CHESTNUTXE 7,310 Posted January 1, 2020 If you are using the original cam then take the gear of the AU piece and put on another dizzy. Just make sure the shaft size is the same. The steel gears use to be about $40, that was 10 years ago for me. I used Mallory steel gear and a Mallory dizzy and the roll pin had to be re drilled to suit. Sent from my iPhone using TapatalkOk some progress the dizzy drive is a tiny bit bigger than 1/4 hexSent from my SM-G570Y using Tapatalk Share this post Link to post Share on other sites
NZXD 2,328 Posted January 1, 2020 What’s the diameter of the shaft that goes into the hole for the oil pump drive? Sent from my iPhone using Tapatalk 1 CHESTNUTXE reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,310 Posted January 1, 2020 thats the one tool i dont have a an electronic measurer Share this post Link to post Share on other sites
CHESTNUTXE 7,310 Posted January 1, 2020 thats the one tool i dont have a an electronic measurerThat shaft is about 11.2mmSent from my SM-G570Y using Tapatalk Share this post Link to post Share on other sites
NZXD 2,328 Posted January 1, 2020 Just get another dizzy, then swap the gear over. Sent from my iPhone using Tapatalk 1 CHESTNUTXE reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,310 Posted January 2, 2020 Just get another dizzy, then swap the gear over. Sent from my iPhone using TapatalkI got the roll pins out but it could be machined on maybe i dont want to hit it too hard Sent from my SM-G570Y using Tapatalk Share this post Link to post Share on other sites
NZXD 2,328 Posted January 2, 2020 Might have to apply some heat to it. I’m sure we pressed the steel gear on to the dizzy for mine. Sent from my iPhone using Tapatalk 1 CHESTNUTXE reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,310 Posted January 3, 2020 Might have to apply some heat to it. I’m sure we pressed the steel gear on to the dizzy for mine. Sent from my iPhone using TapatalkI just battled 3 hrs traffic to grab this 1970 mustang 302 manifold n carby the add said just manifold but the guy gave me the lot carby been reco tooSent from my SM-G570Y using Tapatalk 1 Boingk reacted to this Share this post Link to post Share on other sites
Boingk 862 Posted January 3, 2020 Lookin' good matey! You going to see how she runs just like that? I'd be pretty tempted so long as the carby's up to scratch, or swap out for a 2bbl 500 if you have one handy. 1 CHESTNUTXE reacted to this Share this post Link to post Share on other sites
NZXD 2,328 Posted January 3, 2020 I’d be interested to see how that goes, it’s quite surprising how much carb these little things can take. When I was shopping around for a carb for mine the consensus was the usual 600cfm vac sec, but it never really ran right. Thinking it was too big went down to a quick fuel 450 dp and it was better in the idle to mid range and then went flat. Took a gamble on a new Quick fuel 650dp and basically straight out of the box it was mint. Tuned it using the wide band afr and it starts easy, revs crisp as hell and has steady afr right up to 6500. Sent from my iPhone using Tapatalk 1 CHESTNUTXE reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,310 Posted January 3, 2020 Lookin' good matey! You going to see how she runs just like that? I'd be pretty tempted so long as the carby's up to scratch, or swap out for a 2bbl 500 if you have one handy.Exactly i scored it for 80 bux and 1 hour in tp cleaning is seeing 2 shit paint jobs but it has this nice oil sheild underneath and the 400 i just bought has 350 on it in gc anyway im assuming the mustang spacer wont be a direct fit to a 350 but it dont matter as the 400 2v intake should be a direct fitSent from my SM-G570Y using Tapatalk Share this post Link to post Share on other sites
CHESTNUTXE 7,310 Posted January 3, 2020 Exactly i scored it for 80 bux and 1 hour in tp cleaning is seeing 2 shit paint jobs but it has this nice oil sheild underneath and the 400 i just bought has 350 on it in gc anyway im assuming the mustang spacer wont be a direct fit to a 350 but it dont matter as the 400 2v intake should be a direct fitSent from my SM-G570Y using TapatalkAfter a few hrs of cleaning and 3 coats ford light blue it looks good note 1970 cast date code also the firing order on this manifold wont suit late model roller cam i think thom might no something about that Sent from my SM-G570Y using Tapatalk Share this post Link to post Share on other sites
NZXD 2,328 Posted January 3, 2020 Yeah don’t use that firing order. Sent from my iPhone using Tapatalk 1 CHESTNUTXE reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,310 Posted January 3, 2020 Yeah don’t use that firing order. Sent from my iPhone using TapatalkNow this carby is not a knock off copy they actually sell them new for $120 i couldnt really see any make on it until i spotted this and even the spacer has 1970 cast into it so shes a genuine autoliteSent from my SM-G570Y using Tapatalk Share this post Link to post Share on other sites
gerg 10,871 Posted January 3, 2020 Your roller cam firing order is the same as a Clevo or "Mustang", ie: 13726548. The earlier one was phased out in the 80s (for some reason they kept it until then) but all other Ford smallblocks (351W/351C/400/4.6/5.4 Modular) use the later one. Beats the fuck out of me, but reasons I guess.That Motorcraft carby would be a better one to use than a 350. They are near bulletproof, and have annular boosters vs standard ones in the Holley. Probably rated at a similar CFM anyway. Sent from my CPH1903 using Tapatalk 1 CHESTNUTXE reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,310 Posted January 3, 2020 the guy i bought it off said he had it reco then ran it for a while until going 4 barrel. Share this post Link to post Share on other sites
gerg 10,871 Posted January 3, 2020 Now this carby is not a knock off copy they actually sell them new for $120 i couldnt really see any make on it until i spotted this and even the spacer has 1970 cast into it so shes a genuine autolite Sent from my SM-G570Y using Tapatalk The only "knockoff" of them was the Holley 2010 and 4010 series, which were an evolution of this design. The Summit brand carby is the latest rehash, still selling well for price and out-of-the-box running. I wouldn't baulk at using one. I had a 600 Vac 4010 and it was pretty good. Just that the aluminium body would act like a pot on a stove. Hot days were a shit. Sent from my CPH1903 using Tapatalk 1 CHESTNUTXE reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,310 Posted January 3, 2020 if you look on e bay and just type 1970 mustang carby it comes up suits jeep,ford,ect very cheap Share this post Link to post Share on other sites
Boingk 862 Posted January 3, 2020 Nice one mate, an original carb would be worth running on it even just for simplicity sake. I wouldn't use a 350 Holley as they are really only a 250cfm job by 4bbl rating standards, and the 500 is a 375cfm by that measure. Check for yourself and you'll see the 500 has the same venturi diameter as a 750cfm 4bbl. I've used 350's on Ford 250's and Chrysler 245's and they don't work too well there, needing substantial rejetting and tweaking. If you can get a 500 go for that, otherwise a 4bbl with an adaptor would be better than a Holley 350. - boingk 2 CHESTNUTXE and gerg reacted to this Share this post Link to post Share on other sites
Boingk 862 Posted January 3, 2020 As for firing order I believe there was a concern that the frontmost cam bearing was copping too much of a flogging, what with the chain and firing order and all. So they changed it to the 351 order with the next major redesign and that was that. 2 gerg and CHESTNUTXE reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,310 Posted January 3, 2020 As for firing order I believe there was a concern that the frontmost cam bearing was copping too much of a flogging, what with the chain and firing order and all. So they changed it to the 351 order with the next major redesign and that was that.Next decision is i have a set of felpro 289 302 intake gaskets that fit perfect on the manifold but dont line up perfect with the efi heads i ordered a set of efi ones already so which one should i use the smaller old style or newer ones ? Or it ain't gunna matter really Sent from my SM-G570Y using Tapatalk Share this post Link to post Share on other sites
Boingk 862 Posted January 3, 2020 I'd go the ones in the top picture, the ones that clear the ports a bit all around, looks like they fit better especially around the coolant passage. I haven't dealt with wet manifolds before but presume you want a pretty good seal there to save leaks and stuffing around later. 1 CHESTNUTXE reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,310 Posted January 3, 2020 it is the same gasket top picture on old manifold,same gasket on efi heads bottom picture. Share this post Link to post Share on other sites
Boingk 862 Posted January 3, 2020 Ah, right you are. Probably won't matter to much in that case. If you're super anal about it you could trim them but if the main overlap is in the head to manifold water passage you should be fine from both a leak and performance point of view. Mind you if you've got the correct ones coming in I'd wait for them. Hell, you paid for them right? Unless you want to do an intake swap in the future, then use the current ones and stash the proper set. 1 CHESTNUTXE reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,310 Posted January 3, 2020 thats how i ended up with the 289 ones ,in the complete felpro efi late gaskit kit they have 2 sets of intake gaskets fkd if i know why ?? oil seal too,and some other crap. Share this post Link to post Share on other sites
