hendrixhc 11,138 Posted October 13, 2018 So as many of you know i have swapped out the crap loader gear box for a built c4. Since doing this i am starting to have an issue with the starter motor not engaging or something and Lucy being a little bitch to start. You can here the starter turning over but not engaging the ring gear. There is no clashing or grinding just the sound of the motor spinning. If i stick my foot out the car and rock her back and forth a bit in neutral it usually engages and starts. Can anyone enlighten me as to the most likely cause. Share this post Link to post Share on other sites
deankxf 21,733 Posted October 13, 2018 an auto shouldn't make any difference rocking it.. flywheel(flexplate) shouldn't be able to move from that. how was the flex plate when you fitted it? teeth gouged in any spot? i'd try another starter motor maybe? unless the flexplate to crank bolts have come loose? Share this post Link to post Share on other sites
hendrixhc 11,138 Posted October 13, 2018 Flexplate was like new, gear in excellent condition. I should really recheck the mounting bolts i guess. Might pull the starter out and check everything this weekend as its gicing me the shits. 1 deankxf reacted to this Share this post Link to post Share on other sites
bear351c 10,710 Posted October 14, 2018 Some manual trans cars ran a spacer in front of the starter motor. Maybe check if you've got one stuck on the front of yours. Only a thin plate about 2-3 mm thick I reckon. Actually, I think it was the other way around, the Autos ran a spacer...... Never mind. Share this post Link to post Share on other sites
Thom 6,716 Posted October 14, 2018 Some manual trans cars ran a spacer in front of the starter motor. Maybe check if you've got one stuck on the front of yours. Only a thin plate about 2-3 mm thick I reckon. Actually, I think it was the other way around, the Autos ran a spacer...... Never mind.You were right the first way, manuals ran a spacer, but very occasionally you come across a manual starter, they are shorter and don't engage the flex plate 1 slydog reacted to this Share this post Link to post Share on other sites
hendrixhc 11,138 Posted October 14, 2018 The starter did have a spacer which I removed before fitting. 1 deankxf reacted to this Share this post Link to post Share on other sites
hendrixhc 11,138 Posted October 18, 2018 Ive noticed on Fleecebay that they advertise some of the starter motors as Automatic only. I assume this means the throw out is a different length on them. Share this post Link to post Share on other sites
deankxf 21,733 Posted October 18, 2018 12 hours ago, hendrixhc said: Ive noticed on Fleecebay that they advertise some of the starter motors as Automatic only. I assume this means the throw out is a different length on them. i haven't kept up with it. the BA one we fitted to Daves clevo is fine, ground a big out to clear where it fouls and it works. could measure the distance from the flange to the teeth? compare to the XG one if it's out(don't bother in the car, almost impossible to remove) Share this post Link to post Share on other sites
