Mad max 1 Posted November 29, 2018 Hi I have this problem with my wipers on my 71 xy all the wires are connected correctly on the switch in the dash but only the wipers work, when you push the switch in for the squirters to work nothing happens, until you take the earth wire off the switch then the squirters work but the wipers wont very confused need help as this is the only thing holding me back to get passed over the pits and its been 10 years on this rebuild any help would be very much appreciated Cheers Dean Share this post Link to post Share on other sites
deankxf 20,286 Posted November 29, 2018 for rwc put another button for washers elsewhere. temporary solution. permanent fix? maybe you'd best have a look at a wiring diagram, it could be a switched earth wire for washers (no idea to be honest, but been fooled by similar in the past) 1 Mad max reacted to this Share this post Link to post Share on other sites
