall. Share this post Link to post Share on other sites
SPArKy_Dave 8,863 Posted June 15, 2019 Also, can you take a pic of the upper and lower radiator hoses for me? Specifically where they connect to the engine and to the radiator. Share this post Link to post Share on other sites
