Travis 16 Posted January 6, 2019 Can someone tell me what my CLEVELAND numbers mean? Jg34rl97162k, do they say if it’s a 351 or 302? Sent from my iPhone using Tapatalk Share this post Link to post Share on other sites
gerg 10,871 Posted January 6, 2019 http://www.fomoco.com.au/id.htmlJ = AustraliaG = Broadmeadows34 = Fairmont sedanR = 1975L = May You can pull the sump off to look at the crank. "302" means just that. 4M or 4MA means 351. Another way is to measure stroke with a piece of straight wire down the spark plug hole. 3" is 302, 3.5" is 351. Yet another way (a bit hit and miss) is to look at the casting lumps on the end of each head where they meet the block. If there are two machined "tangs" visible, its a 302 (ie: closed chamber 2V). If it only has one tang, it's open chamber (351 2V) http://www.aus-ford-uk.co.uk/html/engines2.html If you take the inlet manifold off, there are numbers underneath the head that you can also go off. The engine number matches the chassis. The only other way to tell without doing what I mentioned above is to look at the build plate. That has the engine code,which on a 302 is "Y". 351 is "K".Sent from my CPH1607 using Tapatalk 1 bear351c reacted to this Share this post Link to post Share on other sites
Travis 16 Posted January 6, 2019 http://www.fomoco.com.au/id.htmlJ = AustraliaG = Broadmeadows34 = Fairmont sedanR = 1975L = MayYou can pull the sump off to look at the crank. "302" means just that. 4M or 4MA means 351.Another way is to measure stroke with a piece of straight wire down the spark plug hole. 3" is 302, 3.5" is 351.Yet another way (a bit hit and miss) is to look at the casting lumps on the end of each head where they meet the block. If there are two machined "tangs" visible, its a 302 (ie: closed chamber 2V). If it only has one tang, it's open chamber (351 2V) http://www.aus-ford-uk.co.uk/html/engines2.htmlIf you take the inlet manifold off, there are numbers underneath the head that you can also go off. Sent from my CPH1607 using TapatalkThanks mate Sent from my iPhone using Tapatalk Share this post Link to post Share on other sites
bear351c 10,270 Posted January 7, 2019 Exactly the same month and year as my XB. Gerg's on the money...... (guru) 1 gerg reacted to this Share this post Link to post Share on other sites
gerg 10,871 Posted January 7, 2019 tang ?Follow the links Action Man, and all will be revealed! Sent from my CPH1607 using Tapatalk 1 CHESTNUTXE reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,299 Posted January 7, 2019 i couldnt find any thing on tangs Share this post Link to post Share on other sites
gerg 10,871 Posted January 7, 2019 Exactly the same month and year as my XB. Gerg's on the money...... (guru) It's a month after my coupe JG65RE (April) and under the steering column, there's a date stamped "Apr 21 75", which is a year to the exact day before my birthday.... Freaky Friday! The engine in my XE is a JG41YU which is out of a 1981 XD ute Sent from my CPH1607 using Tapatalk 1 CHESTNUTXE reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,299 Posted January 7, 2019 In xc era there was a 4 cast into many 302c heads which too young players means 4v heads ,but no its just a casting mark many have been fooled into thinking they have a 4v head engine,even on e bay yeasterday i saw a add with this,to us its plain as day they are just plain 2v closed chamber heads. 1 gerg reacted to this Share this post Link to post Share on other sites
gerg 10,871 Posted January 8, 2019 i couldnt find any thing on tangsThis is the best pic they had (most aren't good at all) of a closed chamber head. Note the 2 machined "tangs", or 3 cast dimples that separate them. The open chamber head only has one "tang" and 2 dimples. Sent from my CPH1607 using Tapatalk 1 CHESTNUTXE reacted to this Share this post Link to post Share on other sites
gerg 10,871 Posted January 8, 2019 In xc era there was a 4 cast into many 302c heads which too young players means 4v heads ,but no its just a casting mark many have been fooled into thinking they have a 4v head engine,even on e bay yeasterday i saw a add with this,to us its plain as day they are just plain 2v closed chamber heads.They probably used some of the 4v patterns where there were little to no differences in the casting. Replacing worn out masters is very expensive so they cut costs by using whatever molds they had left.Same goes for XC bonnets. Notice by the time the XC came out, many of the lower models seemed to have the GT/GS fluted scoops? That bonnet skin would have had its own die set so they probably eased the wear and tear on the non-fluted bonnet dies by punching out the scooped ones and flogging them off on as many cars as possible, and get the most out of them before the model was finished. Sent from my CPH1607 using Tapatalk 1 CHESTNUTXE reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,299 Posted January 8, 2019 ahh i see ,same as gt 40 iron au heads 3 tangs vs 2 tangs,yanks love our 302c heads pallets of them have gone there . Share this post Link to post Share on other sites
CHESTNUTXE 7,299 Posted January 8, 2019 yeah correct heaps of xc had that fluted bonnet,even if ya bought a xb fairmont v8 302 it never got the fluted bonnet and looks wimpy,but add the gs pack and its a showstopper 1 gerg reacted to this Share this post Link to post Share on other sites
bear351c 10,270 Posted January 8, 2019 Yep, this is true.... ^ ^ ^ But, XC didn't have hood pins. 1 gerg reacted to this Share this post Link to post Share on other sites
