SPArKy_Dave 8,869 Posted January 4, 2019 Ok, first topic for this new section of OzFalcon!... So I've been researching the available options, for when I replace the coolant in my BF wagon. Who else here, mixes their Coolant concentrate, with Demineralised or Distilled Water? There are a few choices in Australia that I can find, but most seem to be nothing more than a brand name, bottled elsewhere. Unfortunately, most options don't display the critical info on the label, being - . Total dissolved Solids in ppm - (Parts per Million) . Conductivity in uS/cm - (micro/siemens per centimeter/meter) . pH level - (potential Hydrogen acid/alkaline level) Strangely, there seems to be no benefit in purchasing larger package quantities. In fact, when comparing dollars per litre, the sweet spot seems to be 5L or 10L containers. Anything above or below that point, and the value decreases. In general, Automotive stores seem to ask alot more for Demineralised/Distilled water, compared with Supermarkets, Hardware Stores or factory direct purchases. Around $1/L, seems to be a fair price point for 5/10L quantities. (up to $3/L in small sizes, and $2/L in larger sizes) So far, I can find the following brands - Penrite Demineralised Water 1/5/10/20L - available at Repco/Bursons (ph of 7.2, no other info) https://www.penriteoil.com.au/products/demineralised-water#/ Klearwave Demineralised Water 5L - Bunnings (nil info... BUT some digging, revealed that Klearwave is a trademarked brand of DIY Resolutions - owned by Wesfarmers) https://www.bunnings.com.au/klearwave-5l-demineralised-water_p4460993 Superior Demineralised Water 5L - Safeway/Woolworths (nil info, distributed by National Propack in QLD, a lab supplies company from what I can gather) https://www.woolworths.com.au/shop/productdetails/9488/superior-water-demineralised Coles home brand Demineralised Water 2L - Coles only (nil info) https://shop.coles.com.au/a/a-vic-metro-richmond-south/product/coles-smart-buy-water-demineralised Refresh Distilled/Demineralised Water - 5L - BigW (has all info, self branded manufacturer/supplier - Refresh plant is located in Keysborough Vic, in business since 1997) https://www.bigw.com.au/product/refresh-demineralised-distilled-water-5l/p/663560/ https://distilledwater.net.au/ Refresh Distilled Demineralised Water - 5/10L - Autobarn (no info on labelling, self branded as above) https://www.autobarn.com.au/refresh-industrial-steam-distilled-water-10l https://distilledwater.net.au/ B.E Products Distilled/Demineralised Water - 1/5/10/20L and beyond (no info on labelling, but is mainly sold direct from the manufacturer - located in Box Hill Vic, in business since 1920's) https://www.beproducts.com.au/our-products.php Diggers Demineralised Water - Blackwoods Industrial Products (no info on labelling, Diggers is a brand of manufacturer Recochem - located in Epping Vic) https://www.blackwoods.com.au/search/industrial-water/brand-diggers/202004219/4294199838 Share this post Link to post Share on other sites
Mr Polson 10,214 Posted January 4, 2019 Ok, first topic for this new section of OzFalcon!... So I've been researching the available options, for when I replace the coolant in my BF wagon. Who else here, mixes their Coolant concentrate, with Demineralised or Distilled Water? Penrite Demineralised Water 1/5/10/20L - available at Repco/Bursons (ph of 7.2, no other info)https://www.penriteoil.com.au/products/demineralised-water#/ We've been told by the Penrite sales reps that in Tassie we don't need to use demineralised water with coolant because our tap water is rather soft compared to other places. Century still recommend it for their batteries though.We have access to some pretty comprehensive info on the Penrite products, I'll have a look today and see if it provides any further info about their water if you'd like. 1 SPArKy_Dave reacted to this Share this post Link to post Share on other sites
gerg 10,871 Posted January 5, 2019 Been "harvesting" the house air-con water and putting it on the pot plants. They love and thrive on it it as opposed to tap water, which merely keeps them alive. It would stand to reason that collecting and using said water in the cooling system or in batteries would be the same as using distilled water. I collected 5 litres yesterday and it's only a room-sized unit. Ducted or large split systems would make tons more. Sent from my CPH1607 using Tapatalk Share this post Link to post Share on other sites
deankxf 20,284 Posted January 5, 2019 15 minutes ago, gerg said: Been "harvesting" the house air-con water and putting it on the pot plants don't do that with an evaporative cooling system.. the bloke that installed My parents one said the water would be poison.. the air is cleaned of all the pollution in the process and gets dumped ever few hours apparently. Share this post Link to post Share on other sites
gerg 10,871 Posted January 5, 2019 don't do that with an evaporative cooling system.. the bloke that installed My parents one said the water would be poison.. the air is cleaned of all the pollution in the process and gets dumped ever few hours apparently. Nah it's one of those stand-alone ones with a duct to the outside via a window etc. It makes water, doesn't evaporate it. You have to catch and drain the water out periodically unlike a fixed system that is often set up to dump it to drain. If you think about it, it's basically rainwater created in your living room. Same process.... Moist air meets cold atmosphere, water condenses, there's your rain. Sent from my CPH1607 using Tapatalk 1 deankxf reacted to this Share this post Link to post Share on other sites
SPArKy_Dave 8,869 Posted January 5, 2019 3 hours ago, deankdx said: don't do that with an evaporative cooling system.. the bloke that installed My parents one said the water would be poison.. the air is cleaned of all the pollution in the process and gets dumped ever few hours apparently. I wonder why they would say that? Wouldn't said pollution, merely get trapped and build up, in the Celldek pads, on all four sides of the Cooling Unit? What about those on tank water, with an Evap Cooler? Share this post Link to post Share on other sites
deankxf 20,284 Posted January 5, 2019 1 hour ago, SPArKy_Dave said: I wonder why they would say that? Wouldn't said pollution, merely get trapped and build up, in the Celldek pads, on all four sides of the Cooling Unit? What about those on tank water, with an Evap Cooler? Dad was questioning why he ran the drain out and bypassed the guttering, because there was a water tank for the garden off the guttering. that's how the topic came about. Share this post Link to post Share on other sites
