SteveHobart 57 Posted May 5, 2019 Hi All, I have a question regarding an XF EFI which I’m installing a Megasquirt ECU into. It’s been surprisingly easy (which some help from the vendor, but I have a couple questions I’m hoping you good peeps can help with. 1. There’s a MAF Sensor in the kit but no cable for it and no reference on the wiring diagrams supplied. Do I need a MAF? 2. The pair to the Crank Position Sensor. Well I don’t believe there is a Crank Position Sensor on an XF. Do I need to use this? Any advice would be greatly appreciated. Cheers Steve Sent from my iPhone using Tapatalk Share this post Link to post Share on other sites
wokko 21 Posted May 5, 2019 I might be wrong but I'm pretty sure Megasquirt uses a map sensor instead of maf sensor Share this post Link to post Share on other sites
SteveHobart 57 Posted May 6, 2019 Sorry, yes, MAP SensorSent from my iPhone using Tapatalk Share this post Link to post Share on other sites
NZXD 2,328 Posted May 8, 2019 Good modification. What did the mega squirt set you back? Sent from my iPhone using Tapatalk Share this post Link to post Share on other sites
SPACK 68 Posted May 9, 2019 More Importantly, what was the differences you found after installation ? Share this post Link to post Share on other sites
SteveHobart 57 Posted May 12, 2019 I haven’t found any differences yet, still putting the engine and transmission together! Ha ha But I’ll advise you when I get it all back in. The Megasquirt Unit I Got was from Shiftkits Australia and the service and price was excellent, couldn’t recommend more highly! Sent from my iPhone using Tapatalk 2 NZXD and bear351c reacted to this Share this post Link to post Share on other sites
SPACK 68 Posted May 12, 2019 Thanks STEVEHOBART..will love to hear how it goes.. Share this post Link to post Share on other sites
BryceVR 13 Posted August 11, 2019 Have you done any more on this. I'm about to pull the pin on a V2 or V3 for my Corty and I'm eager for any information. My plan is the MSv3 and an EDIS ignition system. This should allow for a bigger cam and higher comp. Do you have a basic how-to or can you point me toward any useful resources. Share this post Link to post Share on other sites
SPACK 68 Posted October 3, 2019 Is the UNICHIP any good for the XF EEC1V computer.?..Or using the EA/EB 1 closed loop( no smartlock) EEC1V, and running a stock code better, and cheaper...? Share this post Link to post Share on other sites
