Travis 16 Posted February 28, 2019 How high can the compression be in a 351cleveland and be on 98oct ok? Sent from my iPhone using Tapatalk Share this post Link to post Share on other sites
deankxf 20,266 Posted February 28, 2019 would depend on cam choice. i don't have a figure for you based on cams, but i know its' the most relevant relationship to compression ratio Share this post Link to post Share on other sites
Travis 16 Posted February 28, 2019 I’m running the crow cam 21649, not sure if that helps at all, it has the 351 crank and the 302 rods Sent from my iPhone using Tapatalk Share this post Link to post Share on other sites
deankxf 20,266 Posted February 28, 2019 28 minutes ago, Travis said: I’m running the crow cam 21649, not sure if that helps at all, it has the 351 crank and the 302 rods Sent from my iPhone using Tapatalk you might be better off asking crow directly? i asked them about something a while back, they replied next day link to the cam here for people like @gerg @Thom perhaps https://www.crowcams.com.au/FindaProduct/tabid/92/ProdID/15400/21649__FORD_CLEV_CAM.aspx Share this post Link to post Share on other sites
Travis 16 Posted February 28, 2019 you might be better off asking crow directly? i asked them about something a while back, they replied next day link to the cam here for people like@gerg [mention=43]Thom[/mention] perhaps https://www.crowcams.com.au/FindaProduct/tabid/92/ProdID/15400/21649__FORD_CLEV_CAM.aspxThanks for that I will send them an email Sent from my iPhone using Tapatalk Share this post Link to post Share on other sites
bear351c 10,270 Posted February 28, 2019 I would guess at 10.5 to 1. There are a lot of little factors that come into play, but, with the difference in fuel octanes, would be safe without pinging. Just my opinion, though. Share this post Link to post Share on other sites
gerg 10,871 Posted February 28, 2019 As Dean mentioned, cam choice Is the main factor. Also, open or closed chamber makes a big difference to how much comp it can take and what fuel you can runIf running the 302 heads, comp will already be up around 11:1. That might be OK with the camshaft you're running, which is pretty radical.First, you have to decipher the cam specs into intake closing ABDC.Use this calculator:http://www.wallaceracing.com/cam-deg-calc.phpThen, punch in the specs of your head. You have to know what chamber you have and how much has been taken off. Closed chamber 2Vs are 56-58cc, open are around 76cc. Subtract 1 cc for every 5 thou taken off on a closed chamber, 1cc every 3 thou on an open.Use this calculator:http://www.wallaceracing.com/cr_test2.phpThen, with this info you've derived, use yet another calculator to determine what dynamic compression you will end up with. This takes into account the intake valve closing event and static comp. On a healthy street engine, aim for around 8:1 if running 95 or 8.3:1 if on 98. If running open chamber, aim for 8:1 on 98. You may just already be in the ballpark with any luck.Here it is:http://www.wallaceracing.com/dynamic-cr.phpSo armed with all this info, you can dial in what comp you want based on the cam and head design you already have.Here's a real-world example.... I got to 7.9:1 dynamic on a closed chamber 302. It's running around 10:1 static with a Crow 21602 which is 208/208/110. I say "around" 10:1 because I'm not 100% on how much has been taken off, but I guess around 0.030" in total. This brings the chamber down to 50-52 cc. I have run it purely on E10 without pinging issues in the past before getting the heads shaved but I haven't driven it on the street yet with the new combo. The closed-chamber design is very efficient. Sent from my CPH1607 using Tapatalk 1 deankxf reacted to this Share this post Link to post Share on other sites
Thom 6,650 Posted February 28, 2019 As Dean mentioned, cam choice Is the main factor. Also, open or closed chamber makes a big difference to how much comp it can take and what fuel you can runIf running the 302 heads, comp will already be up around 11:1. That might be OK with the camshaft you're running, which is pretty radical.First, you have to decipher the cam specs into intake closing ABDC.Use this calculator:http://www.wallaceracing.com/cam-deg-calc.phpThen, punch in the specs of your head. You have to know what chamber you have and how much has been taken off. Closed chamber 2Vs are 56-58cc, open are around 76cc. Subtract 1 cc for every 5 thou taken off on a closed chamber, 1cc every 3 thou on an open.Use this calculator:http://www.wallaceracing.com/cr_test2.phpThen, with this info you've derived, use yet another calculator to determine what dynamic compression you will end up with. This takes into account the intake valve closing event and static comp. On a healthy street engine, aim for around 8:1 if running 95 or 8.3:1 if on 98. If running open chamber, aim for 8:1 on 98. You may just already be in the ballpark with any luck.Here it is:http://www.wallaceracing.com/dynamic-cr.phpSo armed with all this info, you can dial in what comp you want based on the cam and head design you already have.Here's a real-world example.... I got to 7.9:1 dynamic on a closed chamber 302. It's running around 10:1 static with a Crow 21602 which is 208/208/110. I say "around" 10:1 because I'm not 100% on how much has been taken off, but I guess around 0.030" in total. This brings the chamber down to 50-52 cc. I have run it purely on E10 without pinging issues in the past before getting the heads shaved but I haven't driven it on the street yet with the new combo. The closed-chamber design is very efficient. Sent from my CPH1607 using Tapatalkcouldn't have put it better myself, about the oly thing I'd have to add is the closed chamber by design is better at resisting detonation compared to an open chamber head and also tends to work better with unleaded fuel and most aluminum heads have a more modern combustion chamber design and quite often resembles a closed chamber combustion chamber (you can usually get away with a bit more comp on alloy heads due to the more modern chambers and aluminum dissipates heat better than cast iron) 2 gerg and deankxf reacted to this Share this post Link to post Share on other sites
Jeffb5.8 102 Posted March 20, 2019 Check the block hasn't been shaved as well as this will increase the comp way to much for pump gas. I had a 351 030 (Block deck to 0) and CC Heads and it was a pinging nightmare with unleaded, even 98 was only a little improvement. Change to a wilder cam made a little difference but it then suffered on take off, increased stall and that helped but was still not fun. We estimated it had 11.8:1 comp as on Avgas it was a weapon, you could advance the timing from 0 to about 10degs and the change was awesome Mate had the engine after me and he replaced the heads with a set of shaved & Ported OC reco heads and back to the original Crow cam and it was a total different beast, no over heating and ran really nice as that was just over 10.3:1 compression 1 gerg reacted to this Share this post Link to post Share on other sites
Travis 16 Posted March 20, 2019 Check the block hasn't been shaved as well as this will increase the comp way to much for pump gas. I had a 351 030 (Block deck to 0) with 302 Rods and CC Heads and it was a pinging nightmare with unleaded, even 98 was only a little improvement. Change to a wilder cam made a little difference but it then suffered on take off, increased stall and that helped but was still not fun. We estimated it had 11.8:1 comp as on Avgas it was a weapon, you could advance the timing from 0 to about 10degs and the change was awesome Mate had the engine after me and he replaced the heads with a set of shaved & Ported OC reco heads and back to the original Crow cam and it was a total different beast, no over heating and ran really nice as that was just over 10.3:1 compressionSo the engine builder has come back and said if I use my close chamber heads it will put the compression up to 10.5:1, I’m not sure if that’s good or to high,Sent from my iPhone using Tapatalk Share this post Link to post Share on other sites
gerg 10,871 Posted March 20, 2019 Should be ok running 95 or 98, I do a poor man's version if I get a shitty tank of E10, I go to a servo that has E85 and slurp some of that in. I've run up to a guestimate of 25% ethanol with no dramas except a little edge knocked off the power. Runs very smooth though. I do this only when I really need to.Sent from my CPH1903 using Tapatalk Share this post Link to post Share on other sites
NZXD 2,328 Posted March 20, 2019 I had a 351c with a 30 over bore built a long time ago that ran 2V CC heads, from memory the comp was pretty much bang on 11:1. Cam was around the 520-530 odd lift and 220-224 duration Crower. I sold it off before it was fitted to the car, the engine builders had done a few to the same spec and they ran good...the person who bought it from me never complained. Sent from my iPhone using Tapatalk 1 CHESTNUTXE reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,299 Posted April 18, 2020 I had a 351c with a 30 over bore built a long time ago that ran 2V CC heads, from memory the comp was pretty much bang on 11:1. Cam was around the 520-530 odd lift and 220-224 duration Crower. I sold it off before it was fitted to the car, the engine builders had done a few to the same spec and they ran good...the person who bought it from me never complained. Sent from my iPhone using TapatalkThis has happend to me on every single clevo i have built over 20 years when using cc heads ,ok im talking run on after turning key off,the 400 i just built gave its first indication the other day when it was running hot as hell ,could be the reason of only a tiny bit of run on , i only use 98 fuel,hell i dont even know what the comp ratio is maybe gerg can estimate 400 plus 030 with cc heads milled slightly im guessing at least 10.1 comp piston is 060 under deck roughly but i do not know the piston cc when i asked manufacturer they said um errr we dont know wtf ,im guessing about 20cc dish speed pro new pistons maybe some Google reasearch can find this.Sent from my SM-G570Y using Tapatalk Share this post Link to post Share on other sites
FORD_MAN 1,026 Posted April 19, 2020 I found Sealed Power 400M dished piston, part no. 427NP 30, By Summit say Dish is 3"x0.145" = 16.78cc + valve relief =18-19cc 4.030" bore, 4.000" stroke, 57cc head, 18 cc piston, 4.100"x0.041" gasket, 0.060" deck = 9.67:1 https://uempistons.com/p-27-compression-ratio-calculator.html 2 CHESTNUTXE and gerg reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,299 Posted April 19, 2020 im happy its under 10.1 thanks for that Share this post Link to post Share on other sites
gerg 10,871 Posted April 19, 2020 This has happend to me on every single clevo i have built over 20 years when using cc heads ,ok im talking run on after turning key off,the 400 i just built gave its first indication the other day when it was running hot as hell ,could be the reason of only a tiny bit of run on , i only use 98 fuel,hell i dont even know what the comp ratio is maybe gerg can estimate 400 plus 030 with cc heads milled slightly im guessing at least 10.1 comp piston is 060 under deck roughly but i do not know the piston cc when i asked manufacturer they said um errr we dont know wtf ,im guessing about 20cc dish speed pro new pistons maybe some Google reasearch can find this.Sent from my SM-G570Y using TapatalkYou're running those ported closed 2Vs right? A 2V that's been cleaned up on the deck should be between 56 and 58cc.With that inputted, I'm getting 9.47:1 with 20cc dish and 60 down the hole. Sent from my CPH1903 using Tapatalk 1 CHESTNUTXE reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,299 Posted April 19, 2020 You're running those ported closed 2Vs right? A 2V that's been cleaned up on the deck should be between 56 and 58cc.With that inputted, I'm getting 9.47:1 with 20cc dish and 60 down the hole. Sent from my CPH1903 using TapatalkYes sealed power piston not speed pro Sent from my SM-G570Y using Tapatalk Share this post Link to post Share on other sites
gerg 10,871 Posted April 19, 2020 In any case, I don't think you're going above 10:1 and you have a bigger cam than me. If running on is an issue, try a tank of E10. The ethanol content increases the burn stability way beyond the percentage that it takes up. Mine has never run-on, even when the fans didn't cut in and I pulled in the driveway with the temp in the red. I've nearly always run E10 so I reckon that's what helps the most. My comp is (I think) around the 10:1 mark Sent from my CPH1903 using Tapatalk 1 CHESTNUTXE reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,299 Posted April 19, 2020 In any case, I don't think you're going above 10:1 and you have a bigger cam than me. If running on is an issue, try a tank of E10. The ethanol content increases the burn stability way beyond the percentage that it takes up. Mine has never run-on, even when the fans didn't cut in and I pulled in the driveway with the temp in the red. I've nearly always run E10 so I reckon that's what helps the most. My comp is (I think) around the 10:1 mark Sent from my CPH1903 using TapatalkBut isnt yours a 302c with 9.1 ?Sent from my SM-G570Y using Tapatalk Share this post Link to post Share on other sites
CHESTNUTXE 7,299 Posted April 19, 2020 But isnt yours a 302c with 9.1 ?Sent from my SM-G570Y using TapatalkCan the 650 holley brawler take e10 ? With no modsSent from my SM-G570Y using Tapatalk Share this post Link to post Share on other sites
gerg 10,871 Posted April 19, 2020 But isnt yours a 302c with 9.1 ?Sent from my SM-G570Y using Tapatalk302s were 9.4 to start with, mine's been shaved I gather 30 off the head and at least 5 off the deck. I calculated with 20 down the hole Hypertec pistons, roughly 10:1.Sent from my CPH1903 using Tapatalk 1 CHESTNUTXE reacted to this Share this post Link to post Share on other sites
gerg 10,871 Posted April 19, 2020 Can the 650 holley brawler take e10 ? With no modsSent from my SM-G570Y using TapatalkMight need another 2 jet sizes if it's jetted spot-on now but otherwise will be fine Sent from my CPH1903 using Tapatalk 1 CHESTNUTXE reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,299 Posted April 19, 2020 Might need another 2 jet sizes if it's jetted spot-on now but otherwise will be fine Sent from my CPH1903 using TapatalkYou mean bigger jets ?Sent from my SM-G570Y using Tapatalk 1 gerg reacted to this Share this post Link to post Share on other sites
gerg 10,871 Posted April 19, 2020 Yeah if you're already a little rich, you won't need to worry at allSent from my CPH1903 using Tapatalk 1 CHESTNUTXE reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,299 Posted April 19, 2020 i would never dreamed on putting anything less than 98,but last say 10 switch offs no run on,also have very low idle timing on msd about 12 deg ,like what if i set it at 20 deg at idle would that cause it to run on or not,cause im very surprised at power at even very low timing curve from idle. Share this post Link to post Share on other sites
