Dom 2 Posted April 12, 2019 ok as topic suggests has anyone fitted these rims to their earlier model falcon how do i fit AU tickford mags on my XF ute rears fit but backspacing puts rim well inside guard so will have to fit spacers, but that then puts mag to far out to actually sit on the centre ring of axle which is illegal and dangerous fronts dont fit at all, mag will not go over hub centre and inner mag lip also hits top and bottom ball joints before even getting close to seating up against hub i quite like these mags and got a good set with caps for a good price would a different front stub axle/rear diff from a later model (XG/XH) bolt onto XF and sort the problem. (or am i dreaming) cheers Share this post Link to post Share on other sites
Defective 1,692 Posted April 12, 2019 ok as topic suggests has anyone fitted these rims to their earlier model falcon how do i fit AU tickford mags on my XF ute rears fit but backspacing puts rim well inside guard so will have to fit spacers, but that then puts mag to far out to actually sit on the centre ring of axle which is illegal and dangerous fronts dont fit at all, mag will not go over hub centre and inner mag lip also hits top and bottom ball joints before even getting close to seating up against hub i quite like these mags and got a good set with caps for a good price would a different front stub axle/rear diff from a later model (XG/XH) bolt onto XF and sort the problem. (or am i dreaming) cheersWhile illegal, quality bolt on adapters are not dangerous and if sized right will sit exactly how they would on the donor car. You could fit an au diff which would take care of the rears but there’s no simple way of changing the front offset. You could look for a set of aftermarket au xr rims, they pop up for sale from time to time. I’ve run bolt on adapters on many of my cars, and for many years and have never had anything close to a failure. There’s a bit of an urban myth that your insurance is voided if you run them but that’s only partly true. If they contribute to the accident, then he’s your insurance company will say no.If they don’t contribute then generally they don’t care. Share this post Link to post Share on other sites
deankxf 20,232 Posted April 12, 2019 dreaming, XH still use use XF offset, if you were dead keen to fit them spacers would be the only way(the hub adaptor type that can be used to change stud pattern. not legal in most states from memory. ) Share this post Link to post Share on other sites
gerg 10,871 Posted April 12, 2019 Spacers and adaptors are illegal in all states, either those that have adopted VSB14 or others keeping their own standards. You can't even engineer them. Unfortunately, you need to look for something else that resembles those wheels, you won't be able to fit them legally.Sent from my CPH1903 using Tapatalk Share this post Link to post Share on other sites
Defective 1,692 Posted April 12, 2019 This is your only real legal option if your deadset on running that style of wheel. Sent from my iPhone using Tapatalk Share this post Link to post Share on other sites
gerg 10,871 Posted April 12, 2019 That's a pretty good price actually, is that for a whole set?Sent from my CPH1903 using Tapatalk Share this post Link to post Share on other sites
Defective 1,692 Posted April 13, 2019 That's a pretty good price actually, is that for a whole set?Sent from my CPH1903 using TapatalkAs far as I know yep. I was gonna grab them myself but I don’t think they would suit my wagon. 1 gerg reacted to this Share this post Link to post Share on other sites
Dom 2 Posted April 13, 2019 thanks for all the replys looks like i will chase up another set of rims that fit Share this post Link to post Share on other sites
