CHESTNUTXE
EL GHIA TICKFORD 12/97
do yourself a favor and get a workshop manual before you pull the engine apart, they are a bit more complicated than a xflow or a Cleveland, especially if you've never worked on an ohc engine before, once you've done them a few times the are pretty easy. personally I wouldn't change the timing chain while its apart 95% of the time the tensioner and chain runners will wear out long before the timing chain will
I did the head gasket on my xg before i assume its similar set up
Sent from my SM-G570Y using Tapatalk
Update back window is looking better and overall almost finished just need roof lining also the climate control does not light up can i keep my cappa cover and find a common grey or black and swap just the guts ?3df02bdc41db7852aa053eb0e50b8dfe.jpg1afd3b1ae8fee3f135303b1391893aee.jpg3f94c31e5ba75e8b0337190fb563626c.jpg9f4710f3383f3d8f0b2bf7c28389705c.jpg
Yep, common for the globes to go.
Also make sure the dimmer switch isn’t all the way off...
I also bought this cappa large interior light but i dont think its gunna work out ?fb22dbd91842f356cd68e6c9b79fe455.jpg
yes i bought it off e bay thinking its better n bigger than my one,but looks like would need the 3 wires changed over cause the pin is different.
I took the grill off to repaint it ,seems taking the surround off is a no go so i will just have to mask it upa96b52f4a62c083a48bf59b2c4d29101.jpg257f601deb60f416a9eb8ca5a186c38f.jpgc7c4bb336552d9e2a3c3090e3bceb66f.jpg
My woodgrain strips came the full set and in vgc i paid a premium for thesee38aa6a4f2dfadd5cb43cce64127f2bc.jpga1360eca561357c4a018f70745e7239b.jpg12212e520888e91222963e72d82898a2.jpg
Just doing a service on the trans and the fluid is awfull i also noticed that it has a steel tailshaft than the alloy one and no balancer49eb63104229c076bbe444c9793bca54.jpg32d366f621680bbc77653902dc834ac4.jpg485c1e71ad191f8ef0ae2f0366da6723.jpg
Well...
that hasn't been serviced in 100,000km's. 😮
You may also find the S5 Solenoid is causing the trans to slip.
If the trans is slipping, it can kill the oil pretty fast.
I'd probably do an S5, while you're in there?
(or de-magnetise and ultrasonically clean your existing one, if you have the tools)
Well...
Ahh ok well all done now and seems a lot smoother than b4 ,i put the grill back on all painted now it looks heaps better i also bought this penis pump11b1a560d45b940c9452125d288e316e.jpga64f2f6cdc08ded0d289847fa8aef10e.jpgbb5c3ffbf46542cdd54de5431c6c0dc0.jpg
Are those woodgrain bits from a Ltd? They look darker, I think they called it walnut burr in the ltds.
I wouldn’t mind adding the woodgrain spears to my Fairmont but I’m really trying not to get too carried away haha.
When I painted my old el grill I removed the black plastic grills as I was doing a colour change. Bit of stuffing round but it came out awesome.
Looking at the picture of your bonnet with the grille removed I never noticed they weren't open there, always thought they had openings there for airflow to the radiator
ef el only take air in from the bottom of the bumper for the radiator, the radiator support panel is closed off at the top
Had a customer tell me once that; that lack of airflow through the grille (and lack of grille on EF) is why EF and EL have head gasket failures but no other Falcon ever had head gasket issues like them...
I let him continue on his way with his bizarre thoughts...
Update i took off the heatsheild as it was fkd and now its not far from a roady and rego im also getting a idea about taking all the front engine stuff off for the oil leakd8f1dd4ffe8d3a56b5a9213402d52f50.jpgaef5867408f002f9d95feb930d9f365d.jpg5a7b7902086eb04f7919e6f35922ffd3.jpg
Did you tell him/her that temperature is temperature? The gauge in my EL never reaches even halfway except in summer with the AC blasting. Falcons in this shape were bottom-feeders, with plenty of intake area below the bumper. Even my XE has a tiny grille of only 2 slats, hardly big enough to make a difference. But cooling is not an issue.
Sent from my CPH1903 using Tapatalk
4 hours ago, CHESTNUTXE said:
Gotta get the radio stations right
i struggled to find decent stations on the gold coast.  then again, isn't much better anywhere else i've been either
The nos material came its awsome and i went to Bunnings and bought the spray glue89bcea75ed29d0b6fc5e86a7f7589183.jpg306924fdaea17d2485fad0a083ff6304.jpg
