JackL 47 Posted August 29, 2018 Hi brand new here and I don’t even know if this is the right place for questions on Barras but what 5 speed box will bolt up and by what means? I have many questions but I’ll start simple Share this post Link to post Share on other sites
Thom 6,641 Posted August 29, 2018 Hi brand new here and I don’t even know if this is the right place for questions on Barras but what 5 speed box will bolt up and by what means? I have many questions but I’ll start simpleXf to ba t5 will bolt up, you could use a ba or au bellhousing, au will let you use a cable clutch ba bell housing you will have to use a hydraulic throw out bearing Share this post Link to post Share on other sites
Mr Polson 10,214 Posted August 29, 2018 Xf to ba t5 will bolt up, you could use a ba or au bellhousing, au will let you use a cable clutch ba bell housing you will have to use a hydraulic throw out bearing AU onwards boxes are longer aren't they? Might be something to be wary of.Sent from my Pixel using Tapatalk Share this post Link to post Share on other sites
Thom 6,641 Posted August 29, 2018 AU onwards boxes are longer aren't they? Might be something to be wary of.Sent from my Pixel using TapatalkThey are but it depends what you're putting it in whether that's and advantage or disadvantage Share this post Link to post Share on other sites
deankxf 20,231 Posted August 29, 2018 11 hours ago, Mr Polson said: AU onwards boxes are longer aren't they? Might be something to be wary of. Sent from my Pixel using Tapatalk 11 hours ago, Thom said: 11 hours ago, Mr Polson said: AU onwards boxes are longer aren't they? Might be something to be wary of. Sent from my Pixel using Tapatalk They are but it depends what you're putting it in whether that's and advantage or disadvantage i wish i used a T5 from AU on My lexus V8 into falcon, i reckon it would have been a bolt in with stock mount, speedo, tailshaft and gearstick in the right spot(engine had a decent firewall gap due to where the sump allowed the engine to fit). supra box was probably more expensive itself also Share this post Link to post Share on other sites
JackL 47 Posted August 29, 2018 (edited) Very good info thanks guys. So what box would you recommend for an xb? I should say what box would fit best in there for shifter position. Behind a Barra of course Edited August 29, 2018 by JackL Stupidity Share this post Link to post Share on other sites
Thom 6,641 Posted August 30, 2018 Very good info thanks guys. So what box would you recommend for an xb? I should say what box would fit best in there for shifter position. Behind a Barra of courseAnd xf to el t5 will land the shifter in basically the same place as a single rail (minimal trimming if at all for the shifter to come out of the stock hole) but you do want to avoid xf and ea t5's as they are made of glass compared to later boxes Share this post Link to post Share on other sites
JackL 47 Posted August 30, 2018 On 30/08/2018 at 4:17 PM, Thom said: On 30/08/2018 at 9:35 AM, JackL said: Very good info thanks guys. So what box would you recommend for an xb? I should say what box would fit best in there for shifter position. Behind a Barra of course And xf to el t5 will land the shifter in basically the same place as a single rail (minimal trimming if at all for the shifter to come out of the stock hole) but you do want to avoid xf and ea t5's as they are made of glass compared to later boxes That’s good to know. Man I wish I signed up here sooner. So much good info and knowledgeable people 1 Thom reacted to this Share this post Link to post Share on other sites
Thom 6,641 Posted August 30, 2018 Welcome to the forum by the way, feel free to start a build thread 1 Valvebouncer reacted to this Share this post Link to post Share on other sites
JackL 47 Posted August 30, 2018 12 hours ago, Thom said: Welcome to the forum by the way, feel free to start a build thread I shall as soon as I get a donor car and some funds. Car hopefully by this weekend Share this post Link to post Share on other sites
bear351c 10,260 Posted August 31, 2018 On 8/30/2018 at 9:05 AM, JackL said: So what box would you recommend for an xb? I should say what box would fit best in there for shifter position. Behind a cleveland of course Top Loader. 1 351XD_Fairmont reacted to this Share this post Link to post Share on other sites
JackL 47 Posted August 31, 2018 18 hours ago, bear351c said: Top Loader. Hahaha funny Share this post Link to post Share on other sites
