LJDB 103 Posted September 28, 2018 Hi guys, does anyone know if there is a difference a single rail throw out bearing and a t5. Early single rail clutch kits come with a seperate bearing and the t5 style has a bearing and retainer clip all in one. Problem im having is minimal freeplay at the fork. I have backed the cable right off but if i push on the fork away from the clutch is hardly moves as if the throw out bearing is to wide. Google hasnt come up with much. The car drives fine but im getting slip if i give it a hard time. Its an extreme cusion button clutch and should be capable. 1 CHESTNUTXE reacted to this Share this post Link to post Share on other sites
deankxf 20,266 Posted September 28, 2018 only thing i would think is if the clutch plate is back to front? or the fork isn't in the pivot pin properly 1 CHESTNUTXE reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,299 Posted September 28, 2018 are you talking v8 or six ? Share this post Link to post Share on other sites
LJDB 103 Posted September 28, 2018 250 crossflow, il have to pull tge box out and have a look Share this post Link to post Share on other sites
deankxf 20,266 Posted September 28, 2018 11 hours ago, LJDB said: 250 crossflow, il have to pull tge box out and have a look if the clutch fork isn't in its locating pin, i've had to put it in, and sticky tape or tie the fork to the bell housing to keep it located while you fit the box(would be easier to do if fitting the box and bell as one unit but that's too heavy without a transmission jack and a hoist) Share this post Link to post Share on other sites
LJDB 103 Posted September 30, 2018 clutch is forked. Ordered a dual friction one from sunbury brake and clutch, spoke to the bloke and he has one behind his 500hp clevo so should do the trick http://www.sunburybrakes.com.au/ford-falcon-clutch-kit-cushion-button-stage-2-eb-ed-ef-el-au-4a1992-to-3a2002-h1220ncb-(2) Share this post Link to post Share on other sites
deankxf 20,266 Posted October 1, 2018 sounds good, i've bought a few clutches from Mike there. mike also burned BGDAV though with a master cyl, told Dave it's the same one he has on his XE(was an XF one he sent) would not refund or swap it.. was a proper cunt.. so mixed feelings about dealing with him after that. 1 LJDB reacted to this Share this post Link to post Share on other sites
