gerg 10,871 Posted December 28, 2019 thanks for that if i had unlimited budget i would buy those tmeyer ones but i want to check the factory high comp ones that are in it already ,and if the bore is ok and no piston movement,a good chance its ok cause it was sitting in a warehouse for 17 years that we know of,and its all there nothing missing,rags put in every open place,hell i reckon it would fire up,but i cant get to it until he re opens after time off for holidays,im also hoping my engine stand wont fold ,i have had a couple of clevos on it b4 with iron intakes n all,so it should hold ,i think it says 400kg .400s are only about 20kg heavier than a clevo. It's mostly in the block, a bit in the crank and rods, and that big fuckoff manifold up top. Sent from my CPH1903 using Tapatalk 1 CHESTNUTXE reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,299 Posted December 28, 2019 maybe we can have a OZFALCON comp,guess the weight of the 400 manifold . Share this post Link to post Share on other sites
CHESTNUTXE 7,299 Posted December 28, 2019 hey has anyone seen those manifold adaptors from holley and price motorsports,where you can run a different range of manifolds on various blocks,like you could run a clevo air gap rpm performer 2v ,then the adaptor and put on the 400,more ideas. Share this post Link to post Share on other sites
Boingk 862 Posted December 29, 2019 The Action+ anifold is on sale at the moment, 380 shipped. https://www.ebay.com.au/itm/Weiand-Action-2V-Head-Intake-Manifold-Ford-V8-351M-400M-WM8010/264469277572?hash=item3d9398eb84:g:i1oAAOSw24hdgW-t:sc:AU_StandardDelivery!2880!AU!-1&frcectupt=true 1 CHESTNUTXE reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,299 Posted December 29, 2019 yeah i have it on my watch list,kind of fitting the name (ACTION MAN MANIFOLD) and probly perfect choice,forget a single plane for a 400 unless throwing 10k at it.latest research today found correct emissions rocker cover decal for 1972 400. Share this post Link to post Share on other sites
gerg 10,871 Posted December 29, 2019 hey has anyone seen those manifold adaptors from holley and price motorsports,where you can run a different range of manifolds on various blocks,like you could run a clevo air gap rpm performer 2v ,then the adaptor and put on the 400,more ideas.They might have been the only option years ago, and were priced accordingly but now the price works out more than just buying a whole new manifold, unless you had an OEM clevo one to fit (like a 76DA iron 4-barrel). I also don't like the fact that there are twice as many gaskets and therefore potential leak points. Also carby (and air cleaner) height is even more of an issue.Sent from my CPH1903 using Tapatalk 1 CHESTNUTXE reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,299 Posted January 1, 2020 ok update,hopefully the shop will be open tomorrow and i can pop in and do the deal,then get a tralier and take it home,im super keen to get it. 1 gerg reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,299 Posted January 2, 2020 ok update,hopefully the shop will be open tomorrow and i can pop in and do the deal,then get a tralier and take it home,im super keen to get it.These are some casring marks that need to be identified on the block we are hoping for a cleveland foundry mark and not the m for Michigan Sent from my SM-G570Y using Tapatalk Share this post Link to post Share on other sites
CHESTNUTXE 7,299 Posted January 2, 2020 ok i bought the motor ,and found out its a DIF casting for dearborn foundry ,see picture maybe gerg can work out the casting date,look to me like 1e20 if thats correct its a first cab off the rank and 10.2.1,i took the air cleaner home,has nice vac original dizzy on it too,the seller said dont tell me too much about the engine or the price is going up so action man slapped the cash down. 2 Boingk and gerg reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,299 Posted January 2, 2020 ok i bought the motor ,and found out its a DIF casting for dearborn foundry ,see picture maybe gerg can work out the casting date,look to me like 1e20 if thats correct its a first cab off the rank and 10.2.1,i took the air cleaner home,has nice vac original dizzy on it too,the seller said dont tell me too much about the engine or the price is going up so action man slapped the cash down.PicSent from my SM-G570Y using Tapatalk 2 1 Boingk, bear351c and gerg reacted to this Share this post Link to post Share on other sites
Boingk 862 Posted January 3, 2020 Nice one mate, it's its a 10.2 you're cheering, re ring and bearing and stab a camshaft in her while you're at it! I can hear it now, with that Action+ on it and an E-907-P... 1 CHESTNUTXE reacted to this Share this post Link to post Share on other sites
gerg 10,871 Posted January 3, 2020 I would have to look up a code cracker for that one Chestnut, more easily relateable for me is the block part number (ie: D1AE.... etc). Sent from my CPH1903 using Tapatalk 1 CHESTNUTXE reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,299 Posted January 3, 2020 well the tmeyer website says first letter is year and 1 is 1971 1 gerg reacted to this Share this post Link to post Share on other sites
gerg 10,871 Posted January 3, 2020 Ok, going by a site I found, it's a 20th May, 1971 casting.Sent from my CPH1903 using Tapatalk 1 CHESTNUTXE reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,299 Posted January 3, 2020 Ok, going by a site I found, it's a 20th May, 1971 casting.Sent from my CPH1903 using TapatalkGetting interestingSent from my SM-G570Y using Tapatalk Share this post Link to post Share on other sites
CHESTNUTXE 7,299 Posted January 3, 2020 Getting interestingSent from my SM-G570Y using TapatalkIm surprised how good the original blue is on the air cleaner base but the lid is average but not bad for 50 years old note small flange on the inside of the bottom of base ? Could be a holder to go on factory carbySent from my SM-G570Y using Tapatalk Share this post Link to post Share on other sites
gerg 10,871 Posted January 3, 2020 Those ears look like they locate on the post in front of the choke horn on the Motorcraft carby. The 2 barrel that would have come with this engine is basically the front half of the 4 barrel carby you got from the wreckersSent from my CPH1903 using Tapatalk 1 CHESTNUTXE reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,299 Posted January 3, 2020 i also noted thismorning it still had the original cast iron FOMOCO water pump,original dizzy,even has engine mounts on it,i have seen where they re co a numbers correct say xw clevo waterpump and asking a million dollars for it,so i could get a new rotation pressed in maybe. Share this post Link to post Share on other sites
CHESTNUTXE 7,299 Posted January 3, 2020 just orderd correct new air cleaner sticker and rocker cover emissions sticker from u.s.a. 1 Boingk reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,299 Posted January 3, 2020 A really good read is ford m block history by BUBBA ,has all the ins and outs of the full history of the 400 and later 351m,and what can be swapped around and actual dates ford changed things around,right up until early 1983 when it was canned,he also goes on about our 2v closed heads,the demise of the 400,and something new i never new,ford made a beefy truck 400 block in later years of production ,resembles our 82 pillow block castings from geelong a bit,very interesting read.He also goes on about what gerg was saying about net and gross hp figures,as the first 1971 hi comp engine was 10.2.1.,and 260HP,but after that they started with net hp and 171hp,and so on,well worth giving a read. 1 gerg reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,299 Posted January 4, 2020 A really good read is ford m block history by BUBBA ,has all the ins and outs of the full history of the 400 and later 351m,and what can be swapped around and actual dates ford changed things around,right up until early 1983 when it was canned,he also goes on about our 2v closed heads,the demise of the 400,and something new i never new,ford made a beefy truck 400 block in later years of production ,resembles our 82 pillow block castings from geelong a bit,very interesting read.He also goes on about what gerg was saying about net and gross hp figures,as the first 1971 hi comp engine was 10.2.1.,and 260HP,but after that they started with net hp and 171hp,and so on,well worth giving a read.Interesting note i cleaned up these 4 big bottom pulleys just to see if any differences but 3 are your garden variety d3ae 6312 ca typical 351c a/c and p/s but the one on the left is doae 6312 c3 which is a 1970 one and measures up about 1/8th inch shorter i wonder did this have a spacer behind it or maybe its 351w the bottom of it is flat compared to the other 3 the good thing is my new 400 dont have a big ass pulley on it so i guess 1 off these should workSent from my SM-G570Y using Tapatalk Share this post Link to post Share on other sites
CHESTNUTXE 7,299 Posted January 4, 2020 are these holes for balancing ? also i found this v8 engine mount are they the same for both sides ? just turn them around and how do you work out if its a xy or xa ? Share this post Link to post Share on other sites
bear351c 10,270 Posted January 4, 2020 I think...? the 4 holes in the mounting plates are different spacing. Share this post Link to post Share on other sites
gerg 10,871 Posted January 4, 2020 The V8 mounting brackets aren't the same for each side. One bolt is different on one corner, and mirrored so you can't swap sides. The 6 cyl ones are offset to mount the engine further forward due to extra length.Those drillings are for balancing, but not for engine balance. It's just so the part itself has zero imbalance, leaving all external balancing to the harmonic balancer counterweight.Sent from my CPH1903 using Tapatalk 3 CHESTNUTXE, bear351c and Thom reacted to this Share this post Link to post Share on other sites
