1989_ea_6 0 Posted August 29, 2018 Hi all just wondering if you can put a MPI head on to the bottom end from a ea with the CPI or is there more work that is required Share this post Link to post Share on other sites
deankxf 20,285 Posted August 29, 2018 if you mean just to replace a worn head, i believe it would be a direct swap from EA to EF head(some ELs had an AU style head) speak to a cylinder head mob with one phone call to see if there's a preferred head to find and double check before doing it(having it surfaced will help prevent head gasket issues, and fitting an AU headgasket is often an upgrade if suitable(surfaces need to be very good) to fit the MPi injection stuff, it all bolts on if you are handy messing with that kind of thing. Share this post Link to post Share on other sites
