gerg 10,871 Posted February 26, 2020 So no rods or pistons... That might be a bit of an issueSent from my CPH1903 using Tapatalk 1 CHESTNUTXE reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,300 Posted February 26, 2020 So no rods or pistons... That might be a bit of an issueSent from my CPH1903 using TapatalkNah pick the rest up tomorrow but 1st clean up sees a DIY block so its a good one and if you could decode the casting date i think its a 78 casting galaxie pretty good imo no lip on bore and i have the pistons out of the old 400 to fix it ,no rush m8 plenty engines coming just put the vasoline away lolSent from my SM-G570Y using Tapatalk 1 gerg reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,300 Posted February 26, 2020 Nah pick the rest up tomorrow but 1st clean up sees a DIY block so its a good one and if you could decode the casting date i think its a 78 casting galaxie pretty good imo no lip on bore and i have the pistons out of the old 400 to fix it ,no rush m8 plenty engines coming just put the vasoline away lolSent from my SM-G570Y using TapatalkPulled her down already this thing has a good double roller ,lifters just fell out and cam looks ok,but will need hone maybe ,bearings look ok too ,oil return is different on this block as well like its choked a bit compard too my oneSent from my SM-G570Y using Tapatalk Share this post Link to post Share on other sites
bear351c 10,270 Posted February 26, 2020 Oooo....... more engine mount plates. 1 CHESTNUTXE reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,300 Posted February 26, 2020 note casting number mib men in black ? nah i think this one is a 81 casting maybe 1 gerg reacted to this Share this post Link to post Share on other sites
gerg 10,871 Posted February 26, 2020 note casting number mib men in black ? nah i think this one is a 81 casting maybeIf it's a Dearborn casting (DIF, Dearborn Iron Foundry), they apparently only made them 71-72. I was worried that it was one of the pre-77 blocks that has trouble with cracking in the valley from the water jacket, but that problem only occured wit Michigan Casting Centre. What I don't get is the extra ribbing around the oil drain holes. I don't recall seeing that before.Sent from my CPH1903 using Tapatalk 1 CHESTNUTXE reacted to this Share this post Link to post Share on other sites
gerg 10,871 Posted February 26, 2020 I just read that an actual build date is located on the timing cover surface, drivers side directly below the water pump hole. That will tell you exactly what year, month and day it was assembled.Sent from my CPH1903 using Tapatalk 1 CHESTNUTXE reacted to this Share this post Link to post Share on other sites
gerg 10,871 Posted February 26, 2020 note casting number mib men in black ? nah i think this one is a 81 casting maybeIt's looking like a service replacement block. Could've been a warranty engine.D1 = 71A = full-size carZ = service partWhat does it say on the crank?Sent from my CPH1903 using Tapatalk 1 CHESTNUTXE reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,300 Posted February 26, 2020 It's looking like a service replacement block. Could've been a warranty engine.D1 = 71A = full-size carZ = service partWhat does it say on the crank?Sent from my CPH1903 using TapatalkI will look tomorrow im at work atm,but i reckon the d1 is just like our d2ae cleveland design its on all blocks from mid xb to xe ?Sent from my SM-G570Y using Tapatalk Share this post Link to post Share on other sites
gerg 10,871 Posted February 26, 2020 I will look tomorrow im at work atm,but i reckon the d1 is just like our d2ae cleveland design its on all blocks from mid xb to xe ?Sent from my SM-G570Y using TapatalkYes correct, the D1 doesn't mean it was made then, it's when the part originally came out.Sent from my CPH1903 using Tapatalk 1 CHESTNUTXE reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,300 Posted February 26, 2020 2 hours ago, gerg said: Yes correct, the D1 doesn't mean it was made then, it's when the part originally came out. Sent from my CPH1903 using Tapatalk I have another idea too use the 2v cast iron manifold and heads off the other 400 and build a nice stock original 400 factory looking 400,sump too,its all there then up the anti on my ute motor with high energy sump and arp studs allround then use the bolts and factory fittings on this engine as ol m8 is doing the 2v closed for the ute 400. Sent from my SM-G570Y using Tapatalk 1 gerg reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,300 Posted February 26, 2020 I have another idea too use the 2v cast iron manifold and heads off the other 400 and build a nice stock original 400 factory looking 400,sump too,its all there then up the anti on my ute motor with high energy sump and arp studs allround then use the bolts and factory fittings on this engine as ol m8 is doing the 2v closed for the ute 400. Sent from my SM-G570Y using Tapatalk Gerg here is that number maybe you can break the code ,i reckon its a 82 block or 81 as look at the pillow similar to our pillow blocks of the same era, also this block is not lipped for the 4v valves like my 71 block very interesting dr jonesSent from my SM-G570Y using Tapatalk Share this post Link to post Share on other sites
CHESTNUTXE 7,300 Posted February 26, 2020 2a5n,1m18 pretty sure is 1981 cast and 1982 built maybe,tomorrow when i pick up the rods we can see how big the dish is on the pistons. Share this post Link to post Share on other sites
gerg 10,871 Posted February 26, 2020 I'm more inclined to think it's a 72, as it has a Dearborn Foundry marking, which did the 400 in 71-72 only. If it was an 82, it would have a Cleveland or Michigan casting emblemSent from my CPH1903 using Tapatalk 1 CHESTNUTXE reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,300 Posted February 26, 2020 yeah,but why is my other 71 block so different in many ways Share this post Link to post Share on other sites
gerg 10,871 Posted February 26, 2020 Here's another point... If it was made 73 onwards, it would have a different part number. Look in the table below... There were a few updates like D3, D5, D7, D8 which all superseded D1. If the last revision was 78, that's what the 82 block would have cast into it.Sent from my CPH1903 using Tapatalk 1 CHESTNUTXE reacted to this Share this post Link to post Share on other sites
gerg 10,871 Posted February 26, 2020 yeah,but why is my other 71 block so different in many waysI can't answer that one... Is it a Cleveland foundry block?Sent from my CPH1903 using Tapatalk 1 CHESTNUTXE reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,300 Posted February 26, 2020 I can't answer that one... Is it a Cleveland foundry block?Sent from my CPH1903 using TapatalkNah they are both dif blocks,but interesting note ute engine is western foundry 4 and this one is western foundry 2Sent from my SM-G570Y using Tapatalk 1 gerg reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,300 Posted February 26, 2020 or maybe a late block restamped under warranty,but it dont make sense it also came out of a galaxy but an australian one,at the end of the day it dont really matter,its in gc, and its being resurrected by us. Share this post Link to post Share on other sites
gerg 10,871 Posted February 26, 2020 or maybe a late block restamped under warranty,but it dont make sense it also came out of a galaxy but an australian one,at the end of the day it dont really matter,its in gc, and its being resurrected by us.The big thing to look for (so I have read about) is if it's a pre-'77 Michigan casting. They are the ones prone to cracking. After that date, they revised the casting or metallurgy or whatever and it's not a problem. There's a lump halfway along the water jacket on each side of the valley, and there will be a horizontal crack just next to it. Not structural, but leaks coolant into the oil.Sent from my CPH1903 using Tapatalk 1 CHESTNUTXE reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,300 Posted February 27, 2020 The big thing to look for (so I have read about) is if it's a pre-'77 Michigan casting. They are the ones prone to cracking. After that date, they revised the casting or metallurgy or whatever and it's not a problem. There's a lump halfway along the water jacket on each side of the valley, and there will be a horizontal crack just next to it. Not structural, but leaks coolant into the oil.Sent from my CPH1903 using TapatalkYour right gerg she is a early block it does have 4v lip after cleaning and painting looks mean also crank is 010 on mains but didnt get rods because he was to busy to search for themSent from my SM-G570Y using Tapatalk Share this post Link to post Share on other sites
CHESTNUTXE 7,300 Posted February 27, 2020 Your right gerg she is a early block it does have 4v lip after cleaning and painting looks mean also crank is 010 on mains but didnt get rods because he was to busy to search for themSent from my SM-G570Y using TapatalkAlso balancer is d2 and crank 5m ect 77 bearings so someone has rebuilt this one b4 im not sure about std bore as there is a bit of wobble in my std pistons but not much no rings on piston if anything std or 020 i reckon which can only mean one thing order new pistons to suit maybe will see when i get the original rods n pistons back in a few days timeSent from my SM-G570Y using Tapatalk 1 gerg reacted to this Share this post Link to post Share on other sites
gerg 10,871 Posted February 27, 2020 Looking spunky... Just had a thought, if it was an AU assembled Galaxie, Ford Oz could have ordered that engine as a spare part from the states (hence the D1AZ block instead of D1AE) in order to qualify as an Aussie CKD assembly. They built Cortinas, Escorts and F-trucks like this.Sent from my CPH1903 using Tapatalk 2 Thom and CHESTNUTXE reacted to this Share this post Link to post Share on other sites
gerg 10,871 Posted February 27, 2020 In a similar vein... for the Nagari, Bolwell used to order their Clevos from Ford as an industrial engine. The engine number used to start with AIE (I think) meaning Australian Industrial Engine. Bloke at work owns 2 Bolwells, a coupe and very rare convertible.Sent from my CPH1903 using Tapatalk 1 CHESTNUTXE reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,300 Posted February 27, 2020 In a similar vein... for the Nagari, Bolwell used to order their Clevos from Ford as an industrial engine. The engine number used to start with AIE (I think) meaning Australian Industrial Engine. Bloke at work owns 2 Bolwells, a coupe and very rare convertible.Sent from my CPH1903 using TapatalkI have seen 1 nigari in sydney a long time ago red with 4v engineSent from my SM-G570Y using Tapatalk 1 gerg reacted to this Share this post Link to post Share on other sites
