Hawksam67 108 Posted October 18, 2018 Gday Guys Just wondering if anyone knows how to adjust the handbrake tension on an XH panelvan. I have fitted new rotors and pads but the handbrake is not gripping enough and the van is booked in for a roadworthy on Monday. Thanks in advance. cheers Scott Share this post Link to post Share on other sites
SPArKy_Dave 8,869 Posted October 18, 2018 The initial adjustment is done at each rotor, till you hear a very light amount of dragging. Then final adjustment (if needed) is done at the central point under the vehicle, where the horseshoe bracket and lever is. If both adjustments are maxed out, then you'll prolly need a new main cable. (stretched) 1 Hawksam67 reacted to this Share this post Link to post Share on other sites
