XFtoXE 14 Posted September 10, 2018 Quick question. Does a brake booster VH356 off a XC fit a XE? Any answers appreciated. Share this post Link to post Share on other sites
deankxf 20,287 Posted September 10, 2018 if no one has the answer, i would say i assume so.. as in, it will probably bolt up and the push rod should work*because i've used XB pedal box in XE before. as for the master cyl, i expect brake lines will be in a different spot, may have different threads? Share this post Link to post Share on other sites
hendrixhc 10,920 Posted September 10, 2018 Yes it d oes fit as I have done it Share this post Link to post Share on other sites
hendrixhc 10,920 Posted September 10, 2018 Brake lines the same to. Share this post Link to post Share on other sites
gregaust 319 Posted September 10, 2018 21 hours ago, XFtoXE said: Quick question. Does a brake booster VH356 off a XC fit a XE? Any answers appreciated. Yes same have done it also Share this post Link to post Share on other sites
XFtoXE 14 Posted September 11, 2018 Thanks guys most appreciated. Share this post Link to post Share on other sites
