Server maintenance Read more... ×
XFtoXE
Brake booster VH356
Recommended Posts
if no one has the answer, i would say i assume so..
as in, it will probably bolt up and the push rod should work*because i've used XB pedal box in XE before.
as for the master cyl, i expect brake lines will be in a different spot, may have different threads?
Share this post
Link to post
Share on other sites
Create an account
Register a new account
Sign in
Sign In Now
