CHESTNUTXE 7,304 Posted February 3, 2020 turblo 400 Share this post Link to post Share on other sites
CHESTNUTXE 7,304 Posted February 3, 2020 hey just turn the cast iron manifolds upsidedown and bolt 2 turbos on ,? 1 Boingk reacted to this Share this post Link to post Share on other sites
Boingk 862 Posted February 3, 2020 If you don't get 600 horse I'd be mighty disappointed. 1 CHESTNUTXE reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,304 Posted February 3, 2020 plenty room in the xf engine bay,no fan,2 pipes going back into a carb hat ? Share this post Link to post Share on other sites
Boingk 862 Posted February 3, 2020 Exhaust crossover into a single HX35 turbo where the battery would normally go, relocate it to behind the cab. Single entry onto a hat, boost reference fuel pressure... you're laughing! 1 CHESTNUTXE reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,304 Posted February 4, 2020 Exhaust crossover into a single HX35 turbo where the battery would normally go, relocate it to behind the cab. Single entry onto a hat, boost reference fuel pressure... you're laughing!Ok the correct blue paint came and umm yeer yeah it aint hardly any different to what i used yesterday so guys dont fall for bc paints $50 can when ford vht lighy blue is identical for $16also after painting the air cleaner lid the crows feet came thru from underlying problems so i stripped it back to bare metal and primed it just waiting a few hrs to cure then lay down a few coatsSent from my SM-G570Y using Tapatalk Share this post Link to post Share on other sites
CHESTNUTXE 7,304 Posted February 4, 2020 Ok the correct blue paint came and umm yeer yeah it aint hardly any different to what i used yesterday so guys dont fall for bc paints $50 can when ford vht lighy blue is identical for $16also after painting the air cleaner lid the crows feet came thru from underlying problems so i stripped it back to bare metal and primed it just waiting a few hrs to cure then lay down a few coatsSent from my SM-G570Y using TapatalkNow that is really looking good 400 2v was worth putting time n effort in to itSent from my SM-G570Y using Tapatalk 1 gregaust reacted to this Share this post Link to post Share on other sites
Boingk 862 Posted February 4, 2020 Looking good mate! 1 CHESTNUTXE reacted to this Share this post Link to post Share on other sites
bear351c 10,270 Posted February 4, 2020 Nice. big fan of the original looking engine bay. 1 CHESTNUTXE reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,304 Posted February 4, 2020 Note regular fuel on air cleaner 1971 sticker ,this was the high octane gasoline cleveland ,the 400 had the nickname red devil ,as super was red colour . Share this post Link to post Share on other sites
CHESTNUTXE 7,304 Posted February 4, 2020 dizzy shaft size is 515thou so i gues the 530 one will work yeah ? Share this post Link to post Share on other sites
CHESTNUTXE 7,304 Posted February 4, 2020 i just did the math and by the time i buy a cast iron dizzy gear and postage,plus the petronix conversion its gunnabe up around $250 easy,bugger that just buy a msd dizzy or aftermarket decent quality dizzy and wire the msd 6al-2 into it. 1 gerg reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,304 Posted February 4, 2020 i just did the math and by the time i buy a cast iron dizzy gear and postage,plus the petronix conversion its gunnabe up around $250 easy,bugger that just buy a msd dizzy or aftermarket decent quality dizzy and wire the msd 6al-2 into it.Down at the machine shop i found a set of nice closed chamber bare heads ,my valves will go straight in with a bit of re co from olm8 so i stripped the big opens again not really sure what to do with these maybe just keep em aside for a whileSent from my SM-G570Y using Tapatalk 1 gerg reacted to this Share this post Link to post Share on other sites
gerg 10,871 Posted February 4, 2020 Did you cc the pistons and get the machinist to measure piston deck clearance? That will tell you if you can use those closed chambersSent from my CPH1903 using Tapatalk 1 CHESTNUTXE reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,304 Posted February 4, 2020 not yet but im sure he knows whats going on,i reckon the piston to deck height will be not as bad as first thought by judgeing both old and new sets looked identical height. Share this post Link to post Share on other sites
gerg 10,871 Posted February 4, 2020 Here use this calculator, it came up with 11.43:1 comp using 8cc dish, 0.020 down the hole, 0.041" gasket and 58cc headhttp://www.wallaceracing.com/cr_test2.phpSent from my CPH1903 using Tapatalk 1 CHESTNUTXE reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,304 Posted February 4, 2020 60 thou down the hole and 20cc dish piston and 58cc head got 10.1.1 Share this post Link to post Share on other sites
CHESTNUTXE 7,304 Posted February 4, 2020 it says by that calcuator that a 400 has a 3.75 stroke ? i thought ford 400 had a 4 inch stroke ? Share this post Link to post Share on other sites
gerg 10,871 Posted February 4, 2020 it says by that calcuator that a 400 has a 3.75 stroke ? i thought ford 400 had a 4 inch stroke ?No that site is for Pontiacs, the sizes on the left are to autofill the specs for various Pontiac engines. You need to manually enter bore, stroke and cc, etc to get the right figure for a 400 Ford. It should come in at around 402 cubes if entered right (stock bore)Sent from my CPH1903 using Tapatalk 1 CHESTNUTXE reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,304 Posted February 4, 2020 i like using the summitt one,i came in at 10.1.1 with a fair bit down the hole and 58cc head,im guessing 20 to 28 cc for the piston. 1 gerg reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,304 Posted February 4, 2020 hey i found this cam lifters and springs from the usa quite cheap but cam specs are 484 /512 will 512 be ok with std rockers ? i know the general rule is 500 lift ? Share this post Link to post Share on other sites
gerg 10,871 Posted February 4, 2020 512 is fine, 12 thou is only about a quarter of a mm. What are the other specs for it?Sent from my CPH1903 using Tapatalk Share this post Link to post Share on other sites
gerg 10,871 Posted February 4, 2020 i like using the summitt one,i came in at 10.1.1 with a fair bit down the hole and 58cc head,im guessing 20 to 28 cc for the piston.I ran those specs through the Wallace Racing one, it came in at 8.68:1. Are you sure the piston has that much dish? Edit: just ran the Summit one, it came in at 8.73:1 It assumes that your head gasket is the same as the bore, which it never is. The Wallace Racing one lets you input the gasket diameter to allow for the extra volume there. I put in 4.100" as that's closer to what they are. Sent from my CPH1903 using Tapatalk 1 CHESTNUTXE reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,304 Posted February 4, 2020 I ran those specs through the Wallace Racing one, it came in at 8.68:1. Are you sure the piston has that much dish? Edit: just ran the Summit one, it came in at 8.73:1 It assumes that your head gasket is the same as the bore, which it never is. The Wallace Racing one lets you input the gasket diameter to allow for the extra volume there. I put in 4.100" as that's closer to what they are. Sent from my CPH1903 using Tapatalk Is that with opens ?Sent from my SM-G570Y using Tapatalk Share this post Link to post Share on other sites
CHESTNUTXE 7,304 Posted February 4, 2020 Is that with opens ?Sent from my SM-G570Y using TapatalkAlso fitted a fmx modulator line had to bend it a bit also some c6 flexplates are only 24oz but i think this one is 28 or should beSent from my SM-G570Y using Tapatalk Share this post Link to post Share on other sites
