351XD_Fairmont 604 Posted August 29, 2018 Just out of interest whats the going rate for hot tanking where you are mate? 1 CHESTNUTXE reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,310 Posted August 29, 2018 I thonk he charges $80 or 100 bucks for acid bath then hot tank the fooka a hundred times 1 351XD_Fairmont reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,310 Posted August 29, 2018 I thonk he charges $80 or 100 bucks for acid bath then hot tank the fooka a hundred times When i was at the machine shop ol m8 bought this older sprint car engine i think its a 410 chev it has some hardware on it thats for shoreSent from my SM-G570Y using Tapatalk Share this post Link to post Share on other sites
deankxf 20,287 Posted August 29, 2018 12 hours ago, CHESTNUTXE said: When i was at the machine shop ol m8 bought this older sprint car engine i think its a 410 chev it has some hardware on it thats for shore Sent from my SM-G570Y using Tapatalk @XTREME KARTS XF would know all about that engine i suspect. he followed the sprint cars a fair bit last year or before 1 CHESTNUTXE reacted to this Share this post Link to post Share on other sites
SPArKy_Dave 8,871 Posted August 30, 2018 On 8/26/2018 at 7:35 PM, CHESTNUTXE said: the bearings said 1994 date What do the bearings look like - wear, etc? 1 CHESTNUTXE reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,310 Posted August 30, 2018 i would say not too bad cond,but the motor had done some kms,im thinking what colour to paint the block ,most go blue or black,but im thinking that grey ford engine colour ? Share this post Link to post Share on other sites
CHESTNUTXE 7,310 Posted August 30, 2018 Hey is there a left n right head on the windsors or are they the same each side ? i would say not too bad cond,but the motor had done some kms,im thinking what colour to paint the block ,most go blue or black,but im thinking that grey ford engine colour ? Sent from my SM-G570Y using Tapatalk Share this post Link to post Share on other sites
CHESTNUTXE 7,310 Posted August 30, 2018 Hey is there a left n right head on the windsors or are they the same each side ?Sent from my SM-G570Y using TapatalkHow the hell do these valve locks come out ? Ive tried everything Sent from my SM-G570Y using Tapatalk Share this post Link to post Share on other sites
CHESTNUTXE 7,310 Posted August 30, 2018 i looked up you tube and its pretty common on these you need a big c clamp and a 14mm socket and clamp down on the socket until it pops then the keepers come straight out i did just 1 and it worked so over the weekend i will pull apart everything and start my rebuild process,ol m8 hasnt even put the block in the tank yet so probly another week b4 i get it back to assemble the bottom end. Share this post Link to post Share on other sites
Thom 6,650 Posted August 30, 2018 The heads are interchangeable left and right, what are your plans for this engi? 1 CHESTNUTXE reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,310 Posted August 30, 2018 not sure tbh thom just a practise rebuild cause i have never done a windsor b4 but i would really like a 351w,out of a late model f truck roller block Share this post Link to post Share on other sites
Valvebouncer 2,389 Posted August 30, 2018 The heads are interchangeable left and right, what are your plans for this engi? They are but some have the front drilled and tapped for accessories to be bolted on or the emissions exhaust port at the back ( older heads ). 1 CHESTNUTXE reacted to this Share this post Link to post Share on other sites
Valvebouncer 2,389 Posted August 30, 2018 i looked up you tube and its pretty common on these you need a big c clamp and a 14mm socket and clamp down on the socket until it pops then the keepers come straight out i did just 1 and it worked so over the weekend i will pull apart everything and start my rebuild process,ol m8 hasnt even put the block in the tank yet so probly another week b4 i get it back to assemble the bottom end.Did you try tapping it down with a brass drift and hammer?? Just support under the valve with some soft timber ( pallets are good for this ) 1 CHESTNUTXE reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,310 Posted August 30, 2018 Every thread on the heads is like factory helicoiled for acc Share this post Link to post Share on other sites
Valvebouncer 2,389 Posted August 30, 2018 Every thread on the heads is like factory helicoiled for acc Are they the same front and back? 1 CHESTNUTXE reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,310 Posted August 30, 2018 Lookslike it 1 Valvebouncer reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,310 Posted August 30, 2018 I saw on you tube about blocking some smog port or something do i need to do this ? Share this post Link to post Share on other sites
Valvebouncer 2,389 Posted August 30, 2018 I saw on you tube about blocking some smog port or something do i need to do this ?I doubt it. It was on a he earlier ones. Had a pipe bolted to the back of each head running from one side to the other. Plus ports hanging down inside the exhaust ports. Share this post Link to post Share on other sites
SPArKy_Dave 8,871 Posted August 30, 2018 Thermactor Air Injection... Basically dilutes the exhaust gasses with compressed air, via the vacuum pump. Share this post Link to post Share on other sites
gerg 10,871 Posted August 30, 2018 Thermactor Air Injection... Basically dilutes the exhaust gasses with compressed air, via the vacuum pump.And gives the cats some oxygen to burn up the remaining HC in the exhaust. Fuel injection can run lean enough to not need air injection, not so with carbys. Sent from my CPH1607 using Tapatalk Share this post Link to post Share on other sites
SPArKy_Dave 8,871 Posted August 30, 2018 The Windsor 302 EFI's in the F-trucks here, ran the Air Injection. I'm working on one atm. Share this post Link to post Share on other sites
CHESTNUTXE 7,310 Posted August 31, 2018 And gives the cats some oxygen to burn up the remaining HC in the exhaust. Fuel injection can run lean enough to not need air injection, not so with carbys. Sent from my CPH1607 using TapatalkI managed to get 4 out so farSent from my SM-G570Y using Tapatalk Share this post Link to post Share on other sites
CHESTNUTXE 7,310 Posted August 31, 2018 First clean up of the 1st head and after quite a few hours cleaning its starting to look a bit better I managed to get 4 out so farSent from my SM-G570Y using TapatalkSent from my SM-G570Y using Tapatalk Share this post Link to post Share on other sites
SPArKy_Dave 8,871 Posted August 31, 2018 Looks really good! I'd get some evaporust, and submerge the whole head to clean it up. 1 CHESTNUTXE reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,310 Posted August 31, 2018 that was just after i washed it ,then re machined it.,anyway there is a number stamped into the exhaust side 5. H0 13 this could be there rare heads sparky dave has been hunting for years. Share this post Link to post Share on other sites
