gregaust 319 Posted January 27, 2020 Speedo will go right in . Just be sure to use the correct gear L servo is an ok one to use Does look very clean , depends on you use a shift kit may be a good addition. A stock C6 shifts soft 1 CHESTNUTXE reacted to this Share this post Link to post Share on other sites
Boingk 862 Posted January 27, 2020 3.45 with a standard stall would be a bit of a hoot, but if it were mine I'd rock 2.92s and go a bigger stall. Power when you want it and still cruise when you need to. 1 CHESTNUTXE reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,299 Posted January 27, 2020 do you wanna tickle it up gregaus ? i can bring it up ,your in brisvegas yeah Share this post Link to post Share on other sites
CHESTNUTXE 7,299 Posted January 27, 2020 2 minutes ago, Boingk said: 3.45 with a stabdrard stall would be a bit of a hoot, but if it were mine I'd rock 2.92s and go a bugger stall. Power when you want it and still cruise when you need to. yeah i put 3.27 behind my 351c in my xe with fmx and it was a big mistake it changed into top gear nearly straight away. Share this post Link to post Share on other sites
CHESTNUTXE 7,299 Posted January 27, 2020 yeah i put 3.27 behind my 351c in my xe with fmx and it was a big mistake it changed into top gear nearly straight away.Original fomoco filterSent from my SM-G570Y using Tapatalk Share this post Link to post Share on other sites
gerg 10,871 Posted January 27, 2020 I reckon a big torque monster like this needs the tallest gears possible. Otherwise, spinning it hard in the lower gears just wastes energy spinning itself.Sent from my CPH1903 using Tapatalk 1 CHESTNUTXE reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,299 Posted January 27, 2020 I reckon a big torque monster like this needs the tallest gears possible. Otherwise, spinning it hard in the lower gears just wastes energy spinning itself.Sent from my CPH1903 using TapatalkBut 2.92 is the tallest i have in b/w 28 spline and the wackyist thing is i only just got the diff shop to rebuild it back to 3.45 from 2.92 god dam it ,hmmm maybe its time for mr ninch to get built 2.75 lsd im sure it wont be hard to find a xa /xc one for leafs to suit the xf uteSent from my SM-G570Y using Tapatalk Share this post Link to post Share on other sites
CHESTNUTXE 7,299 Posted January 28, 2020 But 2.92 is the tallest i have in b/w 28 spline and the wackyist thing is i only just got the diff shop to rebuild it back to 3.45 from 2.92 god dam it ,hmmm maybe its time for mr ninch to get built 2.75 lsd im sure it wont be hard to find a xa /xc one for leafs to suit the xf uteSent from my SM-G570Y using TapatalkUpdate i cleaned the crank up but i think the mains need a clean up,big ends were better but probly 10 thou on both should do the trick i reckonSent from my SM-G570Y using Tapatalk 1 gerg reacted to this Share this post Link to post Share on other sites
gerg 10,871 Posted January 29, 2020 These have massive 3" mains, like a 351W, so I'm sure 10 thou isn't going to ruin the friendshipSent from my CPH1903 using Tapatalk 1 CHESTNUTXE reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,299 Posted January 29, 2020 These have massive 3" mains, like a 351W, so I'm sure 10 thou isn't going to ruin the friendshipSent from my CPH1903 using TapatalkSandwich plate is cleaned and new filter and pan gasket on order from usa ,heads have been dummy cleaned and ready for skim and this broken exhaust bolt i cant get out its gunna be a job for the machine shopSent from my SM-G570Y using Tapatalk Share this post Link to post Share on other sites
Boingk 862 Posted January 29, 2020 Looking good from the photos, honestly that crank seems fine at least how I'm seeing it. If you can't catch a fingernail on any of the scratches they should be okay to use. I linished mine with some strips of 1200 grit and WD40, not sure if it even did anything but they look and feel okay so I'll take some measurements and chuck it back in. The real nightmare was my crossflow... that thing was hammered and the crank looked very much less than ideal but again no fingernail catch so I slapped it in, ran 20W-60 and spun it up to 6,000rpm. Still holding 50psi oil pressure, too. 1 CHESTNUTXE reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,299 Posted January 29, 2020 i hit it with 600 and my nail can catch one of the mains but maybe olm8 can polish it out ,also look at the beefy flywheel bolts compard to arp alternative,also i dont fall for the 3 card trick very often but i got done,i bought this 400 p/s bracket from the mustang ranch in america and it looked much longer than the normal xd/xe p/s bracket cause the taller deck i figured it needed a longer support bracket for the pump but nope it looks exactly the same as a normal xd/xe bracket so i paid a lot of money for something i could have got here ,it must be the actual 400 p/szx pumpzx bracket that is longer im on the case atm ,also cleaned up all bolts,and all are in gc,also orderd 400 mounts from usa ,and got good info how to make the 400 fit in xa/xf stlye chassis,just make a 1/2 inch spacer plate under the plate and raise the titanic,but air cleaner must be no more than 2 inchs. 2 bear351c and gerg reacted to this Share this post Link to post Share on other sites
bear351c 10,270 Posted January 29, 2020 Don't worry about the size of the bolt heads, ARP are good at what they they do. Modern technologies, different metals, machining processes, all contribute to "different" things that do the same job. Like seeing the rebuild photos, good info for all us "Non 400" Clevo drivers. 1 CHESTNUTXE reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,299 Posted January 29, 2020 Don't worry about the size of the bolt heads, ARP are good at what they they do. Modern technologies, different metals, machining processes, all contribute to "different" things that do the same job. Like seeing the rebuild photos, good info for all us "Non 400" Clevo drivers. The manifold should lob uptomorrowSent from my SM-G570Y using Tapatalk 1 gerg reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,299 Posted January 29, 2020 The manifold should lob uptomorrowSent from my SM-G570Y using TapatalkWeyland industries kindly donated this nice manifoldSent from my SM-G570Y using Tapatalk 2 2redrovers and Boingk reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,299 Posted January 30, 2020 Weyland industries kindly donated this nice manifoldSent from my SM-G570Y using TapatalkGood news on the pistons they seem same comp height as old ones but dish is a big bigger i tried to measure the volume but the valve reliefs kept overflowing with kero im guessing around 20cc but thats good news as the block might not need much taken off it also 2v ports on manifold seem quite small but overall im stokedSent from my SM-G570Y using Tapatalk 1 gerg reacted to this Share this post Link to post Share on other sites
gerg 10,871 Posted January 30, 2020 Looks like 2v closed is the go then. These will be too much cc with opens plus 80 down the holeSent from my CPH1903 using Tapatalk 2 CHESTNUTXE and Boingk reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,299 Posted January 30, 2020 I doubt they will be that far down the hole ,the old ones were near zero deck ? Share this post Link to post Share on other sites
CHESTNUTXE 7,299 Posted January 30, 2020 lets see what olm8 says i havent even seen the block yet Share this post Link to post Share on other sites
Boingk 862 Posted January 30, 2020 Slap it together and feed it the gas mate, she'll be right. *cracks open VB longneck* SEND IT! 1 CHESTNUTXE reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,299 Posted January 30, 2020 Slap it together and feed it the gas mate, she'll be right. *cracks open VB longneck* SEND IT!Olm8 has the pistons and the block is cleaned will update with picsSent from my SM-G570Y using Tapatalk 2 gerg and Boingk reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,299 Posted January 30, 2020 Olm8 has the pistons and the block is cleaned will update with picsSent from my SM-G570Y using TapatalkSo what is the go when trying to find the correct Speedo gear for say 2.92 ? The black spiral thing is the big gear i guess ? I also managed to get the navy seal outSent from my SM-G570Y using Tapatalk Share this post Link to post Share on other sites
gerg 10,871 Posted January 31, 2020 Navy seal... Lol Likes a bit of the rear admiralSent from my CPH1903 using Tapatalk 1 CHESTNUTXE reacted to this Share this post Link to post Share on other sites
