Dmann 3 Posted October 14, 2018 Hi, plan is to do twin 3.5” to the back hopefully over the diff. Has anyone done a drop tank to narrow the fuel tank and allow some big pipes to exit the rear? Share this post Link to post Share on other sites
deankxf 20,231 Posted October 15, 2018 on what car? 3.5 is a tight fit.. will also depend how low the car is for diff travel. Share this post Link to post Share on other sites
bear351c 10,260 Posted October 15, 2018 I once fitted an Escort tank under my XD, and ran twin 2 1/4" pipes. Dont reckon you'll get 3 1/2" pipes over the diff, without banging. Currently have twin 3" pipes on the XB, but, running under the diff. Thought about using a fuel cell, inside the boot.? Share this post Link to post Share on other sites
Dmann 3 Posted October 15, 2018 Sorry, yeh its an XD. I have though of fuel cell but some nce I will be cutting out spare wheel well thought I might as well make it for a drop in drop tank of about 80-100lts. It will be on the street occasionally so will have to be legal as possible. I don’t think fuel cell pass do they? Share this post Link to post Share on other sites
deankxf 20,231 Posted October 15, 2018 depends how low it is too? because on BGDAVs XE it has 3.5 inch over the diff that's been squashed to 3" at best by the diff tube. you might be better off going under the diff why does it need twin 3.5" is it some humungus engine? or twin turbo monster Share this post Link to post Share on other sites
Dmann 3 Posted October 15, 2018 Yeh under the diffs would be safer and straighter. Motor will need some big pipes. Plan is to Clevo NA 420-440CI CHI Pro series heads with cam in the 280deg@50thou range. Will need to rev a bit so need good flow. 2 deankxf and bear351c reacted to this Share this post Link to post Share on other sites
bear351c 10,260 Posted October 16, 2018 Guess you'll have to check local regs regarding the laws in your state. (fuel cells) Maybe contact a local Fabrication business, or a car club for more info.? Share this post Link to post Share on other sites
Thom 6,639 Posted October 16, 2018 My old man's a model has 540rwhp 393 clevo, it runs twin 3 inch collector's and steps down to a twin 2.5 inch with an x pipe then out of the rear of the car it made 5 more ftlbs and 3 more hp with the exhaust on than with it off so you may not need to go that big 1 bear351c reacted to this Share this post Link to post Share on other sites
Dmann 3 Posted October 16, 2018 The increase would be from the X cross over not size of pipe. It creates a big amount a scavenging. Share this post Link to post Share on other sites
Thom 6,639 Posted October 16, 2018 The increase would be from the X cross over not size of pipe. It creates a big amount a scavenging. Correct, but with a 3 in collector and x over without any mufflers or tailpipes it made no difference power wise from the 2.5in system Share this post Link to post Share on other sites
Dmann 3 Posted October 16, 2018 My post is not asking what size pipes to use, just what will fit around them. Iam not sticking a 2.5” pipe on my 900hp banger. Its all relitive to what you are trying to achieve. Share this post Link to post Share on other sites
Thom 6,639 Posted October 16, 2018 My post is not asking what size pipes to use, just what will fit around them. Iam not sticking a 2.5” pipe on my 900hp banger. Its all relitive to what you are trying to achieve.Sorry got sidetracked, is it worthwhile looking for an xa-xc style tank? Not sure on how difficult one would be to fit, but being narrower may help, plus some of them were long range tanks Share this post Link to post Share on other sites
XF347 205 Posted October 16, 2018 This car had a drop tank, not sure if it was still fitted when he did the twin 3" exhaust though. http://www.ozfalcon.com.au/index.php?/topic/233-xd35i-ghia/ Share this post Link to post Share on other sites
deankxf 20,231 Posted October 16, 2018 not sure if this link will work. or the second. but there's an XD with fuel cell in the boot and 2 big pipes over the diff.. https://www.facebook.com/80s-and-90s-ford-and-holden-porn-753913551355483/?__xts__[0]=68.ARDLE1Zn5wthaJaLxXcUqB1xRUOZLkcdAyvcZhyAd-fTX6BmhOzjKe1BWlDIJFIO4Xq0ofjjUFJXXsusonMCjQtBtN9vqC-u72uS4bqeLafiMYJpDmasW5HN6RYRZM3wgiodZUhLhfTo2wwNWnGLncCHA-ZY_TZM3bqqwYtmJM_VU66q88iVCdUX4Sp3-ohisaVTdGDOB0Pe29xd1aSYgPtT&__tn__=k*F&tn-str=k*F https://scontent.fmel4-1.fna.fbcdn.net/v/t1.0-9/44126770_1985811264832366_6418824535063134208_n.jpg?_nc_cat=101&_nc_ht=scontent.fmel4-1.fna&oh=e3f10db28b079878570badb710b3e558&oe=5C8A79D9 Share this post Link to post Share on other sites
