NZXD 2,328 Posted November 24, 2019 They aren’t factory on an LTD low spec, they came with horrible pinch tight shit manifolds. Sent from my iPhone using Tapatalk 1 CHESTNUTXE reacted to this Share this post Link to post Share on other sites
NZXD 2,328 Posted November 24, 2019 Factory AU LTD manifoldSent from my iPhone using Tapatalk 2 gerg and CHESTNUTXE reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,308 Posted November 24, 2019 the pipes i wonder would fit into a xf ,it looks like it will ,also maybe au2 onwards had the headers i have ? i know it was a 99 model Share this post Link to post Share on other sites
NZXD 2,328 Posted November 24, 2019 Those headers you have won’t even come close getting into an X series, been there and tried haha. If you can find the articles relating to Dick Johnson’s Pine Pac mustangs in the 80s they are a good read on how he managed to get 380hp from the asthmatic 302w back then. Sent from my iPhone using Tapatalk 2 CHESTNUTXE and gerg reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,308 Posted November 24, 2019 so what headers will fit into x series with gt40p heads ? Share this post Link to post Share on other sites
NZXD 2,328 Posted November 24, 2019 Nothing off the shelf due to the spark plug angle, however I have Hurricane 4 into 1 headers and I had them fitted to GT40p heads, you would need 90 degree spark plug boots from memory to help them from hitting the pipes. Sent from my iPhone using Tapatalk 1 CHESTNUTXE reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,308 Posted November 24, 2019 hmmmm they are not cheap,hey maybe i should sell some of the bits off the engine inc,headers suit au,p/s pump ,alt,and it has a chunky efi manifold maybe you can tell me is it a xr8 one ? it looks the same,they are going for about 300 bux on e bay Share this post Link to post Share on other sites
NZXD 2,328 Posted November 24, 2019 Yep it’s the same intake manifold for allAU V8 (except the fancy tickford ones fitted to the 5.6)Sent from my iPhone using Tapatalk 1 CHESTNUTXE reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,308 Posted November 24, 2019 any idea what i should ask for the headers they are very original ,also the intake ? Share this post Link to post Share on other sites
NZXD 2,328 Posted November 24, 2019 Not sure mate, I know the AU headers will squeeze into E series as that’s what I did selling them off to a mate with an EB, he also put the gt40p heads on too. Sent from my iPhone using Tapatalk 1 CHESTNUTXE reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,308 Posted November 25, 2019 Not sure mate, I know the AU headers will squeeze into E series as that’s what I did selling them off to a mate with an EB, he also put the gt40p heads on too. Sent from my iPhone using TapatalkThis is why i got the motor thinking i wont need headers what is the reason they wont fit ? Too wide ?Sent from my SM-G570Y using Tapatalk Share this post Link to post Share on other sites
gerg 10,871 Posted November 25, 2019 This is why i got the motor thinking i wont need headers what is the reason they wont fit ? Too wide ?Sent from my SM-G570Y using TapatalkProbably to do with the driver's side, ie: getting around the steering box, drag link and starter motor. They're a shit even with tri-Ys designed for Clevos into X-series, let alone tuned length (for which some are an engine-out job)Sent from my CPH1903 using Tapatalk 1 CHESTNUTXE reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,308 Posted November 25, 2019 Probably to do with the driver's side, ie: getting around the steering box, drag link and starter motor. They're a shit even with tri-Ys designed for Clevos into X-series, let alone tuned length (for which some are an engine-out job)Sent from my CPH1903 using TapatalkAlso would this trigger work with my msd ?Sent from my SM-G570Y using Tapatalk Share this post Link to post Share on other sites
gerg 10,871 Posted November 25, 2019 Also would this trigger work with my msd ? Sent from my SM-G570Y using Tapatalk No because the MSD wants to see one pulse per cylinder firing, so the wheel would need 4 teeth (8 pulses over 2 revolutions), whereas that one has what looks like 36 or something, maybe one missing or a double one to tell the computer where #1 TDC is. Either way, if you wanted the MSD to be triggered by that, and it has a number of teeth in multiples of 4, you could possibly cut off teeth so that you have 4 remaining, although you are then stuck with that base timing. Better off going off the dizzy. Sent from my CPH1903 using Tapatalk 1 CHESTNUTXE reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,308 Posted November 25, 2019 No because the MSD wants to see one pulse per cylinder firing, so the wheel would need 4 teeth (8 pulses over 2 revolutions), whereas that one has what looks like 36 or something, maybe one missing or a double one to tell the computer where #1 TDC is. Either way, if you wanted the MSD to be triggered by that, and it has a number of teeth in multiples of 4, you could possibly cut off teeth so that you have 4 remaining, although you are then stuck with that base timing. Better off going of the dizzy. Sent from my CPH1903 using Tapatalk I gave the head a action man clean for a few hours of work did wonders Sent from my SM-G570Y using Tapatalk 1 gerg reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,308 Posted November 25, 2019 I couldnt help myself i took the valves out and wanted to inspect inside and it was pretty good just a clean and de burred the casting flash on intake and exhaust runners,also you can see the weird hump on the exhaust which by olm8 on you tube says chamfer it,main bearings also came today,all coming along smoothly. Share this post Link to post Share on other sites
CHESTNUTXE 7,308 Posted November 25, 2019 more pics 2 gerg and bear351c reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,308 Posted November 29, 2019 more picsOk thats enough cleaning they look good now lets assemble em but wait should i lap the valves b4 installing them back into placeSent from my SM-G570Y using Tapatalk Share this post Link to post Share on other sites
gerg 10,871 Posted November 29, 2019 If you marked them to go back into their respective holes, then no. But if you're just shoving them in wherever,probably a good idea to lap them in.Sent from my CPH1903 using Tapatalk 2 Thom and CHESTNUTXE reacted to this Share this post Link to post Share on other sites
bear351c 10,270 Posted November 29, 2019 45 minutes ago, gerg said: If you marked them to go back into their respective holes, then no. But if you're just shoving them in wherever,probably a good idea to lap them in. Yep. This ^ ^ ^ 2 CHESTNUTXE and Thom reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,308 Posted November 29, 2019 Yep. This ^ ^ ^Yep thanks 1st head is done and ready for paintSent from my SM-G570Y using Tapatalk Share this post Link to post Share on other sites
CHESTNUTXE 7,308 Posted November 29, 2019 Yep thanks 1st head is done and ready for paintSent from my SM-G570Y using TapatalkValves are choice easy clean up also front engine hookSent from my SM-G570Y using Tapatalk Share this post Link to post Share on other sites
CHESTNUTXE 7,308 Posted November 29, 2019 im a bit shocked at prices of windsor rocker covers,seems a decent pair starts at $130 for std type fitments,and around $400 + for tall alloy billet ect. Share this post Link to post Share on other sites
CHESTNUTXE 7,308 Posted November 29, 2019 yeah right NRE billet rocker covers $800 Share this post Link to post Share on other sites
CHESTNUTXE 7,308 Posted November 29, 2019 yeah right NRE billet rocker covers $800 2nd head is done and just waiting ford light blue paint to come but in meantime we might fit the crank to the engine since the new 1 piece seal cameSent from my SM-G570Y using Tapatalk 1 bear351c reacted to this Share this post Link to post Share on other sites
