Aussieyobbo16 7 Posted April 28, 2019 hi all. just wondering if there is any way to remove the piece of trim aroung the outside of the rear window without doing too much damage to the rest of the car. i have a set of roll bars that are bolted into an xh window trim so im wondering what the best way to install them without too much damage or modication. Share this post Link to post Share on other sites
deankxf 20,278 Posted April 28, 2019 the window trims come off from the inside, need the head lining dropped for the top ones i think. i haven't done them before just seen how they attach. got a photo, sounds unusual.. Share this post Link to post Share on other sites
Aussieyobbo16 7 Posted April 28, 2019 2 minutes ago, deankdx said: the window trims come off from the inside, need the head lining dropped for the top ones i think. i haven't done them before just seen how they attach. got a photo, sounds unusual.. I’ll look into that. And I could get a photo but my phone won’t let me upload them. Says the files are too big Share this post Link to post Share on other sites
deankxf 20,278 Posted April 28, 2019 3 minutes ago, Aussieyobbo16 said: I’ll look into that. And I could get a photo but my phone won’t let me upload them. Says the files are too big are you using the tapatalk app? apparently its simple to upload with that. i am still doing it old school transferring to laptop for pics Share this post Link to post Share on other sites
Aussieyobbo16 7 Posted April 28, 2019 Just now, deankdx said: are you using the tapatalk app? apparently its simple to upload with that. i am still doing it old school transferring to laptop for pics Atm I’m only on safari. But I’ve heard a lot about tapatalk Share this post Link to post Share on other sites
deankxf 20,278 Posted April 28, 2019 1 minute ago, Aussieyobbo16 said: Atm I’m only on safari. But I’ve heard a lot about tapatalk everyone that couldn't upload pics and ended up using tapatalk has got it working fairly quickly. i should try it just to see how it's done lol Share this post Link to post Share on other sites
Aussieyobbo16 7 Posted April 28, 2019 yeah it works well. Here’s the bars Sent from my iPhone using Tapatalk Share this post Link to post Share on other sites
deankxf 20,278 Posted April 28, 2019 if you unbolt them at the back are you sure they are even connected at the screen? Share this post Link to post Share on other sites
Aussieyobbo16 7 Posted April 28, 2019 if you unbolt them at the back are you sure they are even connected at the screen?Sent from my iPhone using Tapatalk Share this post Link to post Share on other sites
Demmo 295 Posted April 28, 2019 are you wanting to fit them to an xg as that white ute is an xh with the rounded window trim so they may not fit tight on xg cheers demmo Share this post Link to post Share on other sites
Aussieyobbo16 7 Posted April 28, 2019 The white Ute in the pic is an xf that they were fitted to with the xh trim. I’m trying to figure out how it was done. Share this post Link to post Share on other sites
deankxf 20,278 Posted April 28, 2019 1 hour ago, Aussieyobbo16 said: The white Ute in the pic is an xf that they were fitted to with the xh trim. I’m trying to figure out how it was done. that ute in the pic is an XH, it's got rounded roof edges. (XH mirrors and bonnet slopes off a lot in the pic hard to tell though) what makes you think it's an XF? Share this post Link to post Share on other sites
Aussieyobbo16 7 Posted April 28, 2019 what makes you think it's an XF?Square front end and a lack of 4.0 ouch badgesSent from my iPhone using Tapatalk Share this post Link to post Share on other sites
deankxf 20,278 Posted April 29, 2019 3 hours ago, Aussieyobbo16 said: Square front end and a lack of 4.0 ouch badges Sent from my iPhone using Tapatalk if it looks like this on the front, it is an XH.. actually this pic from grays online doesn't have 4.0 badges either. the roof edges are rounded on the sides on XH XD XE XF XG all have sharp edges rather than a curve, this is probably why the XH window surrounds are different. Share this post Link to post Share on other sites
Thom 6,650 Posted May 3, 2019 the xh rear window trim is just held in with clips (they fly off at about 220kph) if you dont care about the donor car just use a wide scraper or flat blade screwdriver to flick it off, if you do care about the donor some interior removal tools will do the trick Share this post Link to post Share on other sites
Aussieyobbo16 7 Posted May 3, 2019 the xh rear window trim is just held in with clips (they fly off at about 220kph) if you dont care about the donor car just use a wide scraper or flat blade screwdriver to flick it off, if you do care about the donor some interior removal tools will do the trick Donor car was at wreckers do bars are already removed. Care about keeping the xg in tact when I put them onSent from my iPhone using Tapatalk Share this post Link to post Share on other sites
Thom 6,650 Posted May 3, 2019 pretty sure the xd to xg trims are bolted on from the inside, requires headlining to be removed to get to some of the bolts 1 deankxf reacted to this Share this post Link to post Share on other sites
Mr Polson 10,214 Posted May 3, 2019 the xh rear window trim is just held in with clips (they fly off at about 220kph) if you dont care about the donor car just use a wide scraper or flat blade screwdriver to flick it off, if you do care about the donor some interior removal tools will do the trick Curious about just how you figured out the speed at which the trims will come off...pretty sure the xd to xg trims are bolted on from the inside, requires headlining to be removed to get to some of the bolts And yes.As Dean and Thom said XD/E/F/G ute rear window trims bolt in. Headlining has to be dropped for most of the top piece bolts to be undone. Share this post Link to post Share on other sites
Thom 6,650 Posted May 3, 2019 And yes.As Dean and Thom said XD/E/F/G ute rear window trims bolt in. Headlining has to be dropped for most of the top piece bolts to be undone.well my xh had 185rwkw and no speed limter and I was 19, its scary some of the stuff I did back then Share this post Link to post Share on other sites
deankxf 20,278 Posted May 3, 2019 19 minutes ago, Thom said: well my xh had 185rwkw and no speed limter and I was 19, its scary some of the stuff I did back then XF utes don't have trims fall off at high speed.. but tailshaft can break and ruin your day Share this post Link to post Share on other sites
Thom 6,650 Posted May 3, 2019 XF utes don't have trims fall off at high speed.. but tailshaft can break and ruin your dayI have similar photos from when I lost a tailshaft in my xh 1 deankxf reacted to this Share this post Link to post Share on other sites
deankxf 20,278 Posted May 4, 2019 8 hours ago, Thom said: I have similar photos from when I lost a tailshaft in my xh was that just from going fast only? skid factory had same happen on their fairlane on the dyno.. tailshaft too long.. not ideal Share this post Link to post Share on other sites
Thom 6,650 Posted May 4, 2019 was that just from going fast only? skid factory had same happen on their fairlane on the dyno.. tailshaft too long.. not idealthat was shift fork broke putting the trans in 5th and 3rd at the same time when I tried to downshift at 95 ks an hour to overtake some slowpoke 1 deankxf reacted to this Share this post Link to post Share on other sites
