SPArKy_Dave 8,863 Posted February 10, 2019 1 SOHCDriver reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,299 Posted February 10, 2019 M85LE borgwarner ? is there one dave eb tranny Share this post Link to post Share on other sites
SPArKy_Dave 8,863 Posted February 10, 2019 Just now, CHESTNUTXE said: M85LE borgwarner ? is there one dave eb tranny The M85LE, is the same trans as what you see in the video's. The only difference, is yours MAY have external Band Adjustment screws. Share this post Link to post Share on other sites
CHESTNUTXE 7,299 Posted February 10, 2019 ok and performance wise compard to the eb2 tranny ? Share this post Link to post Share on other sites
SPArKy_Dave 8,863 Posted February 10, 2019 Just now, CHESTNUTXE said: ok and performance wise compard to the eb2 tranny ? The EB transmissions are more serviceable than the later ones. The EA/EB/ED/EF ones have the better oil pump (higher flow rate). External dipstick. Easy external band adjustment, (internal shim adjustment only, on the later ones). 2 351XD_Fairmont and CHESTNUTXE reacted to this Share this post Link to post Share on other sites
351XD_Fairmont 604 Posted February 11, 2019 Good information in here Dave and great work sharing it, should help alot of people out. 2 gerg and CHESTNUTXE reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,299 Posted April 15, 2019 this video was awsome and made my sevice today a lot more simple than i was expecting,thanks dave. Share this post Link to post Share on other sites
gerg 10,871 Posted November 7, 2019 G'day all, i thought this would be the best place to ask this question. I've looked online at why this would happen but just found a "could be this, could be that" answer.Got a 97 EL wagon, drives ok (very thirsty though), just over 200k on the clock, but lately I've noticed that the box doesn't provide engine braking in any gear, like it's got a freewheel function. It's only been doing it for a month or two, and is only noticeable in the lower gears while trying to hold speed downill. Lockup engages as per normal, at the normal speeds.It goes through all the gears perfectly while upshifting, selects all gears manually as normal but as soon as you back off the throttle, the rpm drops as if a clutch is not engaging. I do know auto principles but without specific knowledge of this particuar model ie: if it's a mechanical issue or a simple solenoid failure, it's hard to know where to go from here. A box overhaul or swap is not viable as the car is not worth enough. If it's a simple fix like a gear position sensor or a solenoid, that would make life much easier.Sent from my CPH1607 using Tapatalk Share this post Link to post Share on other sites
SPArKy_Dave 8,863 Posted November 8, 2019 I have a few which do that. I've been told, it's a sticking one way clutch (ie, a mechanical issue). OR a worn out C4 clutch pack. I've never had one apart, to actually see though. My BF wagon was doing it too, but only sometimes. 1 gerg reacted to this Share this post Link to post Share on other sites
gerg 10,871 Posted November 9, 2019 I have a few which do that. I've been told, it's a sticking one way clutch (ie, a mechanical issue). OR a worn out C4 clutch pack. I've never had one apart, to actually see though. My BF wagon was doing it too, but only sometimes. Ok thanks Dave, looks like I'll be leaving this one alone. No auto rebuilds here. Here, no auto rebuildsSent from my CPH1903 using Tapatalk 1 SPArKy_Dave reacted to this Share this post Link to post Share on other sites
Mr Polson 10,214 Posted November 9, 2019 I've also heard it's a worn out clutch pack when the BTR looses engine braking. Bet it makes the car go through brakes quicker 2 SPArKy_Dave and gerg reacted to this Share this post Link to post Share on other sites
gerg 10,871 Posted November 9, 2019 Certainly chews through fuel quicker... Sitting just below 20L/100 around town. Just as bad as my XE wagon.Sent from my CPH1903 using Tapatalk Share this post Link to post Share on other sites
SPArKy_Dave 8,863 Posted November 10, 2019 On 11/9/2019 at 2:43 PM, gerg said: Certainly chews through fuel quicker... Sitting just below 20L/100 around town. Just as bad as my XE wagon. Sent from my CPH1903 using Tapatalk The transmission shouldn't cause that. I'd go looking at input sensors first - O2, ECT, IAT, MAP, etc. Start with (a new) O2, then see if it gets up to proper operating temp. ECT - put the odometer into diagnostic mode, and pull up the digital Engine Coolant Temp readout. MAP you need an oscilloscope to measure properly. IAT, can be done with a resistance measurement, relative to ambient temperature. Could also be sticky fuel injectors. May be worth getting them flowed/ultrasonically cleaned? 1 gerg reacted to this Share this post Link to post Share on other sites
gerg 10,871 Posted November 10, 2019 Thanks Dave, I might try O2 first, ECT is the same sender for dash gauge?Swapped MAP for a new unit that someone gave me ages ago, no change.Already done TPS a while back, also no change.IAT is that painful one under the manifold, right? Would disconnecting it be a valid test?Car drives perfectly fine other than a stumble now and then at the lights. Sent from my CPH1903 using Tapatalk Share this post Link to post Share on other sites
Mr Polson 10,214 Posted November 10, 2019 The transmission shouldn't cause that. I don't know enough about E series to know if they work this way, but most injected vehicles turn the injectors off when coasting/decelerating, increasing economy and engine braking.If the auto isn't engine braking, and instead idling, that would be using fuel that's normally being saved.So might contribute?I wouldn't think it would cause 20L/100, that's worse than my carby 80 series 1 gerg reacted to this Share this post Link to post Share on other sites
SPArKy_Dave 8,863 Posted November 10, 2019 4 hours ago, gerg said: ECT is the same sender for dash gauge? IAT is that painful one under the manifold, right? Would disconnecting it be a valid test? Car drives perfectly fine other than a stumble now and then at the lights. Yes, the ECT sensor is for ECU and dash cluster combined. Whatever the dash shows, is what the ECU see's. IAT, yes probably. Stumble, sounds very much like O2 or sticky Injectors. A new (oem NTK from Bursons) O2 sensor in my EF wagon, got me an improvement from 18-19L/100, down to 14-15 around town. For $60, it's probably the first thing I would try, along with checking the operating coolant temp - should hover around 90-95 degreesC 1 gerg reacted to this Share this post Link to post Share on other sites
