gerg 10,871 Posted September 18, 2021 Good thing about it being pre-75 is it's guaranteed to be a 400 and not a 351M (unless someone's done a dirty crank swap in the past)Sent from my CPH1920 using Tapatalk 3 CHESTNUTXE, burnnotice1000 and Outback Jack reacted to this Share this post Link to post Share on other sites
burnnotice1000 588 Posted September 18, 2021 Good thing about it being pre-75 is it's guaranteed to be a 400 and not a 351M (unless someone's done a dirty crank swap in the past)Sent from my CPH1920 using TapatalkWell said gerg,somebody swiped the covers off it you can tell by how good cond inside the heads are probly the power by ford blue ones I'd say also its a DIF block meaning Dearborn industry foundry so it's a goody not the Michigan factory crack one pre 78,and guess what it turns over easySent from my SM-A125F using Tapatalk 3 gerg, CHESTNUTXE and Outback Jack reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,299 Posted September 18, 2021 i started pulling it down,no dramas so far,also has this yellow top coil ? could be factory,looks ancient. 1 Outback Jack reacted to this Share this post Link to post Share on other sites
gerg 10,871 Posted September 18, 2021 Could that be an old Accel? US Fords would have had a Motorcraft coil, Aussie ones Bosch.Sent from my CPH1920 using Tapatalk 3 CHESTNUTXE, Outback Jack and burnnotice1000 reacted to this Share this post Link to post Share on other sites
ZKFairlane 235 Posted September 18, 2021 It's the original autolite coil that the motor was built with. 4 gerg, burnnotice1000, CHESTNUTXE and 1 other reacted to this Share this post Link to post Share on other sites
deankxf 20,266 Posted September 18, 2021 should have just stuck some oil in it and fired it up. 2 CHESTNUTXE and burnnotice1000 reacted to this Share this post Link to post Share on other sites
burnnotice1000 588 Posted September 18, 2021 should have just stuck some oil in it and fired it up. Nah it deserves a strip down and clean up tomorrow will continue on and gut it I reckon it's STD bore and really only bought it for the crank and rods for my other engine as ordering them from the states would have cost about $900 on USA e bay maybe more because posting a crank weighs heaps and just not worth it,will just sell the block if it's STD bore ,heads too,manifold ain't worth anythingSent from my SM-A125F using Tapatalk 4 deankxf, CHESTNUTXE, Outback Jack and 1 other reacted to this Share this post Link to post Share on other sites
gerg 10,871 Posted September 18, 2021 Nah it deserves a strip down and clean up tomorrow will continue on and gut it I reckon it's STD bore and really only bought it for the crank and rods for my other engine as ordering them from the states would have cost about $900 on USA e bay maybe more because posting a crank weighs heaps and just not worth it,will just sell the block if it's STD bore ,heads too,manifold ain't worth anythingSent from my SM-A125F using TapatalkHow do they go with adapting 351W stroker cranks to these blocks? Same bearing size, the only difference I think is something to do with the snout where the timing gear goes?Sent from my CPH1920 using Tapatalk 2 CHESTNUTXE and burnnotice1000 reacted to this Share this post Link to post Share on other sites
burnnotice1000 588 Posted September 18, 2021 How do they go with adapting 351W stroker cranks to these blocks? Same bearing size, the only difference I think is something to do with the snout where the timing gear goes?Sent from my CPH1920 using TapatalkI haven't worked that one out yet Sent from my SM-A125F using Tapatalk 1 CHESTNUTXE reacted to this Share this post Link to post Share on other sites
burnnotice1000 588 Posted September 18, 2021 I haven't worked that one out yet Sent from my SM-A125F using TapatalkThe lid n balancer is off interesting note all clevo manifolds USA anyway seem to have the cf cast mark but 3 different locations for block castingSent from my SM-A125F using Tapatalk 2 gerg and deankxf reacted to this Share this post Link to post Share on other sites
gerg 10,871 Posted September 19, 2021 Michigan Casting Centre, Cleveland Foundry and..... ?Sent from my CPH1920 using Tapatalk 1 burnnotice1000 reacted to this Share this post Link to post Share on other sites
burnnotice1000 588 Posted September 19, 2021 Michigan Casting Centre, Cleveland Foundry and..... ?Sent from my CPH1920 using TapatalkDearborn gerg,or dif or in Aussie lingo diligaf oh no I popped the first head and coolant went everywhere but it look pretty clean so maybe this done has not been sitting that long,head looks ok tooSent from my SM-A125F using Tapatalk Share this post Link to post Share on other sites
gerg 10,871 Posted September 19, 2021 Well at least it had green sht in it at some stage, water jacket might be ok.Sent from my CPH1920 using Tapatalk 1 burnnotice1000 reacted to this Share this post Link to post Share on other sites
gerg 10,871 Posted September 19, 2021 That's right, forgot about Dearborn. So that's at least 4 casting plants they had back then... Windsor is straight across the river from Dearborn, but in Canada.Sent from my CPH1920 using Tapatalk 1 burnnotice1000 reacted to this Share this post Link to post Share on other sites
burnnotice1000 588 Posted September 19, 2021 That's right, forgot about Dearborn. So that's at least 4 casting plants they had back then... Windsor is straight across the river from Dearborn, but in Canada.Sent from my CPH1920 using TapatalkLunch time and yup it's STD bore fak pistons but 020 on the big ends only got 1 out so far and had a double roller chain so someone has rebuilt it before Sent from my SM-A125F using Tapatalk 2 1 deankxf, Outback Jack and gerg reacted to this Share this post Link to post Share on other sites
burnnotice1000 588 Posted September 19, 2021 Lunch time and yup it's STD bore fak pistons but 020 on the big ends only got 1 out so far and had a double roller chain so someone has rebuilt it before Sent from my SM-A125F using TapatalkOk all done and 010 on the crank also collected a lot of bolt ons ,I'm stoked I got a 400 crank and good rods Sent from my SM-A125F using Tapatalk 2 CHESTNUTXE and Outback Jack reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,299 Posted September 19, 2021 Here is what i mean about the high nickel cast number the D1AE with nothing after it is high nickel,and the 2nd picture is the one i took apart today,and just a std cast block. 1 burnnotice1000 reacted to this Share this post Link to post Share on other sites
burnnotice1000 588 Posted September 24, 2021 Here is what i mean about the high nickel cast number the D1AE with nothing after it is high nickel,and the 2nd picture is the one i took apart today,and just a std cast block.The crank is polished and 020 rod size and 010 mains,he also cleaned the rods and ready for new pistonsSent from my SM-A125F using Tapatalk 3 1 Outback Jack, CHESTNUTXE, gerg and 1 other reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,299 Posted September 24, 2021 im gunna get new arp rod bolts and have them fitted later on,and he also marks the rod with a x for some reason,i think its got to do with what way the piston faces ? maybe gerg knows. 2 gerg and Outback Jack reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,299 Posted September 24, 2021 i sold the std bore block and heads to a guy from brisbane who is picking it up later this arv,it didnt last long on marketplace,so i got my money back and the crank n rods i needed,plus a few other bits n pieces. 2 1 Outback Jack, deankxf and gerg reacted to this Share this post Link to post Share on other sites
RM351 148 Posted September 24, 2021 I've been unlucky when it came to buying a 400. Purchased 2 over the years, the first one I went the trouble of getting from the US via ebay. At that time the aussie dollar was over the 90 US cent mark. Engine was fine except on hot days, it was bored 60 thou. 2nd one I bought it here, came out of a '71 Galaxie with a C6 and I currently have. This one is already 40 thou and needs a rebore, not going to bother. Gave it a hone but as you can see it ain't enough. 2 burnnotice1000 and Outback Jack reacted to this Share this post Link to post Share on other sites
burnnotice1000 588 Posted September 24, 2021 I've been unlucky when it came to buying a 400. Purchased 2 over the years, the first one I went the trouble of getting from the US via ebay. At that time the aussie dollar was over the 90 US cent mark. Engine was fine except on hot days, it was bored 60 thou. 2nd one I bought it here, came out of a '71 Galaxie with a C6 and I currently have. This one is already 40 thou and needs a rebore, not going to bother. Gave it a hone but as you can see it ain't enough. I've come across quite a few in the last year or so I like em ,I see that block is the DIF casting ,very common in Australia as most of them came out of galaxy's ect,a few show up out of 4x4 s and f trucks like the CF block I just rebuiltSent from my SM-A125F using Tapatalk 3 1 RM351, CHESTNUTXE, gerg and 1 other reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,299 Posted October 3, 2021 3 1 bear351c, gerg, deankxf and 1 other reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,299 Posted October 4, 2021 1 gerg reacted to this Share this post Link to post Share on other sites
CHESTNUTXE 7,299 Posted October 7, 2021 The 400 reco engine sold last night,$4000,picking up saturday,that facebook marketplace is 1000 times better than e bay,in just 2 days i had 2000 looks instead of 50 looks for 7 days on e bay,now have some cash to look at some wheels for my own 400 engine,but slim pickings out there ,i hope i can snag something that is not advertised,prefer xe sedan roller . 3 deankxf, gerg and Outback Jack reacted to this Share this post Link to post Share on other sites
