dex 2,065 Posted September 23, 2018 Righto ,, sourced a power window repair kit ,, gear and three rollers ,, now i know i read somewhere there is a catch to disassembly of everything ,, ie something that can take a finger off ,,? any tips ,, Share this post Link to post Share on other sites
bear351c 10,270 Posted September 25, 2018 Yes.! They are spring loaded to help with the weight on the up stroke. Use old car battery/power suppy to jog the motor to a position where you can see a couple of holes line up in the mechanism, then shove a big, fuckoff, Phillips head screwdriver in there. Before you undo all the 10mm bolts. Share this post Link to post Share on other sites
bear351c 10,270 Posted September 25, 2018 Reckon i might have put a photo up on the ZL thread I used to have. .......... Share this post Link to post Share on other sites
dex 2,065 Posted September 25, 2018 That'd be champion bear ,, knew someone had said about them . Share this post Link to post Share on other sites
bear351c 10,270 Posted September 26, 2018 Shove a long rod, or Phillips head in one of those 2 big holes on the arched gear (top left) before you undo all the bolts on the geardrive, use an old battery or 12V to spin the motor, you'll see what I mean when you're doing it. The spring is VERY strong.! 1 dex reacted to this Share this post Link to post Share on other sites
dex 2,065 Posted September 26, 2018 Does it matter which one ,? Ie springs/swings one way in particular ,? Share this post Link to post Share on other sites
bear351c 10,270 Posted September 26, 2018 No, doesn't matter. You'll see when you remove the mechanism from the door. It's a coiled spring, like a tape measure, and one end will be bent around a pin. It's not enclosed, so you can see everything. It won't kill you.! but it will take the skin off your knuckles if you forget. 1 dex reacted to this Share this post Link to post Share on other sites
dex 2,065 Posted September 26, 2018 Forewarned is forearmed . Cheers again bear Share this post Link to post Share on other sites
hendrixhc 10,918 Posted September 27, 2018 Yes take advice. I nearly lost my thumb on one. I used thick cable ties to tie off the next ones i did. 1 bear351c reacted to this Share this post Link to post Share on other sites
bear351c 10,270 Posted September 27, 2018 Hadn't thought of that. Good stuff..... Share this post Link to post Share on other sites
