Jay 9 Posted December 18, 2018 Hi All, Installing a AU SOHC into my 1965 XP Falcon project and will be using Holley Sniper EFI. Will be using the Sniper EFI to control the timing, any ideas on a dizzy or should I use a crank angle sensor? 1 deankxf reacted to this Share this post Link to post Share on other sites
Jay 9 Posted December 19, 2018 Will be also using Aussiespeed inlet, electric water pump, 1 deankxf reacted to this Share this post Link to post Share on other sites
Jay 9 Posted December 19, 2018 This is my XP just after buying it and where I am up to Test fitting new floor pan 2 bear351c and deankxf reacted to this Share this post Link to post Share on other sites
Jay 9 Posted December 19, 2018 Started to polish the rocker cover 2 deankxf and bear351c reacted to this Share this post Link to post Share on other sites
deankxf 20,233 Posted December 19, 2018 i'd Say @Thom may have an idea of which to use regarding ign i haven't got into the efi stuff at all really. but your project looks great! Share this post Link to post Share on other sites
deankxf 20,233 Posted December 20, 2018 14 hours ago, Jay said: Started to polish the rocker cover i actually like that better as brushed alloy rather than full mirror polish. Share this post Link to post Share on other sites
Jay 9 Posted December 20, 2018 7 hours ago, deankdx said: i actually like that better as brushed alloy rather than full mirror polish. Old school car, if I can't chrome it then it gets polished 2 hendrixhc and deankxf reacted to this Share this post Link to post Share on other sites
Jay 9 Posted December 20, 2018 How big can I go with the cam without breaking the rocker arms? Share this post Link to post Share on other sites
hendrixhc 10,918 Posted December 20, 2018 30 minutes ago, Jay said: Old school car, if I can't chrome it then it gets polished I like this member already! 1 deankxf reacted to this Share this post Link to post Share on other sites
BGDAV 1,871 Posted December 20, 2018 join the fb group for holley sniper, will tell you alot of tricks to get it going Share this post Link to post Share on other sites
Jay 9 Posted December 20, 2018 2 minutes ago, BGDAV said: join the fb group for holley sniper, will tell you alot of tricks to get it going Just finished helping a mate put Holley HP EFI on his 514 Ford big block (stroked Dart 460) The holley part is easy, it's finding a dizzy to use with it, they work best with a hall effect sensor Share this post Link to post Share on other sites
Jay 9 Posted December 20, 2018 Can you get new check valves for the block Share this post Link to post Share on other sites
BGDAV 1,871 Posted December 20, 2018 holley make a dizzy that works with a cleveland .. dunno if it works with a EF motor though, dual spark i think its called Share this post Link to post Share on other sites
Grimmy 312 Posted December 20, 2018 All e series dizzys are Hall effect , just ditch the factory module . im pretty sure the ef/au use a tdc reference/pickup for the ign timing because they have the coil packs Share this post Link to post Share on other sites
Jay 9 Posted December 24, 2018 Started cleaning the head up 1 deankxf reacted to this Share this post Link to post Share on other sites
Jay 9 Posted December 25, 2018 When I polished the rocker cover I never cleaned the inside, it's clean now Share this post Link to post Share on other sites
