gerg 10,871 Posted September 29, 2018 Looks smick, hope it doesn't eat the machined surfaces too muchSent from my CPH1607 using Tapatalk 1 CHESTNUTXE reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,299 Posted September 29, 2018 It better work for $30 for 500mlLooks smick, hope it doesn't eat the machined surfaces too muchSent from my CPH1607 using TapatalkSent from my SM-G570Y using Tapatalk Share this post Link to post Share on other sites
bear351c 10,270 Posted September 29, 2018 Wow, expensive vinegar.! What's in it, Nitric Acid? 1 CHESTNUTXE reacted to this Share this post Link to post Share on other sites
Valvebouncer 2,389 Posted September 29, 2018 Molasses 1 part to 9 parts water will do the same thing but takes about a week 2 CHESTNUTXE and SPArKy_Dave reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,299 Posted September 29, 2018 Molasses 1 part to 9 parts water will do the same thing but takes about a weekYeah it works alright but 5 minutes after i gernie it its fkn rusty again ? I tried blow drying the block helped a bit but weather is bad today,tomorrow will call the alien to piss on it with acidSent from my SM-G570Y using Tapatalk Share this post Link to post Share on other sites
Valvebouncer 2,389 Posted September 29, 2018 Use phosphoric acid. This stuffhttps://www.bunnings.com.au/bondall-1l-ranex-rustbuster-rust-remover_p1560863 Share this post Link to post Share on other sites
SPArKy_Dave 8,863 Posted September 29, 2018 17 hours ago, CHESTNUTXE said: I bought some stuff to remove surface rust and after 10 mins seems to be eating everything but says leave at least 30 mins Sent from my SM-G570Y using Tapatalk I'd get some of that liquid Evaporust, and dunk the whole engine block in it. Then you don't have to wash it off? (no flash rusting) Their head office, is in QLD somewhere I believe. https://www.evapo-rust.com.au/How It Works.html Is that Action Gel stuff, the same as Evaporust? Share this post Link to post Share on other sites
deankxf 20,266 Posted September 29, 2018 bores will rust instantly.. need to wipe them with some oil etc instantly .. same for machined surfaces 1 CHESTNUTXE reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,299 Posted September 29, 2018 The idea is not to give ol m8 at the machine shop as much to do as im spending too much on a dunk of the block at 100 bux someone had already bathed the block but left it 12 months thats why it had slight surface rust but definitely looks better now bores will rust instantly.. need to wipe them with some oil etc instantly .. same for machined surfaces Sent from my SM-G570Y using Tapatalk 1 deankxf reacted to this Share this post Link to post Share on other sites
gerg 10,871 Posted September 30, 2018 Light surface rust is pretty normal, but if you're still worried, best to hit it with some CRC while it's still wet and blow/wipe it all off. The only surfaces that really matter are bores and bearing tunnels. A bit of 1000 wet n dry takes care of these areas. Sent from my CPH1607 using Tapatalk 1 CHESTNUTXE reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,299 Posted September 30, 2018 Light surface rust is pretty normal, but if you're still worried, best to hit it with some CRC while it's still wet and blow/wipe it all off. The only surfaces that really matter are bores and bearing tunnels. A bit of 1000 wet n dry takes care of these areas. Sent from my CPH1607 using TapatalkWhen i got home from work its fkd again so will do it all again today but oil it straight awaySent from my SM-G570Y using Tapatalk Share this post Link to post Share on other sites
CHESTNUTXE 7,299 Posted September 30, 2018 its better now after spending a few hrs on it,i also cleaned 1 rod n piston up plus the bearings to do a dummy fit b4 taking it to the machine shop,i want to see how far down the hole the pistons are ,also the piston has about 20cc dish,so many heads available ,i would like to be in the 10.1 range . Share this post Link to post Share on other sites
CHESTNUTXE 7,299 Posted September 30, 2018 i used trans fluid about 20cc Share this post Link to post Share on other sites
CHESTNUTXE 7,299 Posted September 30, 2018 i used trans fluid about 20ccThe rusty cam came up maybe usable ? Its better than the 302 efi roller i pulled out last week Sent from my SM-G570Y using Tapatalk Share this post Link to post Share on other sites
CHESTNUTXE 7,299 Posted September 30, 2018 also these lifters seem the same but different,the guts of the 94 windsor roller lifter comes straight out and the eb 302 ones only the top bit came off,as a test i tryed everything on a fkd lifter just to see if i could get the rest out but nope ? Share this post Link to post Share on other sites
SPArKy_Dave 8,863 Posted September 30, 2018 They could've been seized together, with carbon. To my knowledge, they are all supposed to come apart... 2 CHESTNUTXE and NZXD reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,299 Posted September 30, 2018 any suggestion how to unpart em dave Share this post Link to post Share on other sites
CHESTNUTXE 7,299 Posted October 1, 2018 any suggestion how to unpart em daveI watched a vid on u tube how to clean em properly and it said if those parts are stuck in there they are trash so i cleaned the good ones out of the 351w and replaced the lot now they are working fine and im soooo glad i replaced them also the manifold should come today then finish it offSent from my SM-G570Y using Tapatalk 1 deankxf reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,299 Posted October 1, 2018 The manifold came Share this post Link to post Share on other sites
bear351c 10,270 Posted October 1, 2018 Which finish did you order..? Shiny or super shiny? 1 CHESTNUTXE reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,299 Posted October 1, 2018 i got it just natural as im not keeping this engine ,i will be getting a rpm air gap for my 3fifty 1 windsor in black probly ? Share this post Link to post Share on other sites
CHESTNUTXE 7,299 Posted October 1, 2018 yeah baby 2 bear351c and deankxf reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,299 Posted October 1, 2018 another shot,i also spent time cleaning the pistons for the new windsor looking good,i just put the top ring back on so i can do a dummy fit with the crank to see if we can surface the block .i saw a video where they put all 4 corner pistons in and see exactly how much to mill. Share this post Link to post Share on other sites
CHESTNUTXE 7,299 Posted October 2, 2018 another shot,i also spent time cleaning the pistons for the new windsor looking good,i just put the top ring back on so i can do a dummy fit with the crank to see if we can surface the block .i saw a video where they put all 4 corner pistons in and see exactly how much to mill.Im haveing massive trouble finding correct rings for the 351w factory piston as its an american thing ,plenty in the usa i might have too order them,302 efi is differentSent from my SM-G570Y using Tapatalk Share this post Link to post Share on other sites
