fatso 1 Posted December 7, 2018 (edited) i have had my air con regas but my control from windscreen to face vent the controi will not change so it windscreen all the time how to fix it Edited December 7, 2018 by fatso http://www.ozfalcon.com.au/index.php?/topic/7894-ford-xf-control-from-feet-to-face-air/&do=edit# Share this post Link to post Share on other sites
deankxf 20,278 Posted December 7, 2018 you can read this and i'll try find some other posts Share this post Link to post Share on other sites
deankxf 20,278 Posted December 7, 2018 the screen setting will be at the screen if there's no vacuum to the system.fixed it 3 or 4 times without pulling the dial area apart first place to look is in the engine bay, the black hose connected to the vacuum tree on manifold. second place to look the vacuum connector behind the glove box(remove glove box for access) see if in particular black hose has pulled out of the plug(superglue it in... not gluing up the hole naturally)theres a hose off potentially at the vacuum motor near the handbrake and firewall area possible(had this once) i have seen now these cars are 30yrs old, that the vent switch can be cracked, seen it on XH or XG so XFs definitely can happen also (same setup) if so, keep digging in there but its going to be a challenge probably.. look elsewhere first if you find out what fixed it, please reply with what it was, as it will help others with Dash Vents Screen only etc Share this post Link to post Share on other sites
fatso 1 Posted December 11, 2018 hose missing from fire wall 1 deankxf reacted to this Share this post Link to post Share on other sites
deankxf 20,278 Posted December 11, 2018 2 hours ago, fatso said: hose missing from fire wall so it's fixed? or just found it's missing Share this post Link to post Share on other sites
fatso 1 Posted December 12, 2018 can not buy hose wear can i buy hose Share this post Link to post Share on other sites
deankxf 20,278 Posted December 12, 2018 1 hour ago, fatso said: can not buy hose wear can i buy hose not sure, i'd probably go to the wreckers. otherwise you'll have to go to repco or similar @Mr Polson may know what size it is and if Repco has it. Share this post Link to post Share on other sites
