CHESTNUTXE 7,308 Posted September 21, 2018 i have also noticed the bolt torque specs are about 20 percent less than a cleveland. Share this post Link to post Share on other sites
CHESTNUTXE 7,308 Posted September 21, 2018 i think i have made a huge mistake but fixable,i have a massive amount of gap between the pushrod and rocker about a 1/4 inch maybe,when i bought the cam on special there was no warning about wont work with efi block,it has a small base circle ,i checked the old one and its lobes are much taller and base circle is fatter,so perhaps this cam suits older 302 blocks with roller lifters ? Share this post Link to post Share on other sites
CHESTNUTXE 7,308 Posted September 21, 2018 ok i fixed it with another factory cam i picked up during the week,its all spot on now.i put it the sump on just for a look until the timing cover comes on monday. Share this post Link to post Share on other sites
SPArKy_Dave 8,870 Posted September 21, 2018 Maybe you got a flat tappet camshaft? 1 CHESTNUTXE reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,308 Posted September 21, 2018 nah its a roller 224 @ hawaii 5\0 but i had no idea only a late model roller cam would fit, the small base circle cams since i just found out suit the older windsors  so there is trap to anyone else going down this path,i will ring em on monday and see if i can send it back or buy a early windsor for the next build and use this cam. Share this post Link to post Share on other sites
SPArKy_Dave 8,870 Posted September 21, 2018 12 hours ago, CHESTNUTXE said: nah its a roller 224 @ hawaii 5\0 but i had no idea   2 CHESTNUTXE and Valvebouncer reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,308 Posted September 21, 2018 call this song the DURATIONÂ 1 SPArKy_Dave reacted to this Share this post Link to post Share on other sites
Valvebouncer 2,389 Posted September 21, 2018 What’s wrong with the original timing cover? 1 CHESTNUTXE reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,308 Posted September 21, 2018 i had to chainsaw it off because off stuck bolts,new one coming monday says suits hawaii 5.0L 1 Valvebouncer reacted to this Share this post Link to post Share on other sites
NZXD 2,328 Posted September 22, 2018 Coming along nicely! Don’t forget to use thread sealer on the head bolts that go into the water jackets. Get some AU spec rocker cover gaskets, they are reusable and seal perfectly, I don’t like the cork ones at all. Same with the manifold ends, just use sealer and use a bit around the water ports as well, I’m sure you are all over this though. Sent from my iPhone using Tapatalk 2 Valvebouncer and CHESTNUTXE reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,308 Posted September 22, 2018 i am trying to find info on this small base circle cam,anyone else no anything about them ? Share this post Link to post Share on other sites
CHESTNUTXE 7,308 Posted September 22, 2018 23 hours ago, NZXD said: Coming along nicely! Don’t forget to use thread sealer on the head bolts that go into the water jackets. Get some AU spec rocker cover gaskets, they are reusable and seal perfectly, I don’t like the cork ones at all. Same with the manifold ends, just use sealer and use a bit around the water ports as well, I’m sure you are all over this though. Sent from my iPhone using Tapatalk which bolts go into the water jacket ? Share this post Link to post Share on other sites
NZXD 2,328 Posted September 22, 2018 i am trying to find info on this small base circle cam,anyone else no anything about them ? Small base circle roller cams are commonly called retro fit roller hydraulic cams to suit the non roller blocks. Sent from my iPhone using Tapatalk Share this post Link to post Share on other sites
NZXD 2,328 Posted September 22, 2018 which bolts go into the water jacket ?With the roller 5.0 blocks all the bottom row of head bolts go into the water jacket. The top row should be blind. Sent from my iPhone using Tapatalk 1 Valvebouncer reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,308 Posted September 22, 2018 Small base circle roller cams are commonly called retro fit roller hydraulic cams to suit the non roller blocks. Sent from my iPhone using TapatalkHey maybe you want it cause now im stuck with it ????? Or can you use it with longer pushrods on a roller blockSent from my SM-G570Y using Tapatalk Share this post Link to post Share on other sites
Valvebouncer 2,389 Posted September 22, 2018 With the roller 5.0 blocks all the bottom row of head bolts go into the water jacket. The top row should be blind. Sent from my iPhone using TapatalkIt doesn’t hurt to put stud sealant on the inlet manifold bolts that go into the water jackets too. 2 CHESTNUTXE and NZXD reacted to this Share this post Link to post Share on other sites
NZXD 2,328 Posted September 22, 2018 Hey maybe you want it cause now im stuck with it ????? Or can you use it with longer pushrods on a roller blockSent from my SM-G570Y using TapatalkWhat’s the specs? Sent from my iPhone using Tapatalk 1 CHESTNUTXE reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,308 Posted September 22, 2018 intake 218 exhaust 224 @hawaii 5/0-Â 1500 /5500 powerband 513 lift and 110 lobe sep,so its pretty mild with a bit of stick,all i did was smuther it in engine oil and put some cam breakin lube on the dizzy gear,then carefully fitted it and noticed the other roller cam was fatter,thats why my pushrods were too short about 1/8 of a inch maybe to 1/4 not too much but i reckon it could be used in a roller block with some longer pushrods ? i have sent a message to thunderhead289 and he should be able to tell me if its possible this guy is mr 302 windsor. Share this post Link to post Share on other sites
CHESTNUTXE 7,308 Posted September 22, 2018 It doesn’t hurt to put stud sealant on the inlet manifold bolts that go into the water jackets too.So these outside boltsSent from my SM-G570Y using Tapatalk Share this post Link to post Share on other sites
NZXD 2,328 Posted September 22, 2018 So these outside boltsSent from my SM-G570Y using Tapatalk Yes, were they new bolts you fitted? They had torque to yeld head bolts from the factory that are a one time use as they stretch. That bumpstick is a little to mild for me, my next build is having something around .600 lift and 240-250 duration. Sent from my iPhone using Tapatalk 2 gerg and CHESTNUTXE reacted to this Share this post Link to post Share on other sites
NZXD 2,328 Posted September 22, 2018 You can see why a set of headers wakes these babies up a bit, those manifolds are so restrictive. Sent from my iPhone using Tapatalk 1 CHESTNUTXE reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,308 Posted September 22, 2018 yeah i just clean n paint everything that came with it,looks better for sale imo. 1 NZXD reacted to this Share this post Link to post Share on other sites
NZXD 2,328 Posted September 22, 2018 yeah i just clean n paint everything that came with it,looks better for sale imo.Yeah definitely looks good. I don’t think you’ll have any issue selling it. Sent from my iPhone using Tapatalk 1 CHESTNUTXE reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,308 Posted September 22, 2018 yeah every engine i rebuild sells quite easy i dont ask much for it ,im planing on buying the 2nd 302 efi au 1999 engine down the wrecker as soon as this is sold it should have the gt40p heads which will give me a better base to start with,then take it from there i have been reading about the 331 stroker kit ,it doesnt need any block mods and drops straight in not bad for 990 us dollars forged pistons and scat crank n rods 2 gerg and NZXD reacted to this Share this post Link to post Share on other sites
Valvebouncer 2,389 Posted September 22, 2018 Yes, were they new bolts you fitted? They had torque to yeld head bolts from the factory that are a one time use as they stretch. Sent from my iPhone using TapatalkNot the one I did. I had to replace them any way as some fuckwit previous mechanic lost one bolt and replaced it with a normal bolt.Use holden head stud sealant, it’s the best stuff and the only decent thing to ever wear a holden badge. 2 CHESTNUTXE and NZXD reacted to this Share this post Link to post Share on other sites
