gregaust 319 Posted May 28, 2022 .060" is fine. A lot go .080" 1 CHESTNUTXE reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,299 Posted May 28, 2022 where do you get 080 pistons ? i cant find any on e bay . Share this post Link to post Share on other sites
deankxf 20,266 Posted May 28, 2022 1 hour ago, CHESTNUTXE said: where do you get 080 pistons ? i cant find any on e bay . i just googled and got this link.. if it suits?https://www.summitracing.com/search/part-type/pistons/make/ford/engine-size/7-5l-460/engine-family/ford-big-block-385-series/bore-in/4-440-in/stroke/4-500-in 1 burnnotice1000 reacted to this Share this post Link to post Share on other sites
burnnotice1000 588 Posted May 28, 2022 i just googled and got this link.. if it suits?https://www.summitracing.com/search/part-type/pistons/make/ford/engine-size/7-5l-460/engine-family/ford-big-block-385-series/bore-in/4-440-in/stroke/4-500-inThat's to suit a 4.500 stroke crankSent from my SM-A125F using Tapatalk 1 deankxf reacted to this Share this post Link to post Share on other sites
jca25 1,034 Posted May 29, 2022 Do sell these blocks and cranks off much now Sent from my SM-G781B using Tapatalk 1 burnnotice1000 reacted to this Share this post Link to post Share on other sites
burnnotice1000 588 Posted May 29, 2022 Do sell these blocks and cranks off much now Sent from my SM-G781B using TapatalkI scored a crank spacer this morning you need this on a early internally balanced crankSent from my SM-A125F using Tapatalk 3 Outback Jack, jca25 and gerg reacted to this Share this post Link to post Share on other sites
jca25 1,034 Posted May 29, 2022 I scored a crank spacer this morning you need this on a early internally balanced crankSent from my SM-A125F using TapatalkGreat information but just was more wanting to know if it's worth me looking a doing a bb or keep looking at the stoker on my spare blockSent from my SM-G781B using Tapatalk Share this post Link to post Share on other sites
gerg 10,871 Posted May 29, 2022 Great information but just was more wanting to know if it's worth me looking a doing a bb or keep looking at the stoker on my spare blockSent from my SM-G781B using TapatalkBig blocks are cheap horsepower but heavy. Strokers get it done with much less weight but the bits are expensive, only the block basically remains, everything else is turfed for new bitsSent from my CPH2197 using Tapatalk 3 burnnotice1000, Outback Jack and jca25 reacted to this Share this post Link to post Share on other sites
jca25 1,034 Posted May 29, 2022 Big blocks are cheap horsepower but heavy. Strokers get it done with much less weight but the bits are expensive, only the block basically remains, everything else is turfed for new bitsSent from my CPH2197 using TapatalkYea the plan was 408 stoker for the van, but never been sure on a bb, like I have the spare 302 at home, just more of a price weigh up on things on parts as I build myself and the machine work gets done for me at cost or less Sent from my SM-G781B using Tapatalk 3 burnnotice1000, Outback Jack and gerg reacted to this Share this post Link to post Share on other sites
burnnotice1000 588 Posted May 29, 2022 Yea the plan was 408 stoker for the van, but never been sure on a bb, like I have the spare 302 at home, just more of a price weigh up on things on parts as I build myself and the machine work gets done for me at cost or less Sent from my SM-G781B using TapatalkEither is good ,mounts n extractors are easy to find,460 van is megaSent from my SM-A125F using Tapatalk 1 jca25 reacted to this Share this post Link to post Share on other sites
FORD_MAN 1,026 Posted May 29, 2022 Pro-Gram makes Front, Center & rear main caps for cleveland, windsor (5.0, 302 & 351) & BBF, https://mwengineservices.com.au/wp-content/uploads/2012/01/Catalogue_V2.pdf 3 burnnotice1000, CHESTNUTXE and Outback Jack reacted to this Share this post Link to post Share on other sites
burnnotice1000 588 Posted May 29, 2022 Pro-Gram makes Front, Center & rear main caps for cleveland, windsor (5.0, 302 & 351) & BBF,https://mwengineservices.com.au/wp-content/uploads/2012/01/Catalogue_V2.pdf Thanks for that Sent from my SM-A125F using Tapatalk 1 CHESTNUTXE reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,299 Posted May 30, 2022 i took the block down to the machine shop,took the cam bearings and 1 piston to give him something to look at when honing the block,so this time next week we can start to put it together hopefully,i also bought a book on big block building ,should get deliverd soon. 3 gerg, Outback Jack and deankxf reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,299 Posted June 1, 2022 i found a set of caps for the other block ,getting them next month,at least thats something and got them cheap so a line bore is not out of the question anymore,and it will give me another 460 to build or 429 ,im thinking of doing a nice 429 just for something different,rods are the same and pistons are cheap as chips from usa as most go for the 460 build,just some ideas at this stage. 3 gerg, bear351c and burnnotice1000 reacted to this Share this post Link to post Share on other sites
burnnotice1000 588 Posted June 2, 2022 i found a set of caps for the other block ,getting them next month,at least thats something and got them cheap so a line bore is not out of the question anymore,and it will give me another 460 to build or 429 ,im thinking of doing a nice 429 just for something different,rods are the same and pistons are cheap as chips from usa as most go for the 460 build,just some ideas at this stage.The book is hereSent from my SM-A125F using Tapatalk 1 Outback Jack reacted to this Share this post Link to post Share on other sites
burnnotice1000 588 Posted June 2, 2022 The book is hereSent from my SM-A125F using TapatalkSo refreshing to see so much info ,questions I was wondering about and picked up 2 things straight away I needed to know.even has stuff on clevo and 400.Sent from my SM-A125F using Tapatalk 3 1 gregaust, SPArKy_Dave, gerg and 1 other reacted to this Share this post Link to post Share on other sites
SPArKy_Dave 8,863 Posted June 2, 2022 I like technical books, that one looks like a good investment! Share this post Link to post Share on other sites
CHESTNUTXE 7,299 Posted June 2, 2022 yes it even has red flags on things you must do on re assembly ,there is a tiny hole in one of the inlet ports that must be plugged and bottom hole on timing cover goes into the water jacket and must use sealer. 1 deankxf reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,299 Posted June 2, 2022 also you cant put a early crank in a 79 onwards block because it will hit the block,later 460 cranks are slightly smaller on the counterweight ,and later blocks from d9te have a little bit taller deck height and is the one to go for if building a stroker,also D6 truck conrods are the same strength as cobra jet rods and im lucky to have a set,and also have better bolts. 3 burnnotice1000, deankxf and Outback Jack reacted to this Share this post Link to post Share on other sites
burnnotice1000 588 Posted June 9, 2022 also you cant put a early crank in a 79 onwards block because it will hit the block,later 460 cranks are slightly smaller on the counterweight ,and later blocks from d9te have a little bit taller deck height and is the one to go for if building a stroker,also D6 truck conrods are the same strength as cobra jet rods and im lucky to have a set,and also have better bolts.Update,I got the block back in better than I thought cond,then spent a few hrs giving it its 2nd final clean,wd it,now wait a few days before painting the block,he fitted the pistons as well,also scored a timing pointer this morning.Sent from my SM-A125F using Tapatalk 3 1 CHESTNUTXE, deankxf, Outback Jack and 1 other reacted to this Share this post Link to post Share on other sites
gregaust 319 Posted June 10, 2022 On 6/3/2022 at 8:14 AM, CHESTNUTXE said: also you cant put a early crank in a 79 onwards block because it will hit the block,later 460 cranks are slightly smaller on the counterweight ,and later blocks from d9te have a little bit taller deck height and is the one to go for if building a stroker,also D6 truck conrods are the same strength as cobra jet rods and im lucky to have a set,and also have better bolts. Almost correct .. Spot on for the crank counterweights . The D9 blocks are same deck height, the difference is the bores are a bit longer downwards which in a stroker setup adds a little extra for the piston. Although in theory that is good , in reality it doesn't really make a huge difference 1 CHESTNUTXE reacted to this Share this post Link to post Share on other sites
dex 2,065 Posted June 10, 2022 Is that a “ gouge “ in no; 1 cylinder ,,? arround 7 o ‘clock position ,, 2 burnnotice1000 and CHESTNUTXE reacted to this Share this post Link to post Share on other sites
burnnotice1000 588 Posted June 10, 2022 Is that a “ gouge “ in no; 1 cylinder ,,? arround 7 o ‘clock position ,,I thinks it just run off from the still a bit dirty head bolt holes ,I took that picture about 1 minute after wd40 it and turning it around on the stand.Sent from my SM-A125F using Tapatalk 2 Outback Jack and CHESTNUTXE reacted to this Share this post Link to post Share on other sites
dex 2,065 Posted June 10, 2022 Had my ocd maxing out ! 2 CHESTNUTXE and burnnotice1000 reacted to this Share this post Link to post Share on other sites
burnnotice1000 588 Posted June 10, 2022 Had my ocd maxing out ! Well it could be , problem is evrytime I take a pic on that driveway the camera makes it look x5 worse than it actually is,if in the garage they seem to be fine,interesting thing about scratches I once took a 400 clevo crank to the machine shop to get it milled and he said that big scratch won't affect its performance,he could have easy said ahh yeah m8 $350 to mill it but he didn't and just got the crank linished and it was fine I guess maybe what angle the scratch or scouring is.Sent from my SM-A125F using Tapatalk 2 CHESTNUTXE and Outback Jack reacted to this Share this post Link to post Share on other sites
