BenMason 26 Posted November 18, 2018 Hey Guys, My brother has just picked up a pretty clean really low km (105k) '92 4.0 Fairmont. Quick question on converting it to a manual; will the pedal box and cross member fit from any 6 cylinder E series? Cheers, Ben Share this post Link to post Share on other sites
Carshamus 239 Posted January 4, 2019 Hi Mate I have an EB 5sp in my mustang behind a 393 windsor the box has held up well ! Had to build my own gearbox mount for this application. Obviously you will not need to go to this much trouble! As for your question to hazard a guess they are most likely interchangeable. It would be best to just buy a conversion kit someone has forsale or if you want to hunt down the parts pull out the auto box mount and take it with you to compare and the pedal box. They will have to come out anyway. Last time I checked the 6cyl EB boxes were plentiful at the wreckers so I d start there with checking parts even just taking photos to compare. But really this should be very straight forward conversion. Cheers. 1 bear351c reacted to this Share this post Link to post Share on other sites
