gerg 10,871 Posted May 11, 2022 Yeah mate I think you're right about the different gasket set, the big one with two holes looks like a throttle body gasket (they had twins from memory). Dunno what the cork one is, never seen or worked on one to know.Sent from my CPH2197 using Tapatalk 1 burnnotice1000 reacted to this Share this post Link to post Share on other sites
gregaust 319 Posted May 11, 2022 You don't really need the turkey pan tray. Those blue gaskets in that set work awesome 2 burnnotice1000 and CHESTNUTXE reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,299 Posted May 11, 2022 greg i thought you said dont use the felpro inlet gaskets thats why i bought the turkey tray gobble gobble 1 burnnotice1000 reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,299 Posted May 11, 2022 On 4/23/2022 at 8:11 PM, gregaust said: That's very interesting .. The Victor Reinz gaskets are good . Those I'd say are a very nice choice . I use the VR nitro seal I've found work great . Please just stay well away from the Felpro print-o-seal (Black teflon gasket with blue beads) They are rubbish. They are coated for easy removal but the teflon coating allows them to creep around between the smooth surfaces . Most then leak coolant @ the front or are these felpro ones different greg 1 burnnotice1000 reacted to this Share this post Link to post Share on other sites
deankxf 20,266 Posted May 11, 2022 big block into XA to XF mounts? https://www.facebook.com/marketplace/item/1324810974681688/ 1 burnnotice1000 reacted to this Share this post Link to post Share on other sites
bear351c 10,269 Posted May 11, 2022 That timing chain is a standard Morse chain. Multi link for maximum quiet. Multi keyed sprocket is for advancing/retarding the cam. Reckon that round corky is for under the oil filler cap. ?? 2 Outback Jack and burnnotice1000 reacted to this Share this post Link to post Share on other sites
burnnotice1000 588 Posted May 11, 2022 That timing chain is a standard Morse chain. Multi link for maximum quiet. Multi keyed sprocket is for advancing/retarding the cam. Reckon that round corky is for under the oil filler cap. ??Yes bear I just bought it cause I never seen a Morse type with a multi Index sprocket on e bay says sold heaps of them ? Seem popular with a stocker,that big cork is a lot bigger than a rocker cover oil cap its about 5 inches Sent from my SM-A125F using Tapatalk 2 Outback Jack and bear351c reacted to this Share this post Link to post Share on other sites
burnnotice1000 588 Posted May 12, 2022 Yes bear I just bought it cause I never seen a Morse type with a multi Index sprocket on e bay says sold heaps of them ? Seem popular with a stocker,that big cork is a lot bigger than a rocker cover oil cap its about 5 inches Sent from my SM-A125F using TapatalkNice new timing cover came,has acc with it including dip stick coverSent from my SM-A125F using Tapatalk 5 gerg, deankxf, Outback Jack and 2 others reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,299 Posted May 17, 2022 i bought a heap of parts from america to finish off the engine ,now just a waiting game until everything arrives,good thing is i made a friend over there who has a mountain of 400s and 429/460s,we video on messenger and he is dying for a set of 302c closed heads (lol),he finds aussie clevo stuff a real goldmine,and giving him the rundown on info about how we got the tooling from the states then started pouring our own clevo stuff was a real eye opener for him,he did not even no about the D1AE high nickel 400 block i had,he has gone on a rampage looking one in the states.amazing when you find someone on the other side of the world that is right into all the stuff you love yourself,we have already got an idea about loading his container full of $200 complete 460s and 400s as where he is there is a abundance of them,a once a year shipment should be plenty to muck around with and sell,well thats the idea at this stage ,from the info i have dug up so far its double the price of a container ATM,from what it used to be,and our dollar is poor as well,but will keep it on the backburner for the moment,probly one of the reasons its very hard to find a 460 engine latley.if the deal works out i would love a few 429s just for info sake,you no,usual strip and rebuild while photos and description. 4 Outback Jack, gerg, SPArKy_Dave and 1 other reacted to this Share this post Link to post Share on other sites
Outback Jack 6,352 Posted May 17, 2022 Sounds like a sound plan.Best of luck 2red, hope the buisness goes well.Every Ford man loves a Big Block......Sent from my motorola edge 20 pro using Tapatalk 1 burnnotice1000 reacted to this Share this post Link to post Share on other sites
gerg 10,871 Posted May 17, 2022 There are still a lot of used but rebuildable 302 heads kicking around, can be had for not much. Still, in the States their aftermarket alloys are a lot cheaper than ours, and rebuilding factory iron 2Vs would be less and less feasible for HP per dollar.If he insists on getting hold of some, maybe you could strike a deal with him?Sent from my CPH2197 using Tapatalk 1 burnnotice1000 reacted to this Share this post Link to post Share on other sites
burnnotice1000 588 Posted May 18, 2022 There are still a lot of used but rebuildable 302 heads kicking around, can be had for not much. Still, in the States their aftermarket alloys are a lot cheaper than ours, and rebuilding factory iron 2Vs would be less and less feasible for HP per dollar.If he insists on getting hold of some, maybe you could strike a deal with him?Sent from my CPH2197 using TapatalkNice silvolite flat tops came,bearings as wellSent from my SM-A125F using Tapatalk 3 1 gerg, Outback Jack, CHESTNUTXE and 1 other reacted to this Share this post Link to post Share on other sites
burnnotice1000 588 Posted May 20, 2022 Nice silvolite flat tops came,bearings as wellSent from my SM-A125F using TapatalkStd replacement cam and lifters came it's like 440 inlet 480 exhaust Sent from my SM-A125F using Tapatalk 2 Outback Jack and deankxf reacted to this Share this post Link to post Share on other sites
SPArKy_Dave 8,863 Posted May 20, 2022 That stuff looks very fancy! What rings did you go with? 1 burnnotice1000 reacted to this Share this post Link to post Share on other sites
burnnotice1000 588 Posted May 21, 2022 That stuff looks very fancy! What rings did you go with?Finally found some rods this morning but he would only sell the crank n rods so now I have 3 cranks,check how beefy these std rods are,I've read they are good for 500hpSent from my SM-A125F using Tapatalk 3 gerg, deankxf and Outback Jack reacted to this Share this post Link to post Share on other sites
gerg 10,871 Posted May 21, 2022 I haven't read much about the Lima motor, do they have the same rods between 429 and 460, or do they change piston pin heights?Sent from my CPH2197 using Tapatalk 1 burnnotice1000 reacted to this Share this post Link to post Share on other sites
burnnotice1000 588 Posted May 21, 2022 I haven't read much about the Lima motor, do they have the same rods between 429 and 460, or do they change piston pin heights?Sent from my CPH2197 using TapatalkYes same rod,and pin height differences,there is actually more selection when coming to buying a set of aftermarket pistons for a 429 many companies make forged slugs because of the super cobra jet and others.Sent from my SM-A125F using Tapatalk 2 Outback Jack and gerg reacted to this Share this post Link to post Share on other sites
burnnotice1000 588 Posted May 23, 2022 Yes same rod,and pin height differences,there is actually more selection when coming to buying a set of aftermarket pistons for a 429 many companies make forged slugs because of the super cobra jet and others.Sent from my SM-A125F using TapatalkGot the old pistons taken off the rods and cleaned up just 1 for a look and turns out 040 these are a big pistonSent from my SM-A125F using Tapatalk 3 Outback Jack, gerg and deankxf reacted to this Share this post Link to post Share on other sites
burnnotice1000 588 Posted May 27, 2022 Got the old pistons taken off the rods and cleaned up just 1 for a look and turns out 040 these are a big pistonSent from my SM-A125F using TapatalkStruck a snag as no main caps as I was promised he said he don't have em so I'm fkd but wait a minute got another 460 block this morning and it's the same shape just needs some TLC and at least it has its caps,I was quoted around $750 to line bore the other block and almost impossible to find a set of 460 caps I just bought another block and saved this project,machine shop costs are huge.by the end of the day I got the block looking half reasonable Sent from my SM-A125F using Tapatalk 1 1 1 bear351c, gerg and deankxf reacted to this Share this post Link to post Share on other sites
gerg 10,871 Posted May 27, 2022 You could get some aftermarket 4-bolt caps but they only do the middle 3 on Clevos and big blocks from memory. You still have to line bore them to get them true to the mains tunnelSent from my CPH2197 using Tapatalk 2 Outback Jack and burnnotice1000 reacted to this Share this post Link to post Share on other sites
burnnotice1000 588 Posted May 27, 2022 You could get some aftermarket 4-bolt caps but they only do the middle 3 on Clevos and big blocks from memory. You still have to line bore them to get them true to the mains tunnelSent from my CPH2197 using TapatalkNo one has any stock gerg I have been searching online everywhere only ones that are available are the milodon set and they are about $700 and you still need the rear and front cap as well ,pro gram make them but no stock same as pro comp no stock by the time ya get it all done plus line bore its way too expensive that's why I just bought another block ,interesting on USA e bay there are many sets of 429 cj 4 bolt caps x5 full set for $1350 us also bought a set of factory 460 rocker covers and pushrods and rockers as well plus a few more cranksSent from my SM-A125F using Tapatalk 1 gerg reacted to this Share this post Link to post Share on other sites
burnnotice1000 588 Posted May 28, 2022 No one has any stock gerg I have been searching online everywhere only ones that are available are the milodon set and they are about $700 and you still need the rear and front cap as well ,pro gram make them but no stock same as pro comp no stock by the time ya get it all done plus line bore its way too expensive that's why I just bought another block ,interesting on USA e bay there are many sets of 429 cj 4 bolt caps x5 full set for $1350 us also bought a set of factory 460 rocker covers and pushrods and rockers as well plus a few more cranksSent from my SM-A125F using TapatalkGot the block a bit cleaner and chased all threads ,come Monday take it to olm8s de rusting tank for a dip ,also get him to hone it and fit the cam bearings Sent from my SM-A125F using Tapatalk 2 Outback Jack and deankxf reacted to this Share this post Link to post Share on other sites
burnnotice1000 588 Posted May 28, 2022 Got the block a bit cleaner and chased all threads ,come Monday take it to olm8s de rusting tank for a dip ,also get him to hone it and fit the cam bearings Sent from my SM-A125F using TapatalkNot sure what happened to pics Sent from my SM-A125F using Tapatalk 2 Outback Jack and deankxf reacted to this Share this post Link to post Share on other sites
Outback Jack 6,352 Posted May 28, 2022 Go the big block!Sent from my motorola edge 20 pro using Tapatalk 1 burnnotice1000 reacted to this Share this post Link to post Share on other sites
burnnotice1000 588 Posted May 28, 2022 Go the big block!Sent from my motorola edge 20 pro using TapatalkThis block is 060 over already and is quite usable I sanded 1 bore by hand and fitted a new piston just to make sure its not a rattler and seems to be ok there also virtually no lip so I'm in luck,amazing what are the chances of finding a 460 block with 2km of your house ? Well I fluked it again.Sent from my SM-A125F using Tapatalk 4 1 Outback Jack, gregaust, gerg and 2 others reacted to this Share this post Link to post Share on other sites
