CHESTNUTXE
CLEVELAND ENGINE TALK
Recommended Posts
ok he gunna charge $150 for hot tanking and rust dipping,price is ok but i think i will just sell them the way they are for a cheaper price,like $300 ea .
Share this post
Link to post
Share on other sites
A cheap molasses tank would be one of the plastic water/chemical tanks that hold a cubic metre. Would fit a couple blocks in at the same time. If you cut the top off in the right way and you have a lid to cut down evaporation.
Share this post
Link to post
Don't leave it in too long though or it could be like this ^^
Ok lets start the stripdown of what appears to be a black block that turns freely and has typical xd xe v8 water neck.663fc99c89d040b4e46be0087c188592.jpg410fff3890c83c713164849b6e674434.jpg
Sent from my SM-G610Y using Tapatalk
Share this post
Link to post
XC had that neck also didn't it, related to the thermoquad?
Yes correct and my thoughts of a black block have now turned blue block ,this engine has been rebuilt and all bolts coming off easy and they were perfect on torque settings ,shes a 302c and in good cond inside even cam looks reuseable maybe , its very dirty on the outside but inside its a gem ,now onto if its had pistons and bearings my gut feeling is yes382e6b6e2ef81591f488b765f9d57a3c.jpg83c6f948700835eb50015c8ae9c98b67.jpg437937679e1f3d4632150464cfc60b24.jpg52dbf0814f4e3a61bce493eead24b5c7.jpgf206daa72be2c332a1a66ef407cfe8d7.jpg5f680471068f50ae6ba445767856a628.jpg0002092e82a3a906ccc7a23e74cf9f52.jpg
Share this post
Link to post
ok i put a solid day in and end of it got the block looking a lot cleaner for sure ,turned out this one was 10/10 bearings and new pistons,so puts it as a candidate for re co ,also had a double chain,turns out its a 1973 block and here i was thinking a black block.
Share this post
Link to post
Pics15915572f03af3d5eb2b56809243d993.jpg8f625b1699d50c47af5547498f223b45.jpg629f0f0e719d530b9edc6dd5ce059381.jpg6e8d2d800e02e9a9adc0bc699383f0a1.jpg91df76393f421e2abe375ceb740a0908.jpgf8688ec8cb124bdf501452ad1d55593b.jpgc279875b0d3eee3ada6a1d3b3fd69678.jpgb3158f9b7f4c32dc8f6f488c9348dc29.jpg4e5303a24e4a0ac7912b38c0ff3e1812.jpg
Share this post
Link to post
the crank is not good on this one and there is no way im gunna get it ground,i have the other 302 c engine to take apart aswell,lets hope the crank is a bit better on that one.
I dragged the other 302c out for inspection and teardown lets hope the crank is okd9faa5178148798e6a6524dea4e7e6d1.jpgc1c338e7d0fe13b7ebfd285441c042d9.jpg0f6f7b42b835eb30a5af44999e014dd1.jpg0851e6519f0f802d5c63e5a0c175e8a4.jpg
Share this post
Link to post
What a mess to get to the std bore block it also had std factory bearings and timing chain , also good news the crank is quite up to a polish for the 302c rebuild18c53be266d2555046efa301e659b25b.jpg012799c8a0f82e22bce5eb42a341dd18.jpg
Share this post
Link to post
New usa rockers came alsp new 400 pushrodsbe81ba16f15a20b1ac310a03be534a3e.jpg
Share this post
Link to post
Does blue block mean pre xc xd?
Share this post
Link to post
Yeah, my XB is JG34.....  (1975 Fairmont) Blue blocks had larger dizzy shaft hole in block, XD/XE had slightly smaller (black blocks)
Will continue on today with susing out parts to rebuild one good 302
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
