eattsie9 350 Posted June 1, 2019 Hey All To anybody running the Koni reds, What do you have your rebound set up? mine is currently on the softest and i think I'm going to adjust it a turn or 2. Thanks Share this post Link to post Share on other sites
eattsie9 350 Posted June 1, 2019 Well I went for roughly half way between full soft and full stiff ill report back how that feels Share this post Link to post Share on other sites
SPArKy_Dave 8,829 Posted June 1, 2019 Straight out of the box setting here. I thought the rebound adjustment was just to account for wear mainly? 1 eattsie9 reacted to this Share this post Link to post Share on other sites
gerg 10,871 Posted June 2, 2019 Well I went for roughly half way between full soft and full stiff ill report back how that feelsI did mine so it felt roughly the same pulling it out as pushing it in (that's what she said) ie: 50/50 rateSent from my CPH1903 using Tapatalk 1 eattsie9 reacted to this Share this post Link to post Share on other sites
Crazy2287 1,886 Posted June 2, 2019 I'm running max stiff in the rear. (Only have koni in rear) It depends on what you want, street strip or drag. You generally want rebound to be firmer then compression. But this also depends on spring rate. Also how high is the car and how far from the bump stops. I use a stiff shock in the rear to stop my tail shaft slapping the tunnel. And for track. 1 eattsie9 reacted to this Share this post Link to post Share on other sites
eattsie9 350 Posted June 2, 2019 Crazy, how low is your car? What springs? Share this post Link to post Share on other sites
